Question about Bosch T-map Sensor 0281002437
Map sensor for 2006 ford freestyle - Bosch T-map Sensor 0281002437
  • Bosch Master
  • 8,220 Answers
Let me guess hard cold start right?
Posted on Jan 09, 2013
CARMD READOUTS ON MY 2006 FORD FREESTYLE CODES # PO 174,171,401,457, ALSO P2104,111,112,218 WHAT'S WRONG WITH MY FORD?
P0174: Fuel Injection System Too Lean Bank 2 http://www.autocodes.com/p0174_ford.html
P0171: Fuel Injection System Too Lean Bank 1 http://www.autocodes.com/p0171_ford.html
P0401: Exhaust Gas Recirculation Flow Insufficient Detectedhttp://www.autocodes.com/p0401_ford.html
P0457: EVAP Control System Leak Detected Fuel Filler Cap Loose/Off P0457 Ford EVAP Control System Leak Detected Fuel Filler Cap Loose Off
P2104: Throttle Actuator Control System Forced Idle http://www.autocodes.com/p2104_ford.html
P0111: Intake Air Temperature Sensor 1 Circuit Range/Performance Problem http://www.autocodes.com/p0111_ford.html
P0112: Intake Air Temperature Sensor Circuit Low Input
http://www.autocodes.com/p0112_ford.html
P0218: Transmission Fluid Temperature Over Temperature Condition http://www.autocodes.com/p0218_ford.html
Dec 07, 2016 | 2006 Ford Freestyle
How to change a throttle body position sensor on a ford freestyle 2006
Four nuts to remove, unplug it and pull out the gas pedal. Called the APP sensor. Actuator pedal position sensor.
Feb 25, 2016 | Ford Cars & Trucks
My codes that keep coming up are p2111, p2104, and p2112. Do you think i need a new throttle position sensor?
The Freestyle has a revised (non-heated) Throttle body replacement kit that cures the problem. That's what you need...
Oct 31, 2014 | 2006 Ford Freestyle
Where is the camshaft position sensor located on a 2006 ford freestyle
home scanners give an aproximation of issue--go to partsplace and they can tell u or getta repair manual-------if part is cheap gamble and replace it-----but an analyser that runs a data stream will pinpoint solution
Jun 08, 2012 | 2006 Ford Freestyle
Abs light on after replacing hub bearing
Sounds like the ABS sensor has failed, or is unplugged. If someone did the work for you, take it back. Otherwise check the sensor on the right front. Replace as necessary. Also ask the Q at MyFordFreestyle.com
Feb 10, 2010 | 2006 Ford Freestyle
2005 ford freestyle code P0106
PO106 is faulty M.A.P. sensor.
Jan 22, 2009 | Ford F Cars & Trucks
Bosch T-map Sensor 0281002437 Logo
53 people viewed this question
Top Bosch Kitchen Ranges Experts
William Miller
William Miller
ashburton
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
