Question about Toshiba Satellite A15-S129 Notebook
Toshiba Satellite A200 -AH9 Wont Turn On.
I was using the computer a few days ago, full battery, plugged into AC and then all of a sudden it turns off, stops working, fails, dies (you get the point). Pressing the power button yields NO reaction not even a flicker. When plug in the computer the blue "plugged in" light blinks and nothing else works, when unplugged there is nothing.
Again, the laptop stopped working while on full battery, while plugged in and now, whatever i try nothing happens.
  • 70 Answers
Maybe you have power conection problem
your problem maybe on the circuit after the battery
so you must check your circuit
or you can contact your Laptop manufucturers
Posted on Jan 21, 2009
I have Toshiba Satellite A200-1CC. It wont give a sign of life when the power button is pressed. AC power cord with jack are okay, Wall power cords are new. It won't fill the baterry, but when the bat
first try to check if your toshiba is still part of the warranty. if this is good, much better to go to the service center and they will replace the battery pack of your laptop.
Dec 15, 2011 | Toshiba Computers & Internet
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
Laptop won't reboot
are you trying to put win 10 on as it can do this some time, can take upto 10 15 min to load, when the like is flashing its dos, when the screen is black its windows it takes some time for windows to find a driver and load it so the screen comes up. i've had this on a200's before. if you keep rebooting you will need to wipe the hard drive and start again. this also does this on win 7 and 8. win xp it does not do this as its full dos setup .
Jun 30, 2017 | Toshiba Satellite Pro A200-EZ2204X...
Laptop Toshiba Satellite A200 Model No. PSAF6A-02C01N fail boot
Try removing / swapping / reseating the memory.
Try booting with one stick only, if the top slot doesn't work, try booting the bottom slot. Try both sticks.
Let me know what happens.
Apr 04, 2010 | Toshiba Satellite A200-0ET00X Notebook
Toshiba Satellite A200 unstable on power
The problem is probably not in the motherboard itself, but may be internal to the laptop.
From what you've described the problem is either in the AC Adapter itself or in the power supply inside the laptop (the area where you plug the AC adapter into the computer.
The first thing to try is another AC adapter if you can get a hold of one or purchase one if need be as it's the most likely source of the problem. More than likely it's providing enough power for the system to recognize it's attached and draw power from it, but there is likely a short inside it or the cords keep the power from being constant.
If you do not have a full adapter to test with, you can replace the end that plugs into the wall with and universal plug - something you can buy at major retail stores. The adapters take a lot of wear and tear and can be damaged from all the stuff we put them through.
Dec 25, 2009 | Computers & Internet
My loaptop aint working at all
Try removing the battery and pulling the power cable then put the battery back in and plug the computer back in and turn it on.
Jan 10, 2009 | Computers & Internet
Battery discharges, and will not charge, computer wont run on AC
how long have you had your laptop? the toshiba laptop battery can be normal used in 400-500 cycles, that means normal in 2 years. if the age is over 2 years, the battery declines day by day. get a new one if it is unnormal
Dec 04, 2008 | Toshiba Satellite P35-S609 Notebook
Toshiba satelite A100 rejects AC... often.
Just to humor me, are you using any peripherals with your laptop when this happens, such as a wireless mouse, USB connections such as digital cameras? Try to take these away when recharging.
There seems to be 2 issues here.
1) Recharing batteries: To prepare the batteries for long-term use (I do not know how long you've had the batteries...try draining the batteries (both of them), and then recharging it to full 2x before using them without the AC Adapter. This should clear the problem.
2) AC Adapter only works every other day: When you swapped the power pack, was it with a new AC adapter, or another used one? Also, have you tried using a different outlet than the one you normally use? Let me know how this turns out.
Nov 17, 2008 | Toshiba Satellite A100-S8111TD Notebook
Doesn't start up
remove the primary battery and plug the computer into an AC outlet using the AC adapter. If the computer starts up, one of the batteries need to be replaced. If the battery light on the of the comoputer is blinking, the battery has reached a low batery level, which may not allow the computer to start up. Plug the computer into an AC outlet using the AC adapter to start the computer and allow the battery to charge.
Dec 30, 2007 | Toshiba Satellite M55-S3512 Notebook
Toshiba Satellite A15-S129 Notebook Logo
276 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
