Question about Clarion DXZ555MP CD Player
DXZ555MP Problem I need some help with my radio. Ok I was connecting the radio and the positive cable touched the negative and the positive the negative. When i whent to connect it no display . But I touched the eject button and it sounds like ejecting. What could be the problem. I think thewire was the red one. Please can somebody tell whow to fix it
  • 4 more comments
  • Gerry Liossatos
    Gerry Liossatos Jul 01, 2007
    But the eject button works
  • Gerry Liossatos
    No display and no sound but it didnt smell like burned or smoke.
  • Gerry Liossatos
    What cd radio you think is better i will spen like 200 only do you know which are the best?
  • Gerry Liossatos
    I live in Puerto Rico I know how to install the radios. But you dont know a specific model?
  • Gerry Liossatos
    Gerry Liossatos Jul 02, 2007
    Hey I connected it now and it worked. Then I discconected and plug it again and it didnt go on again
  • Gerry Liossatos
    I already found the problem the battery was low of power
    President:
  • 3,130 Answers
I'm sorry to say, but you damaged the radios power supply. You blew out a capacitor or a solid state device. These radios cannot take even an instant reversal of power, as it takes micro seconds to blow something solid state out. This radio, you will probably have to replace. Good Luck
Posted on Jul 01, 2007
  • 2 more comments
  • Larry  Dillon
    Larry Dillon Jul 01, 2007
    but does the rest of the radio? No display. No sound.
  • Larry  Dillon
    It does not have to smell or burn my friend, transistors and IC's can pop in an instant, and without warning. You will need to have this looked at by a pro I'm fraid, unless you know how to trouble shoot solid state printed circuit boards. But like I said before, most of the time these auto radios are not worth repairing. The cost for labor and parts make these radios throw aways.
  • Larry  Dillon
    If you live near an ABC warehouse, or a circuit city, a lot of those stores have Sony, or Pioneer, and JVC and even a lot of them will instal the unit for you as part of the cost of the radio. You should be able to get one for les then 200 bucks
  • Larry  Dillon
    Larry Dillon Jul 02, 2007
    Well thats a good thing. These are things we thought you would have checked already my friend, as you are suppose to check your final installations with the vehicle running!
SOURCE:
Have a delcotron alternator ,what to know where no.1 terminal and no.2terminal wire goes it is on my 1946 cj2a jeep my amp hand does not show a charge had alternator checked out and is ok
  • Use a wrench to remove the negative and positive battery cables: They are clearly labeled "+" and "-." Always remove the negative cable first, as this isolates the power to the metal parts of your car. Tuck the cables away from the battery as you don't want them to accidentally touch a battery terminal when you're wiring your alternator.
  • 3
    Locate the alternator terminals. There are two: one marked "live," "pos" or "+" and the other marked "neg," "field" or "-."
  • 4
    Locate the two cables. The positive (red) cable goes to your battery via a wire loom or harness. The negative (black) cable attaches to a metal part of your car.
  • 5
    Check how the cables attach to the alternator terminals. Some connect using eyelets that hook over the terminal and tighten with a bolt; others connect by inserting the wire under the terminal and tightening a bolt.
  • 6
    Loosen the two bolts using a suitable-sized wrench or, if the cables connect using eyelets, remove the bolts.
  • 7
    Insert the exposed end of the negative (black) cable under the loosened bolt on the negative terminal of the alternator, then tighten the bolt. If the cable has an eyelet, hook it over the terminal and screw the bolt back in place and tighten using a wrench.
  • 8
    Insert the exposed end of the positive (red) cable under the loosened bolt on the positive terminal of the alternator, then tighten the bolt. If the cable has an eyelet, hook it over the terminal and screw the bolt back in place and tighten using a wrench.
  • 9
    Replace the positive battery cable on the positive battery terminal using a wrench. Replace the negative battery cable on the negative battery terminal.
  • May 17, 2011 | Jeep CJ Cars & Trucks
    HOW CAN I UNLOCK THE RADIO ON AN ACURA 3.2 CL TYPE S
    Try this:
    > Disconnect the battery cables: Negative {black} cable first, then Positive{red}.
    > Touch and hold the metal ends of the cables together (hold together so they make constant contact) for at least 30 seconds.
    > Reconnect cables to battery: Positive first, then Negative.
    > Then try entering the code.
    Sometimes the radio will lock (especially if the code has been typed in wrong several times) and this is a way to manually unlock it.
