Question about Samsung Touch of Color PN50C550G1FXZA 50 in. Television
My Samsung PN50C550G1FXZA plasma tv won't power up.
The red LED stand by light is continuously on and there is no clicking sound when I try to power up.
SOURCE: Samsung TV won't turn on- trying to fix it. A challenging problem
I had the same problem. I live in NJ and called the local authorized "service provide" listed on the Samsung website. What a joke. Quoted $350 just to show up, never showed up. So I opened my own TV. Took off the plastic back (10 screws) took off the large metal RF shield (12-14 screws) and noticed a blown component. The markings on the component were KL15L and it is apparently an NTC Thermistor. Obviously it got fried and not knowing if there was other damage I decided to set out to replace the entire Power PCB Board Assembly and not the component. There were two part numbers on the assembled board (BN97-00457E & BN94-00622E). After searching online I also found a suitable replacement number for these (BN96-04896A). I found two places who claimed to have the part or have it on order (shopjimmy.com and vancebaldwin.com). After placing orders with both and having neither come through, I broadened my search and found out that the LNR409D was basically the same model as my LNR408D so I looked for its Power PCB Board Assembly part number which turned out to be BN41-00521B. Google search for that part number showed the item available on ebay. I bought it a week ago (ebay 260311519904) for $144 plus $12 shipping. I removed the bad board an hour ago (6 screws about 7 connectors) installed the new one, plugged in the connectors, replaced the covers, plugged in the TV... AND IT WORKS!
Suggestion: If your TV is out of warranty then open it up (what have you got to lose) and see if the problem is obvious and maybe something you can fix (replace) yourself. The parts, spare boards, etc. are out there if you look.
Posted on Nov 16, 2008
  • 7 Answers
SOURCE: Samsung LNR408DX/XAA Wont power up
I had the same problem with a 52" Samsung LCD. I found 2 electrolytic caps with bulging tops on the power supply board. (see pic). I looked to be the 5v section but I'm not sure. I got replacement at Fry's for $1.90 each. All is well!
Ahwatukee Al
Posted on Jul 21, 2009
SOURCE: Samsung LN-T4032H
This is the capicator $1.50. You have to take off the back, sauter off the capicator (you'll see it because it is poking out) and sauter on the new one. I found the fix on this web-site.
Posted on Oct 04, 2009
lightnbaby
  • 36 Answers
SOURCE: tv tries to come on but just clicks and clicks.
There are 3 capacitors in power supply board, all 1000uF10v.
2 for 5vdc and 1 for 12vdc. replace with best quality 1000uF 25V cap.
do it yourself repair will save you $300
Posted on Nov 16, 2009
  • 28 Answers
SOURCE: My tv won't turn on, the red light just blinks and
power suppy needs replacing...according to samsung and other forums i read when mine did this its a common problem
Posted on Mar 20, 2010
I've replaced every board on the samsung plasma and still clicks
What do you mean by clicks? Plasma televisions are hot cathode ray, there is thermal expansion that takes place due to heat.
Nov 04, 2016 | Samsung Televison & Video
Philips Magnavox Plasma TV went off.
The red LED merely indicates that power is getting to your TV. There may have been a power supply failure, especially since your TV is a 2008 model
Jun 28, 2013 | Philips Magnavox 42MF521D/37 Television
Samsung plasma won't turn on
Here's is what you need to look for when describing a problem for troubleshooting purposes:
0) What model is the TV (you've covered that)
1) Does the TV respond to command to turn on?
(yes - continue; no - 70% bad power, 30% bad main board)
2) Once it responds (clicks), does a front LED or other indication show that it turns on? It's OK if there's no display.
(that can be model specific and is not certain indication for anything until known what is specific for the model)
3) If such an indication comes up does it remain on until you act or does it go off by itself?
(Stays on - power supply likely good; turns off - power supply *may* be good, but not certain)
4) If the power indication stays on by itself can you make it go off by pressing the power button or do you have to disconnect from AC power?
(responds to power off - 90% power supply likely OK and 90% OK main board; does not respond to power off - 90% bad main board)
Here is a link for test/repair of the power supply of your TV, hope it would help:
http://www.coppelltvrepair.com/p/895/samsung-pn58a550s1fxza-power-supply-repair-service-for-dead-or-clicking-on-and-off-problem
Dec 22, 2012 | Samsung PN58A550S Plasma TV
Won't power on
Sounds like a Zenith or LG TV. It is most probably the Y board, when you hear the clicking sound is usually that. I am sharing this with you because it happened to me with a Zenith (POS). The red light (on my TV) is in the bottom right corner. In my case it was the Y Board. Best of luck
May 14, 2017 | LG 50PA4500 50" 4500 Series Plasma HDTV
50" Philips Plasma 50pfp5332D/37 won't turn on
I have a 42in vizio led with about the same problem i replaced a 75 cent chip # u33 on computer board problem fixed.
Sep 25, 2012 | Philips 50PFP5332 50" 1366 x 768 Plasma...
I have a 2006 LG 42PC3DV Plasma TV and everytime I try and turn it on it makes a double clicking sound and then turn back off..any reason why?
try to test the relay,, or maybe the capcitor, diodes in power source section with your multi tester,, and i think, there is a thermostat beside power that leaks or defective maybe,, then try to change it..
Jul 28, 2012 | LG 42PC3D 42 in. Plasma Television
Samsung plasma tv made a really loud pop and the screen and sound do not work but the red power light won't come off unless the tv is unplugged what happened?
The main power supply regulator board has the fault. Check if any electrolytic capcitor/s has bursted out. Replace them if any. If this do not help you. repalce the board as card basis.
Replacing it as card basis is fine, rather than making 'surgery' to it.
May 28, 2012 | Televison & Video
I have a 42" Samsung
This clacking and clicking noise could have been coming from a capacitor going bad in the tv. If this is the case where the tv will not turn back on, I would suggest calling samsung to try to get a replacement or get the tv serviced. Trying to replace bad capacitors can be a tedious job and requires knowledge of soldering small components. This may also void your warranty if you still have coverage.
Aug 19, 2011 | Samsung PN42A400 42 in. Plasma TV
Samsung Touch of Color PN50C550G1FXZA 50 in. Television Logo
321 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
