Question about JVC SR-VS30 Mini DV/S-VHS VCR
When I play a miniDV on the SR-VS30 a counter appears on the screen showing minutes;seconds;frames. Is there a setting I need in order to remove this image from the screen. When I play a VCR on this machine no counter appears. I do not have a manual available, Suggestions please! I do not have a manual
  • JVC Master
  • 5,390 Answers
Try the JVC website they might have a free PDF of the manual, which could also help you solve any possible future problems.
Posted on Jan 14, 2013
2 Suggested Answers
  • 979 Answers
SOURCE: Playback Problems using Firewire port
Is the power from both units being supplied from the wall outlet? If so, it is possible to accidently create what is known as a "ground loop" condition. The easiest way to induce this unwanted condition is to connect one unit to an outlet on one wall, and then connect the other unit to a whole different outlet. Always connect units to the same mains connection to help prevent this...Accordianman
Posted on Oct 11, 2007
Chotto shot for psp
HERE ARE THE INSTRUCTIONS TRANSLATED AS FOR YOU
VPhoto Settings:
First Row:
The first square is for frame (on or off). When you turn the frame feature on, you can only take pictures in 480 x 272 resolutions (according to the manual). When you’re in the picture preview mode, press triangle button to preview frame. After that, use left and right buttons on the D-pad to select different types of frames, use up and down buttons to select different categories of frames.
The second square is Dog Watch mode. When you’re in preview mode, press the R button to start the sound detection. The camera will start taking snap-shots when there is some loud sound (not movement) and save it onto the memory stick. To stop press the X button (button configuration might be different if you have a US PSP).
The third one is for timer (10 sec, 15 sec, 30 sec, 60 sec and the last one is off). When you’re in preview mode, press the R button to start the count-down.
The fourth square is for timer sound (on or off).
The fifth square is for camera’s sensitivities (on or off).
Second Row:
Shutter sound (normal, gun shot, inspiration, melody & kung-fu!).
On-screen help (on or off).
On-screen robot named Ijiro that give your hints (on or off).
Date stamp (on or off).
Resolution when taken pictures "with" Chotto Shot software (640 x 480 or 480 x 272 only). Without the Chotto Shot software, more resolutions are available.
After you finish with all the settings, move the cursor to the last single square on the botton to save your settings.
Video Settings:
First Row:
The first square is for automatic rapid shots settings (on or off). If you select on then you'll have the options of 0.5 sec, 1 sec, 10 sec, 30 sec & off.
The second square is manual rapid shots settings (on or off). If you select on then you'll have the options of 450 frames, 90 frames, 15 frames, 4 frames & off.
The third square is again, for camera's sensitivities (this time it's for video).
Second Row:
Again, don't forget to save your settings by selecting the last single square on the bottom of the screen.
Slide Show:
ALL (all the videos and photos)
VIDEO (just the videos)
PHOTO (just the photos)
GROUP (you specify the group yourself and it can be just videos only, pictures only or both).
When you select any of the above you should get these options (below):
First Row:
Display details on screen (on or off).
On-screen progress bar (on or off).
Loop the slide show (on or off).
Second Row:
Fade options (slide, fade, rotation, random & off).
Background music or BGM (on or off and also you can specify what kind --> parade, bossanova, miyabi & off).
Slide show orders (by name, by date or random).
Time between each slide (5 sec, 15 sec, 1 min, 10 min or manually by pressing the circle button or the D-pad).
Display calendar on the screen (on or off).
Again, don't forget to save your settings by selecting the last single square on the bottom of the screen. After you save the settings, the slide show will commence.
To control the slide show while it's playing:
D-pad left button - if the video is playing then it will pause and if you press it again, it will rewind to the beginning of the clip.
D-pad right button - to advance to the next video or photo.
Circle button - if the video is playing then it will pause (same as the D-pad left button) but if you press it again, it will resume playing. When the photo is playing (as the slide show), it will advance to the next photo.
