Question about Camping, Backpacking & Hiking
Mattress pad controll not operating
Shows no life ( no lights no nothing ) This is new but was not opened for 2 or 3 years . Fuse inside controller good. What is most likely the cause, capacitors? what to check? Guy with a solder gun.
SOURCE: the controller on my heated mattress pad blinks
I had same problem. Make sure plug is all the way in and locked.
Posted on Nov 25, 2008
SOURCE: Cruise control NOT WORKING
Check your rear brake peddle and see if the sensor for the cruise control is out of adjustment. I had the ame problem on my 1990 GL1500.
Posted on May 29, 2009
  • 4 Answers
SOURCE: HUD will not light up
If you peek down inside the windshield, you'll probably see the HUD is working. A common issue is that the adjustment spring will break, making the HUD invisible because it is adjusted out of range. The spring can be replaced by removing the cluster then the HUD unit.
Posted on Aug 31, 2009
SOURCE: new heated mattress pad won't warm up. Controls keep blinking.
i've lost my control for a king size electric blanket. it had dual control-can u tell me where i can get one and the cost. thx
Posted on Nov 28, 2009
SOURCE: 2007 Saturn Aura. Cruise control quit working.
I just had the same problem,also door locks would not engage when shifted out of park. Had problem for a week now all is ok didnt do anything
Posted on Apr 08, 2010
Why does my heated mattress pad read "error"?
Hi, I think that Your mattress pad possibly low quality or it was error by manufacturing company. They couldn't maintain proper quality. So this mattress pad may harmful for you health. You may get new best quality mattress pad. Also I think this website www.bestmattresslist.com may help you. Best Mattress Topper Archives BestMattressList
Oct 09, 2016 | Sealy Heated Full Size Mattress Pad - -
I am looking for a replacement for 1 of the controls for my heated mattress pad. Where can I find 1?
www.sunbeam.com/.../bedding/controls/bedding-contr...
Sunbeam ProductsHow do dual controls work? The dual ... What if my control does not regulate my side of the warming product? ... Where can I purchase replacement controls?
Finding Replacement Cords and Controls for an Electric ...
www.thriftyfun.com/Finding-Replacement-Cords-and-Controls-for-an-El...
... blanket. Finding a replacement cord or a control for an electric blanket can be difficult. ... My blanket was under warranty and I got one for free. If yours is out of ...
Finding Replacement Controls for a Heated Mattress Pad ...
www.thriftyfun.com/Finding-Replacement-Controls-for-a-Heated-Mattre...
This is a guide about finding replacement controls for a heated mattress pad. It can be very frustrating to find replacement ... Read all 1 Answer ... Where can I findreplacement controllers for my Living Quarters heated mattress pad? By Steve.
Replacement Controls for a Sealy Electric Blanket ' ThriftyFun
Dec 07, 2015 | Sealy Heated Queen Size Mattress Pad - -
Have a model 2150 heated mattress pad, one year old, with dual controls. One control is blinking and won't heat up the pad. I have unplugged twice and checked the plugs into the pad itself,
Hi
First, I am not familiar with your particular Pad. But they all work in a similar fashion. Second... you would be wiser taking your pad to an electrician if you are not competent with electricity. (Especially 240V AC where I am.)
If it's only 120v AC then the sting is not as bad. I've had Both!
The Pad is not worth your life.
That said....
Obviously the AC power is OFF & disconnected first.
Use a multimeter in Ohms or Beeper Mode to look for an open circuit in the element(s) inside the blanket.
If the pad connector comes to the edge somewhere then this is where to test the pins. No AC Power Needed.
On Ohms mode it should show some small resistance in the element. Thats why it heats up....
If the element is internally broken (open circuit) then I doubt it can be repaired.
A multimeter can be a useful tool in a modern house these days.
They can be picked up pretty cheap now. $10 to $50.
The probes can check for AC & DC voltages.
The current function would never be used by the average person.
The Beeper Test uses the internal battery for open & closed circuit testing. The Ohms function will show the resistance of elements and the like.
If you are unsure how to use one then ask the supplier or an electrician / technician to show you.
Cheers
Nov 20, 2014 | Dishwashers
Why has my heated mattress pad stopped working?
Electronics fail. Sounds like the digital controller has failed. A Google search finds others with the same problem. Biddeford models come with a 5-year warranty, so if yours is less than 5 years old, I suggest you contact Biddeford by telephone: 800.789.6441 or visit their website: http://www.biddefordblankets.com/warranty.asp
Sep 15, 2014 | Biddeford Blankets Heated Mattress Pad...
Controller on a heated matress pad shows a backward 3 does not warm up
that heated mattress pad needs to be safety tested by an electrician
faulty thermostat or internal heating wires
or the actual controller
Mar 02, 2014 | Furniture
Electric blanket won't heat
Take the help of your mattress pad company or look into instruction manual. Do not operate it unless you are familiar with it. You should call the customer care to know how to operate.
Jack from Coriumdirect Mattress pads
Apr 07, 2013 | Biddeford Blankets Heated Mattress Pad...
Mattress pad not heating up
There must be a problem with wiring. You must contact with the manufacturing company or some electrician to go through the control box. Do not try to deal with it by yourself as it may cause damage.
Jack
Jan 26, 2013 | Canon Cannon Quilted Heated Mattress Pad
Mattress pad 1/2 not heating. (K85KQP)
It is sure to be a problem with the controller.
If you can open the controller up, you can compare the good controller on the side that operates to find the problem with the bad side.
If you have a multimeter, you can surely fix the problem.
Check for output where the wire comes out of the controller if you can get inside of the controller.
It may be that the cord is bad.
That is the most abused part, because it is continually being moved and bent.
Feb 09, 2008 | Heating & Cooling
Camping, Backpacking & Hiking Logo
71 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
weirdtop
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
