Question about Frigidaire FDE336RE Dryer
Fridgedaire drying- It's screeching!
I have a Fridgedaire, model FDE336RES2. It's probably about 8 years old and has just this past month started schreeching when it dries. It still appears to be drying normally, but the screeching is gradually getting worse. Our dryer's always been warm/hot on the top and back while drying, that's nothing new, so it really just seems to be the screeching noise that's "new." I tried going on to the Fridgedaire site, looking at troubleshooting, but this is not something that was addressed. Help?
  • 3 more comments
  • Anonymous Nov 24, 2007
    dryer drum squeaks
  • smallow Jan 16, 2008
    I have the frigedaire FDE336RES1. It is approx. 8 yrs. old and the problem is that it screeches while in use. It starts out really loud and then eventually fades away through the middle of the cycle. The back of the dryer however gets really, really hot to the touch and is starting to leave a burnt brown mark on the outside casing of the dryer.
  • Anonymous Feb 11, 2008
    makes loud screeching noises
  • Tiffany Bray Nov 02, 2008
    WE HAD THE SAME PROBLEM AND DISASSEMBLED THE ENTIRE DRYER. WE PUT HEAVY GREASE ON THE MOUNT AND THE SQUEEKING STOPPED. BUT NOW WE DON'T KNOW WHERE OUR LITTLE YELLOW PLASICE PIECES GO. OOPS! THAT IS WHAT I AM LOOKING FOR NOW. BUT RAN ACROSS THIS. JUST GREASE IT!
  • audreylynne Feb 20, 2009
    my dryer started doing the same thing until yesterday. it started on fire! piece of junk.
  • 5,911 Answers
There are several things that will make a dryer noisy. Here's a list of a few items that I know of. Some may or may not apply to your dryer: FIRST OF ALL, BEFORE SERVICING THE INSIDE OF ANY DRYER UNPLUG THE UNIT OR TURN THE CIRCUIT BREAKER OFF. 1. Drum rollers worn out. Most dryers have some sort of drum roller that supports the dryer drum. There are two mounted under the drum in the rear of the dryer. Some models will have an additional set of drum rollers under the front of the drum as well. You may also here the drum thumping too. Lubricating them with a good quality turbine oil at the point of the spin shaft will get rid of any squeaks or squeals. DO NOT oil the roller wheel as it will slip on the drum. 2. Dryer drum seal. This is a felt gasket or seal that is glued to the rear ring of the drum. When they get old they become brittle and pieces start to break off leaving bare metal scraping against bare metal. They also can become folded and part of it will be seen poking through the back of the drum inside. This seal should ride evenly around the outside perimeter of the drum and should not be seen inside the drum. 3. Dryer drum support glides. Some dryer models have teflon plastic support glides mounting around the ring of the front of the tub, or will have teflon supports mounted under the front of the drum. In either case, if the plastic gets too worn down, the dryer will start to make a scraping noise. 4. Idler pulley. This is a little pulley that provides tension on the dryer drive belt. It is located near the drive motor and can start to make noise. Usually a little bit of lubrication at the point of the spin shaft will get rid of the problem. 5. Dryer drive motor. Sometimes when the drive motor gets a nice collection of dust build up around it, the motor will make noise as the impeller rubs against dust or any other debris caught. A stiff cleaning brush and a vacuum cleaner will help get rid of dust accumulation around the motor. Now, there is a possibility that the bearings in the motor could be going bad too. You would need to remove the drive belt and check to make sure the motor free spins with no power applied. Give the motor shaft a spin. It should glide free with no noise. 6. Dryer drive belt. When the belt gets old it will develop a "glaze" on it and start to slip around the drum. This can causing a squealing noise, especially under heavier loads. This is usually a prelude to the belt breaking. Start with the easy and simple options first. Try lubricating any drum rollers or pulley rollers. DO NOT get oil on the drive belt. Lubricate the rollers at the point of the spin shaft only. Inspect the front and rear of the drum. The seal will be in the rear. Make sure that it is intact and good condition, and make sure it has not folded inside the drum. Also, check for glide supports around the front of the drum and make sure there are not areas that are worn down. Another thing that COULD cause noise, but may not be associated to the problem you are having, are foreign objects getting lodged between the dryer drum and casing. Screws, paper clips, nails, etc., have been known to get caught in these areas and will make some awful noise. If you try everything and the unit still makes noise the drive motor bearings could be going bad. This is usually not likely and the motor can be very expensive to replace. Last of all, some heat on the top and rear of the dryer are normal. However, if it is excessive (you can't place your hand on it and hold it there), you probably need to give the inside casing a good cleaning. This could be a sign that your dryer ducting has become clogged and the unit is actually overheating trying to fight for air. Ask yourself, "Are my clothes taking a longer time to dry?" If the answer is "yes" then you need to clean the unit out and check the entire length of the ducting to ensure it is blowing air out of the vent. Remember also, the shorter and straighter the ducting run, the better. Any sharp bends or kinks (behind the dryer) will cause lint to back up. I hope you find this advice helpful. Good luck and let me know if I can help further.
