Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
Hp laserjet m1522nf won't turn back on
It froze I tried everything but couldn't get it to work, so I turned it off via switch on back and now it won't turn on...
SOURCE: My HP LaserJet M1522nf worked
It is probably a formatter board (the main circuit board) problem. This is very common with this model of printer. The printer should either be serviced by a technician or replaced. If the printer is still under warranty, contact HP for support.
Posted on Apr 22, 2010
  • 123 Answers
SOURCE: how to reset password in hp laserjet m1522nf
You can try setting the printer back to fabric settings following this simple steps:
1) Turn the printer off
2) Now while the printer is off, press and Hold the down arrow and cancel button
3) Keep them depressed and turn the printer back on while holding those keys
4) you will see a message on the display that reads "permanent storage init" at this point you can release the buttons
After this steps you need to wait about 3-4 minutes and then the printer will come back to ready
Password reset DONE !!
If you need more assitance you can contact me at :
eliteprintersolutions@gmail.com
Posted on Jul 14, 2010
  • 223 Answers
SOURCE: How to Reset HP Laserjet M1522nf security password
Hi the easiest way is a nv ram
1. Turn the printer off
2. Hold down the down arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
This reset will clear all of your saved settings and contacts, if networked print out a configuration report after resetting the printer to view the ip address (IPV4). If the IP address has changed you will need to update the print driver's port tab and update the port.
Good Luck
Al,
Eliteprintersolutions@gmail.com
Posted on Jul 15, 2010
  • 56 Answers
SOURCE: HP Laserjet M1522nf - displaying
this error can be caused by a paper jam, or a little piece of paper in the toner area, Take the cartridge out and use a flashlight to check in the sides looking for paper. Other reason is that sometimes the sensor that detect the toner is out of place and in that case you can try to power cycle with the toner out before you install it again. Good luck
Posted on Sep 08, 2010
BaronVonNuke
  • 1915 Answers
SOURCE: My hp laserjet M1522nf is
You need to connect the unit via USB and then run the HP firmware update utility so that the current firmware can be installed. This error is usually caused when a firmware update is interrupted. Current firmware for this unit is 20100902.
Posted on Mar 05, 2011
95 s10 4x4 wiring issues wipers don't work they
sounds like the ignition switch. usually different items go out and then work when you have a bad connection
Jul 22, 2014 | Cars & Trucks
I replaced the ignition lock cylinder in my 92 cabriolet and I turned the key and it started first swing, then I was putting the steering wheel covers back on and it just turned off... When I try to turn...
If it's an automatic check fuse #15 wether it's a stick or automatic you should have power at the red & black wire coming out of your ignition switch when you turn key to start postion and power at the red wire going into switch at all times. if no power coming oit on the red/black wire you need an ignition switch. if there is power coming out of switch try putting car in nuetral (for auto trans). if still nothing you'll need to check for power at small wire going to starter when key is turned to start. if has power then need starter if no power you'll need to check starter interlock relay.
Dec 31, 2012 | Cars & Trucks
My air conditioner isnt blowing cold air
is the ac a manual one or automatic? if it's manual then it froze and will no longer work. it froze and is all done working. time for a new one. I bought one 12 years ago and apparently I was suppose to turn on and off. The ac couldn't do that. IF it works on it's own maybe the circuit isn't the higher amp for 220 ac units.
Sep 07, 2012 | tranexp.com Computers & Internet
HP Pavillion a1514n Won't Turn On
Hook a monitor to the video output, if no change! the video graphics chip is bad located on the motherboard.
Jun 29, 2012 | HP Pavillion dv9740us Notebook
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
My Shuttle Barebone K48 will not even power on.
Try to run it with only one stick of memory in at a time. If the memory doesn't work the computer won't even go into the POST. It only takes one failed stick to stop a computer.
Mar 07, 2012 | Shuttle KPC K48 Barebone
Post Test card reads 43 what does it mean?
when was it manufactured . it has possibly went past it's life expectancy
Mar 01, 2017 | StarTech.com PCI Post Diagnostics Test...
2010 Elantra Touring - car won't start - doesn't turn over (battery is fully charged), clock/radio & A/C units don't work, and EPS doesn't work. Dealership cannot figure it out.
sounds like a fuse. check them and get back to me. If the shop you took it too cannot figure it out they probably should not be a shop. i hope they didnt get you for a diag fee. Im going to locate a wire diagram to help you figure this out.....Also you said you put a new battery in the car, check that the battery terminals are clean and tight.
Oct 06, 2011 | Cars & Trucks
When attempting to fax, prompted that storage is full, how do I clear storage.
please tell me how to give ip and i treid many time to to setup to give ip to connection my computer with printer but i couldn't
Jun 17, 2011 | HP LaserJet M1522nf Multifunction Printer...
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
319 people viewed this question
Seeker5211
Seeker5211