    Jun 04, 2010 | 2001 Acura 3.2CL
    Connect battery cables in 2004 Ford Expedition
    Are you trying to jump it? Or are you replacing the cables entirely? If replacing them, (Read all my instructions for the cautions involved) then unscrew the negative post cable first and then your positive side from your battery. Be careful not to touch them together while your are taking the cables apart. Once the battery is not connected, find the easiest cable to replace first, I think it will be the negative. Do not connect the battery yet!!!!, second the red cable indicating the hot cable will be next. That cable might be longer because on fords, unless I am mistaken should be connected to the starter or on fords an external starter solenoid. Connect that. Once you have replaced both cables, it's time to connect the red cable to the battery. Be careful that the negative side cable is not touching the ground or vehicle because you will see a shocking spark. Once that is connected it's time for the negative side to be connected to the battery black side. The battery has positive indicators (+) and negative indicators (-) may be color coded also + (red) - (black). DO NOT CROSS THEM BECAUSE THE CHARGE MIGHT BE ENOUGH TO BLOW THE BATTERY ( DANGER) I cannot stress this enough. You do not want to be around when a battery blows. They are dangerous. Use caution ok. Don't be that person that goes to the hospital with burns from acid.
    Nov 01, 2009 | 2004 Ford Expedition
    My 1994 lincoln towncar wont start. it started up and i drove it to the gas station to get gas. and when i went to start it it did nothing. whats wrong. the battery was ok.
    There is one small ignition wire that is connected to the solenoid on top of the starter. It slips on and can lose it's connection at any time. Sometimes you can just touch it and it will start working again. The connection needs to be tightened.
    Oct 21, 2009 | 1997 Lincoln Town Car
    My 1994 Jeep Cherpkee Sport will not turn over when I turn the key. All systems are OK. The battery charges and lights and radio are fine. When I turn the key nothing happens. What could be the problem?
    Bad starter or starter Solenoid. Grounded wire between the solenoid and battery or actually a bad battery. I've had batteries that were bad where everything worked until you went to start teh engine then it wouldn't turn over. There are 2 parts to the battery, 1 is voltage which runs the radio, windows, lights and such the other is Amperage which is needed to get the started to work. You can have good voltage but no amperage due to a dead cell. Disconnect the Negative battery terminal, connect jumper cables to a goo running vehicle, connect the positive cable to teh positive terminal and the negative clamp to the negative cable, this take your battery out of the loop, then try and start the vehicle. If the vehicle starts it's your battery if it doesn't then it is most likely your starter or Solenoid.
    Sep 09, 2009 | 1994 Jeep Cherokee
    Elecrtial problem
    Sounds like a newer 5 series. The SZL module located in the steering column has failed. Most common indication of this failure is the wipers being stuck on. Unit will need to be coded by a professional. Just for fun you can try a memory dump: remove negative battery cable and then positive battery cable and touch them together for 30 minutes then reconnect everything and hope for the best. If the cables are too short to reach each other slide a screwdriver in through the negative opening and into the positive opening. MAKE SURE NEGATIVE CABLE DOESN'T TOUCH THE POSITIVE CABLE WHILE IT IS CONNECTED TO THE VEHICLE.
    Jun 19, 2009 | 2002 BMW 5 Series
    Replacing the battery in a 1999 Lexus LX470
    There are a few thing's, one thing is to not accidentally touch the positive terminal with the negative battery cable or touch the negative terminal with the positive battery cable when your removing or installing the battery, if one of the cable's do touch the other post it may blow some fuse's, on some vehicles with radio anti theft systems when you remove the battery the radio will lock out, if you don't have the code you'll have to take it to a service dealer to have them reset it, other than that it's pretty much straight forward. good luck.
    Apr 02, 2009 | 1999 Lexus LX470
    Clock setting for Clarion DXZ555MP Radio / CD Player.
    Just go to the website and click on the 'download manual' link on the right side. Here is the page on Clarion USA, for your cd player.
    http://www.clarion.com/us/en/products/2005/audio/source_units/cd/DXZ555MP/us-en-product-pf_1133851137392.html
    There you can download your owners or installation manual in PDF for free. Nice to deal with a company like them isn't it?
    Sep 29, 2008 | Clarion DXZ555MP CD Player
    Clarion DXZ555MP CD Player Logo
    137 people viewed this question
    Top Clarion Car Audio & Video Experts
    xxxxxx xxx
    Marvin
    Marvin
    Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