L shoulder button - if the calender option is selected, it will display the previous month.
R shoulder button - again, if the calender option is selected, it will display the next month.
Select button - when you press it, it will go to options.
Start button - when you press it, it will go to the main menu.
Album:
First, click on Album and then you should see 4 different tabs (All, Group, Video & Photo). Use L or R button to switch between each tab. Notice the bottom of the screen are menu selection for this page:
Select - Settings.
Start - Go back to main menu.
Circle button - Play.
Square button - Multiple selection (of the thumbnails).
Triangle button - Edit or delete.
X button - Deselect all (of thumbnails).
Settings:
On-screen help - On or off.
Video looping - On or off.
On-screen progress bar - On or off.
Well, that's it for now. Sorry I don't have any pictures to accompany the translation. When I have more time, I will update this thread with more translation from manual. Hope this at least helps some of you to get started.
Update:
Well, since the GoEdit has been released in Europe, you can just go and download the software (which is in English) from here. Make sure to follow the instruction (correct folder name, etc and also it requires firmware 3.40 and above). Good luck and if you have any question please feel free to pm me.
Jan 12, 2008 | Sony PlayStation Portable (PSP) Console
How to find out lamphour in PLC-XT11
hi
do the follwing setting on your projector to reset the lamp hour
1.Turn projector on, press MENU button and ON-SCREEN MENU will appear. Press POINT LEFT/RIGHT button to move a red frame pointer to SETTING Menu icon
2 Press POINT DOWN button to move a red frame pointer to "Lamp counter reset" and then press SELECT button. The message "Lamp replace counter reset?" is displayed. Move
the pointer to [Yes] and then press SELECT button.
3.Another confirmation dialog box appears and select [Yes] to reset Lamp Replace Counter.
ok
Feb 02, 2011 | Sanyo PLC-XT11 Multimedia Projector
I am trying to set my Sanyo picture right side up. what setting do I go to?
Check Ceiling feature.
Press MENU button and ON-SCREEN MENU will appear. Press
POINT LEFT/RIGHT button(s) to move a red-frame pointer to
SETTING icon.
Language used in ON-SCREEN MENU is selectable from among
English, German, French, Italian, Spanish, Portuguese, Dutch,
Swedish, Russian, Chinese, Korean and Japanese.
Display
This function decides whether to display On-Screen Displays.
On ··· shows all On-Screen Displays.
Off ···· sets On-Screen Displays disappeared except;
? ON-SCREEN MENU
? "Power off?" message
? "No signal" message
? "Please wait...."
? P-Timer counter
Set a red frame pointer to item and press SELECT button.
Press POINT DOWN button to move a red-frame pointer to item
that you want to set and then press SELECT button. Se ting
dialog box appears.
Dec 11, 2010 | Sanyo PLC-XF46N LCD Projector
Can i tell the age of JVC unit by it's serial number
Yes can you tell me what the ser. # is. I will give you year
Oct 22, 2009 | JVC SR-VS30 Mini DV/S-VHS VCR
Can the Panasonic AG-DV2500 play 90 minutes Minidv tapes?
the DV2500 will not play LP (90 minute) tapes. when an LP tape is inserted, it will play for 2-3 seconds, and then eject.
Nov 28, 2008 | Panasonic AG-DV2500 DV/Mini DV VCR
ILink
my computer not recognize is DV recorder for Windows Vista.
I need drivers.
Tanks
Vagner - Brazil
Dec 14, 2007 | JVC SR-VS30 Mini DV/S-VHS VCR
Video won't show up on comp monitor
check your inputs on that machine. there are settings that you need to do. when you put a tape in the minidv, does it play fine? if it does, you need to check your input setting on that machine..good luck
Apr 03, 2007 | Panasonic AG-DV2000 Mini DV VCR
JVC SR-VS30 Mini DV/S-VHS VCR Logo
82 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
