Question about Samsung RS2534 Side by Side Refrigerator
The refrigerator icemaker does not make ice.
We replaced the water filter because it froze and broke. Now the filter light will not go out and the ice maker will not make ice. Is ther a reset for this?
  • Anonymous Mar 14, 2014
    The ice maker is not making ice?
  • Anonymous Mar 17, 2014
    The icemaker stopped working. Won't make any ice. Have tried everything. There is no "switch". We have had this fridge one year and the ice maker has been a constant issue. More issues surface when we change the filter. Every time we change the filter the ice maker seems to "go to sleep" and this time we can't wake it up!
  • 700 Answers
You have to hold in the ice type and the childlock button for about 6 seconds and that will take the filter light off. To reset the ice maker open the freezer door and then pull out the ice bin. on the bottom of the ice maker theres a button that you have to hold in to reset the ice maker. Good luck and thanks for using FixYa
Posted on Jan 21, 2009
  • singbeckster
    singbeckster Sep 30, 2012
    Thanks sooo much! Worked for us!
Icemaker issues
If your ice maker still in guarantee or warranty period, then go to the seller and replace with a new one. If not then go to google and type in ice maker repairer in your area and you will find plenty of website of repairer.
Mar 15, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
Samsung refrig model rf26xaebp stopped making ice but i still bet water thru the door
The solonoid valve for the ice maker may be faulty or the icemaker may be froze up. Try thawing out the icemaker with a hair dryer. If thats doesn't fix the problem you may have to replace the soloniod or ice maker control. Be sure the arm above thre the ice bin is in the down position. Hope this helps.
Dec 30, 2013 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Ice maker not getting water to it, I recently replaced the copper line from the wall to the refrig with a flexible stainless steel. The refrig stayed disconnected for a week before replacement now I...
Hello DeWayne,
That hose that connects to where the water comes out as it cycles,the end of it where it goes to the top and enters into the freezer/icemaker is frozen and needs to be removed and thawed,you could take that hose off at the water valve and blow through it if you can not blow through it easily its defiently froze,if once you thaw it it becomes froze again within a couple days up to a couple weeks the water valve where that hose connects to at the bottom is bad and causing it to freeze and that valve should be replaced.
I hope this will help you to get your icemaker working,
Gene
Aug 08, 2011 | Frigidaire FRS3R5EMB Side by Side...
New unit never used found the water filter cracked
THE FILTER HOUSING MAY HAVE FROZE AND BROKE. MAY HAVE FROZE ON TIME IN SHIPPING. CALL ELECTROLUX THEY WILL SEND YOU THE PART AND A TECHNICIAN TO FIX IT. SO IT COULD BE REPAIRED IN ONE TRIP.
Apr 24, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
ICEMAKER /WATER
The line in the back of the freezer section is froze up. Remove the ice-maker and use a heat gun or hair dryer to thaw. be careful not to put the heat gun or dryer to close. It wont take long to thaw. BB
Dec 15, 2009 | GE Refrigerators
GE PROFILE PTS22LHPARWW ICEMAKER NOT WORKINNG
change or remove filter
change control valve
change valve on copper water ine
change copper water line
check input pressure to unit
25? 25? anybody know what is the minimum water pressure supposed to be entering the refrigerator icemaker?
Oct 23, 2009 | GE Refrigerators
Icemaker on Hotpoint Model HSS25GFPAWW Refrigerator not working
try turning the temperature for the freezer down a little bit. it has to at least be around 17 degrees before the older ice makers start to work.
Jan 20, 2009 | Hotpoint HSS25GFP Side by Side...
Side by side refrigerator icemaker not making ice. Hotpoint mdl HSS125IFMD Tried installing new filter. Getting water but no ice being made.
I would first try replacing the solenoid valve which lets the water in. Also, how are the ice cube arms aligned? They should be vertical
Jul 04, 2008 | Refrigerators
KENMORE ICE MAKER STOPPED WORKING
MAKE SURE THE ICEMAKER IS ON,ON OFF BUTTON OR LEVER IN DOWN POSITION,CHECK TUBE BEHIND ICE MAKER PULL IT OUT LOOK IN IT LOOK IN FREEZER HOLE TO MAKE SURE IT'S NOT FROZE UP,CHECK WATER INLET VALVE ON LOWER BACK OF FRIG.,LOOSEN CONNECTION TO SEE IF GETTING WATER,IF WATER IS COMING OUT IT IS A BAD WATER VALVE ONLY ONE SIDE TO WATER DISPENSER IS WORKING,VALVE IS NOT OPENIBG TO ICEMAKER SIDE,THANKS-MIKE
May 29, 2008 | Kenmore 53642 / 53644 Side by Side...
Icemaker isn't making any ice
Your fill tube that fills the Icemaker could be froze up, The plastic tube that goes into the icemaker. Sometimes they get froze shut. You can remove it from the back of the fridge, just pull it out from the back and take a look. If that doesn't work, Let me know.
Bill
Apr 28, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung RS2534 Side by Side Refrigerator Logo
2,142 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
