Question about Packard Bell Computers & Internet
Volume 100 message on screen
Message in centre of monitor can't be cleared. I think it is a F key to turn off, any advice would be appreciated. Thank you.
  • Packard Bell Master
  • 7,627 Answers
Reboot.
Posted on Jan 10, 2013
Nerdy_geek
  • 94 Answers
SOURCE: Changed screen resolution. Now
try to boot on safe mode, by pressing f8 while booting then choose safe mode,
while in safe mode you can set the resolution back to its default .
Posted on Sep 11, 2008
Sameeraryan
  • 82 Answers
SOURCE: monitor fault
Try removing the RAM from the motherboard & fix it again...... if this will help you u might not need to go service center.......or check the dispaly cable which is connected to your CPU........hope thjis will help u...............Sameerrayan
Posted on Jan 14, 2009
ethan859
  • 19 Answers
SOURCE: Computer will not turn on. " in power save mode"
If mbase213's solution doesn't work, try the solution I've found in another forum. Read through the whole thread.
http://en.kioskea.net/forum/affich-46233-can-t-exit-power-saving-mode
Posted on Nov 09, 2009
Testimonial: "Thank You."
alokeanand
  • 40 Answers
SOURCE: I have a Packard Bell touch screen computer and when I try to open several programs the computer freezes with the message 'Program has stopped working' Any assistance with this problem would b
Some programs need a substantial amount of RAM and in case of computers with smaller RAM, they tend to freeze. Either close some of the running programs or increase the RAM capacity. In every likelihood it should work.
Posted on Apr 01, 2012
  • 1288 Answers
SOURCE: I have HCL Ezeebee desktop computer when we boot the system monitor, keyboard, mouse blink for a while and monitor (HCL) show 'no signal' message, and keyboard num lock led not display mouse i
No signal at the monitor indicates (if you know the monitor is working ok) a failure of the graphics chip or graphics card, The lack of indicator light on the num lock LED and the lack of power to the mouse would indicate that there is a major issue with the motherboard.
you can try using another monitor to confirm the problem lies with the graphics, and in the case of the keyboard and mouse, swap them for a usb version, if they work, the Ps2 ports are probably damaged.
I'd be thinking of replacing the motherboard
Posted on May 19, 2012
My phone will not turn on it keeps giving a warning message .... press volume up key to run custom os or volume down key to cancel. I pressed down and it still wont turn on
Take your mobile to nearest authentic mobile service & repair shop and get replace volume switches.
It will work 100%.
Jul 20, 2016 | Cell Phones
Get rid of dead robot
try clearing your cache partition, you can get to the android recovery with your buttons.
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Jan 21, 2015 | Tablets & eReaders
System startup
Below the event message it should be also display"time" and "clear"on the screen. There are two corisponding soft keys below the two words. Press the clear key to erase the message from your display.
Feb 19, 2012 | NorStar T7316E Corded Phone
How to set up Panasonic Answering Machine KX-TG4391
Recording your greeting message You can record your own greeting message (2 minutes max.). 1 {GREETING REC} 2 Within 10 seconds, press {GREETING REC} again. 3 After the base unit beeps, speak clearly about 20 cm away from the MIC. 4 Press {?} (STOP) to stop recording.
Playing back the greeting message Press {GREETING CHECK}.
You can also operate the answering system by pressing dial keys on the handset
Key Operation {^} or {V} Adjust the receiver/speaker volume {1} or {<} Repeat message (during playback)*1 {2} or {>} Skip message (during playback) {4} Play new messages {5} Play all messages {8} Turn answering system on {9} Stop playback*2
Oct 17, 2010 | Panasonic DECT 6.0 Expandable Cordless...
A volume controle massage in the centre of my screen that I can not remove.
This particular Acer monitor has no speakers and the volume message is not comming from the monitor its comming from the computer.
Could you please prove this issue by connecting the monitor to another pc and see if some sort of menu display happens again?
Let me know your results
Mar 07, 2010 | Acer AL1916W 19" LCD Monitor
How do i shut off my change oil light in my h3
I'm not 100% on this but I think it's like a lot of GM's; turn the key to the "on" position(not running), stomp the gas pedal to the floor 3 times within 5 seconds & the light should flash & go out.
Sep 24, 2009 | 2006 Hummer H3
At the centre of my viewsonic monitor model:E70fB a message in blue coloured box that"osd lock"and its blinking continously its irritating me
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This might unlock your OSD menu and remove that message from your screen. regards
May 14, 2009 | ViewSonic E70fb 17" CRT Monitor
I am using view sonic monitor & i am facing a problem with it .At the centre of the screen there is a message in blue colour filled box that"osd lock"its irritating
OSD and Power Lock Settings
• OSD Lock: Press and hold [1] and the up arrow 􀁓 for 10 seconds. If any buttons are
pressed the message OSD Locked will display for 5 seconds.
• OSD Unlock: Press and hold [1] and the up arrow 􀁓 again for 10 seconds.
• Power Button Lock: Press and hold [1] and the down arrow 􀁔 for 10 seconds. If the
power button is pressed the message Power Button Locked will display for 5 seconds. With
or without this setting, after a power failure, your LCD display’s power will automatically
turn ON when power is restored.
• Power Button Unlock: Press and hold [1] and the down arrow 􀁔 again for 10 seconds.
Well this Should resolve ur issue
May 13, 2009 | ViewSonic E70fb 17" CRT Monitor
MY HP 1740 FLAT SCREEN MONITOR IS SHOWING A OSD LOCKOUT WARNING
Might be this...
For an OSD Lockout message, press and hold the Menu button for 10 seconds.
For a Power Button Lockout message, press and hold the Power button for 10 seconds.
http://h200003.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=3648453&prodTypeId=382087&objectID=c01508108
But then this post says he had to hold it down for 25-30 seconds...
http://h30434.www3.hp.com/psg/board/message?message.uid=59866
Mar 17, 2009 | HP Computers & Internet
Text message tone volume, LG KP500, Cookie
Go to Profiles, and choose a Customized Profile. Rename it to whatever you prefer. In this profile you can select your ring tone, message tone, volume, etc. I only had to do this once, and everything worked perfectly!
Feb 11, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Computers & Internet Logo
52 people viewed this question
Top Packard Bell Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Tony
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
