Question about Olympus SP-590 UZ Digital Camera
The following error occurred while importing image.jpg the system cannot find the file specified" I have tried everything I can think of - I am on the verge of buying a new camera as I need this to be
I have searched other solutions and none have worked for me. It states the message above, plus this one "an error is preventing the photo or video from being displayed Error code: 0x8000000a". It used to work fine so I just don't get it. Please help because I am that close to having to buy a new camera!!!
  • 883 Answers
SOURCE: Olympus XD card low level formatting help needed
purchase another card (smaller memory and cheaper...as a test). install it. if it works, then read file folder names under windows and then copy these folders over to the 1GB card.
Posted on Jun 03, 2007
IrishDruid
  • 2712 Answers
SOURCE: Help! Will not let me transfer images from camera
Removing the software and reinstalling it using a "clean boot" may resolve the symptoms you are experiencing. Booting clean is a way to eliminate programs from conflicting with installation of software.
1. Unplug the camera from the computer. Later you will be prompted by the software to plug in the camera; do so at that time only.
2. Open the Windows Control Panel.
3. Open the Add / Remove Programs window.
4. Locate the listing for the camera software and remove it. When prompted to remove the camera drivers files, click Yes.
5. Locate any other camera software and remove it as well.
Now download the latest version of the software for your OS from the manufacturer's website.
The following is the procedure for a 'clean boot'. I am assuming that you have XP. If you have a different OS, just let me know and I will send you the appropriate procedure to boot clean in that OS.
1. Click Start --> Run --> Type MSCONFIG --> Click OK
2. On the General tab, choose Selective Startup
3. Uncheck Process SYSTEM.INI file
4. Uncheck Process WIN.INI file
5. Uncheck Load Startup Items
6. Click on the Services tab
7. At the bottom, check Hide All Microsoft Services
8. Uncheck all boxes in the window or click the button labeled Disable All
6. Click OK
7. Click Restart
After restarting, install the downloaded camera software. Next, do the following:
1. Click Start --> Run --> Type MSCONFIG--> Click OK
2. Replace checkmarks in the items that you previously removed them from.
3. On the General tab, choose Normal Startup
4. Click OK
5. Click YES, when asked to restart your computer
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 03, 2008
  • 919 Answers
SOURCE: Hello, My Olympus u700 Camera displays an error code "D: 5e02, 5f08". What do I do? Please help! Thank you. Regards.
The problem you are describing is a problem with the sensor in the lens assembly. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $86 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Posted on May 08, 2009
SOURCE: Problem downloading image
One of the images did not finish writing to the card properly (usually in the last 4 or 5 images, or the last video)
Try selecting all but the last 10 images and chose import selected. This should work. Then delete those from the card.
This bit is important
Put the card back in the camera (if it's in a usb reader) if not, disconnect the camera and put it into playback mode. View the remaining 10 images/video.
Try re importing and it should work fine! I've had this problem since ilife '09 and this method always fixes it. It seems to happen when the cards get full. Try not to completely fill a memory card and you should not get the problem.
Posted on May 31, 2009
  • 4 Answers
SOURCE: My Olympus U700 camera is coming up with a blue
lens is out of adjustment , try slapping the camera in your palm as your powering up, it might take a few times so be patient that should reset lens
Posted on Feb 22, 2010
Tip
How to hide files in a jpg photo
1) Take two files -
one which you want to hide and another will be the jpg image(of any size and dimension)to hide that file
If you want to hide multiple files in one jpeg image, just zip them into one file
2) To make the process easy, Copy the above two files to the C:
3) Now open the command prompt (Go to start, Click "RUN" and type "cmd").
4) get to the root by typing cd\ or you can give the path name where the files are located
5) Now type the following command:
copy /b imagename.jpg + filetohide.ext new_image.jpg
6) Now a new file new_image.jpg will be created
7) Double click on the file and it will open the image which you used to hide the secret file
8) To access the hidden file simply change the extension from jpg to orignal extension of the hidden file,
Example: I took an image filename "myphoto.jpg"
I wanted to hide some important word documents so I zipped all the word files and created a zip file "word.zip"
Then copied both "myphoto.jpg" and "word.zip" to c:
Opened the command prompt
Typed the command: copy /b myphoto.jpg + word.zip new_image.jpg
Now I have a new file "new_image.jpg" in C:
When I double click on the new file it shows me the image of "myphoto.jpg"
If I change the extension of new_image.jpg to new_image.zip I can extract the contents of the .zip file
ENJOY !
