Question about Danby DAR482BLS Compact Refrigerator
Dar482bls compressor is hot but does not come on relay clicks every 2 to 5 min. what is wrong
Is the problem with the start relay and if so where is it located?
Lincoln navigator1999 where is the relay for the fuel pump located and how to check if it is working
It's located under the hood. Usually the underside of the lid will have a layout of the fuse, and relay location. Pull the relay for the fuel pump, and replace with another relay of same numbers on top of the relays. Then try turning on the vehicle. Hopefully it will start. If so, then you replace the old bad relay.
Jun 25, 2014 | Cars & Trucks
2003 mitsubishi eclipse rs wont start i already repalced the starter...where is the starter relay at
The relay is located in the relay box under the hood in the relay box. I suggest you Google "relay location 2003 Mitsubishi Eclipse" for the exact location. For troubleshooting purposes, once you locate the relay, simply swap it with an identical relay within the relay box. If it still fails to start, then it is not the relay.
Apr 11, 2014 | 2003 Mitsubishi Eclipse Coupe
Where is the starter relay located on a 2011 Dyna Glide?
Start Relay
The fuse block located under the left side cover contains the
start relay.
Jan 21, 2013 | Harley Davidson FXD Dyna Super Glide...
Locate start enable relay 1993 cadillac eldorado
The starter enable relay is located taped to harness 5" rear of front edge of left rocker panel channel.
Hope this is helpful.
Sep 03, 2012 | 1993 Cadillac Eldorado
Fuse and relay for the fuel pump
The fuel-pump relay unit is responsible for turning the fuel pump on when it detects the engine is running. When the ignition signal stops, the fuel-pump relay switches the pump off. Problems with the ignition and starting the vehicle often can be traced to the condition of the fuel-pump relay.
Description
  • The fuel-pump relay is a small unit, typically enclosed in a plastic case. The unit contains several sprockets on one side that are clipped onto the ignition system. The fuel-pump relay is engaged only during the start cycle. If it is faulty, it can take longer to start your vehicle.
  • Location
  • Most fuel-pump relay units are located under the dashboard near the steering column. In some cases, the unit is located in the area where the steering column is mounted or near the engine's firewall. The end of the fuel pump relay is typically located near the center of the floorboard, under the carpet in the front section of the passenger's or driver's side footwell.
  • Considerations
  • In addition to difficulty in starting the vehicle, symptoms of a poorly functioning fuel-pump relay include the following: the car dies then starts a few minutes later; the fuel pump makes a strange noise (humming or clicking loudly) for longer than five to 10 seconds after starting; or the engine won't start after you have engaged the fuel-pump switch.
  • Troubleshooting
  • When your car does not start properly, you can conduct a fuel-injection relay test. Two relays are located inside the fuel-injection system; one of them is responsible for turning the ignition on without turning over the engine, and the other is responsible for turning on when the engine turns.
    You can check to see if the first relay is working by touching it while turning the ignition on and off. You should feel a "click" every time you switch the ignition. If the fuel-pump relay is not working, you can "jump" the unit with a small lead jumper cable. You will need to access the fuse panel and insert the cable into the relay unit; the unit will run as long as the wire is inside the relay and can help start your car.
  • Jan 15, 2011 | Chevrolet Lumina Cars & Trucks
    Fuel relay placement 1991 Buick LeSabre. Replaced pump & filter still won't start
    Your vehicle's fuel pump relay is located on the relay center, behind the glove box, 2nd column of relays, 2nd one from the top.
    May 23, 2009 | 1999 Buick LeSabre
    Where is the starter relay on a 1996 Mitsubishi Eclipse?
    1. take out your cd player or stereo
    2. the starter relay will be located in that hole
    3. to start you car take off the relay and conect terminals 2 and 4,and it will run again.
    May 21, 2009 | 1997 Mitsubishi Eclipse
    Fuel pump relay for a 1994 Chevy Truck WT1500
    The Fuel Pump Relay is located in the Glove Box under a little cover on the upper left side. The Fuel Control Relay is the left relay and The Fuel Pump Relay is the right. To test these relays, swap them and then try to start the vehicle, or blow the horn. If the horn blows then use that relay for the pump and you may at least drive the vehicle where needed! If the vehicle starts, then replace them as a pair.
    Apr 27, 2009 | 1994 Chevrolet S-10 Blazer
    Fuel pump shut off switch
    no it doesn't. the fuel pum has a relay that is located in the junction box under the hood if your vehicle is not starting because your not getting fuel check the relay. I use the a/c clutch relay to switch with the fuel pump relay if the vehicle starts just replace the relay if the vehicle doesn't start then you have a bad fuel pump...please rate
    Oct 04, 2008 | 2002 Dodge Neon
    Danby DAR482BLS Compact Refrigerator Logo
    55 people viewed this question
    Top Danby Refrigerators Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    jason
    Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