Posted on Jul 01, 2007
Model 69822 is less than 8 years old. Screeches loudly for about a minute on startup. Runs fine after that and dries the clothes.
The screeching is probably a slipping belt. This can be caused by"
1. Glazed or worn out belt.
2. Improper belt tension.
3. Overloaded dryer
4. Bad drum bearing
If it is used heavily (often), I would assume #1 which is the cheapest and quickest fix. You can investigate #2 at the time of replacement.
Jan 26, 2016 | Kenmore Dryers
"Infinity 20" probably 8yrs old now. Recently started making a humming noise whilst in use. The noise continues 15secs or so after hot water tap has been turned off.
Sounds like the diaphram in the gas control valve which is not replacable. You would have to replace the gas control valve and I would also suggest replacing the thermocouple. However since the heater is 8 years old you may think about replacing the entire hot water heater. Depending on how much water has gone through it in these past 8 years it will probably rust out soon and then you will be dealing with a flood.
Good luck,
Marty
Nov 08, 2013 | Rinnai Water Heaters
My holmes air purifier makes a screeching sound
If you can access the fan, spray lubricant onto the shaft as close to the fan body as possible. It will work it's way into the bearing
Apr 14, 2012 | Holmes Products Air Purifiers
My 8 month old magic chef wine cooler model #MCWC45A Serial #0902MCWC45A0720 just went dead. It just got silent, no sound and no interior light. I have tested the outlet and it is ok. i tried connecting to...
If it is 8 months old it probably is under warranty call magic chef they will usually send someone out. Have your purchase stub ready or they can go by the manufacture date but that might be over a year.
Apr 15, 2011 | Magic Chef MCWC45A Wine Cooler
I have a 5 year old Jura Capresso F9. It has given me Malfunction 8 a number of times over last few months, but have always gotten past it. The other night, the machine was off but plugged in. It came...
This could be a problem with the main control board or CPU. It could be that there is moisture after getting onto it and causing the fault which may only need to be dried off. Otherwise the machine may need a new board. If main board is 5 years old, its probably had its day.
Mar 29, 2011 | Jura Capresso Impressa F9 Espresso Machine
Dryer squeaking really loudly when drum turns. Heats though! Model FDE336RES2
its the plastic piece the drum roller rides in behind the drum in the center of the rear wall it wears down the plastic to the metal and starts screeching the drum either pops up and out of it or theres 3 philip head screws in the rear of the drum
Nov 06, 2010 | Frigidaire FDE336RE Dryer
Stopped running. Can't start.
You probably have a clogged vent. If the moist air can't vent to outside your dry times would be much longer and the heat would get trapped in the dryer. This probably caused your thermal fuse to fail. Once that fails the dryer won't do anything. The good news is that it should be a fairly inexpensive repair.
Dec 09, 2009 | Dryers
I've got a fridgedaire gallery gas dryer, approx 8 years old. Takes too long to dry clothes. I've cleaned inside as best I could and the dryer duct. Is seems to get hot some of the time, but not constant
if you use fabric softener. i recommend you slow it down...alot. an appliance guys nightmare is just that. inside fabric softener, is wax. your lint screen may look clean. but run it under hot water. ive come across many a lint screen where the water will simply not go through the screen, even though it appears to be sparkly clean.
Sep 29, 2009 | Frigidaire FGQ332ES Gas Dryer
Drum came loose on Fridgedaire front loader on final spin cycle.
What was the point of posting this on the site?
The drum has broken loose from the support plate at the rear
You need a new drum and a support plate plus probably an outer shell.
A complaint to the manufacturer may get you a deal on a replacement
Jun 04, 2009 | Frigidaire ATF6000ES Front Load Washer
Dryers Logo
4,066 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