ENJOY !
on Dec 03, 2009 | Computers & Internet
Save GIMP image as jpg
Press CTRL+E, type in the file name you want and add the '.jpg' or '.jpeg' extension to the end, deleting any other file extensions. Then navigate to where you want to save it and hit Export. From there, its just an issue of importing the .jpg image from wherever you saved it, into Publisher.
Nov 23, 2012 | Computers & Internet
Hi, I am trying to install the drivers for my HandHeld 3800G Linear Imager (barcode scanner), but keep getting the following error: "Cannot Install this Hardware There was a problem installing...
you may have to delete the file or uninstall-then reinstall..if this does not work you may have to go to the honeywell site and reload the drivers again as you may have lost a thread during the initial download ...happens more than you think...good luck
May 19, 2017 | Honeywell (formerly Hand Held ProductsHHP)...
Can't download the photos from the MiCam Junior Digital Camera. Software has been correctly installed, laptop recognises camera but when try to download error message "there is a connection...
I have uploaded the installation CD here (188.81Mb): http://depositfiles.com/files/qmc5ykx6p
I have uploaded the user manual here (2.6Mb): http://www.filejumbo.com/Download/26D632AAF285B1D0
Acquiring images from a TWAIN Device PhotoImpression accepts images acquired via standard TWAIN devices. 1. Click the Get Photo button on the Main Screen, and select Camera/Scanner. A list of your TWAIN devices will appear. 2. Select your desired device from the Select Source pull-down. 3. Select the album to which you wish to link the acquired image(s). 4. Click the Acquire Options button to set your acquire parameters: a. Specify the file format for the acquired images. b. Specify the save directory for the acquired images. c. Choose whether or not to retain the original file format (for example, some cameras may save in a specific format-you can have the program convert the files to an option of your choice, or retain the original format). d. Set the file names for the incoming files. You can choose to have the program automatically name the files using the current date, or you can specify your own unique file name. 5. Click the Acquire button if you are capturing from a still camera or scanner; click the Video Camera button if you are capturing a still from a video. Follow the procedures specific to your device to import the image into PhotoImpression.
Updates for the Arcsoft application "PhotoImpression" are available from Arcsoft
If there are connection errors, that could be from:
  1. USB connection error
  2. Hardware issue
Try plugging the camera (via USB) to a different port on the computer, then acquire the pictures using the included software, or your own photo editing software that is capable of acquiring images from a TWAIN device.
Hope this helps!
Guy
Dec 31, 2010 | Cameras
How to get no. Of pixels from given image through java
try this code
import java.awt.image.PixelGrabber;
import java.awt.Toolkit;
import java.awt.Image;
class getpixel2
public static void main(String args[]) throws Exception
Image image = Toolkit.getDefaultToolkit().getImage("D:\\one.jpg");
if(image==null)
System.out.println("NO FIle");
PixelGrabber grabber = new PixelGrabber(image, 0, 0, -1, -1, false);
if (grabber.grabPixels())
int width = grabber.getWidth();
int height = grabber.getHeight();
if (isGreyscaleImage(grabber))
byte[] data = (byte[]) grabber.getPixels();
else
int[] data = (int[]) grabber.getPixels();
for(int i=0;i<data.length;i++)
int r = (data[i] >> 16) & 0xff;
int g = (data[i] >> 8) & 0xff;
int b = (data[i] >> 0) & 0xff;
System.out.println("(R,G,B)=("r","g","b")");
public static final boolean isGreyscaleImage(PixelGrabber pg)
return pg.getPixels() instanceof byte[];
} import java.awt.image.PixelGrabber;
class getpixel2
if(image==null)
else
May 15, 2010 | Computers & Internet
Inserting images into a flash website template
first make sure that your pics are the same file extension
(jpg,bmp,png ext)
if the original pic in the flv was named top1.jpg make sure that the pic you import is named top1.jpg
Aug 03, 2009 | Adobe Flash Pro CS4 for PC
Importing Error
The problem is probably the same one i had. After successfully importing videos and pictures from my SD card, Windows 7 started giving me that error. I discovered that it was caused by the fact that I had imported some directly to an external USB hard drive (E:) and had set the default import directory to it (I can't remember if I had done this dileberately, or if W7 remembered it).
Fix: Just before you start the import, click the more options link at the bottom, and change your default folder to the local drive or to an attached external drive, something that exists at the time.
Worked like a charm after that!
Bill
Singer/Songwriter
www.billandkateisles.com
Jun 07, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
Will not show or import jpeg or jpg files
You need to ensure that the background images are turned off in the entertainment menu first then insert disc or usb stick to show images.
May 02, 2009 | Car Audio & Video
Olympus SP-590 UZ Digital Camera Logo
556 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
