Question about Panasonic CS-S9NKUA Ductless Mini Split Wal Cool Air Conditioner
REMOTE CONTROL Panasonic CS-S9NKUA 9,000 BTU A7503710
3 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: How do I change the battery in the remote control
slide the cover of the remote up higher. It is hiding the batteries.
Posted on Nov 26, 2009
SOURCE: Panasonic CS-W24DKR/CU-W24DKR not responding to remote control
to easily test remote,turn mobile phone camera on and operate remote with infe red end looking at phone camera,if remote is working you will see a white light on camera,if u get a light on camera reciever in wall unit may be faulty.
alan @zia airconditioning.
good luck
Posted on Dec 28, 2011
Can a Fujitsu compressor unit be connected to multiple inside evaporator units that have different tonnage ratings. 18,000 BTU compressor and 9,000 & 12,000 BTU evaporator units inside.
call fujitsu engineering division direct and ask them about what is connected and if it works ok
logically as each evaporator has it's own tx valve as long as the compressor is large enough to run all together it should work but get the right information from the fujitsu experts
Oct 11, 2016 | Fujitsu Heating & Cooling
Remote will not communicate with wall unit
try repacing batteries-or/and turn off high voltage to system waite 5 minutes -turn back on---if this doesn't work call an hvac contractor or go on line for troubleshooting advice
Oct 13, 2015 | Sanyo 09KHS71 9,000 BTU Single Zone...
Panasonic mini split air conditioner css9nkua error code h99 what does it mean
12.11 Freeze Prevention Control 2
• Control start conditions
o During Cooling operation and soft dry operation ? During thermo OFF condition, indoor intake temperature is less than 50°F or ? Compressor stops for freeze prevention control
o Either one of the conditions above occurs 5 times in 60 minutes. • Control contents
o Operation stops
o Timer LED blinks and "H99" indicated
You may need the assistance of a technician. Service manual located here:
http://www.mcaair.com/docs/panasonicac/CS9NKUA%20CS12NKUA%20Service%20Manual.pdf
Apr 29, 2015 | Panasonic CS-S9NKUA Ductless Mini Split...
Panasonic mini split air conditioner css9nkua. what does run code h99 mean?
H99: Indoor heat exchanger anti-freezing protection
Causes: - Insufficient refrigerant;
- Air filter dirty;
- Clogged cross flow fan.
How can ice be removed from the back of the outside component ?
The ice should shed during a normal defrost cycle. If you have extreme ice build up, you may have a problem with the defrost sensor or the defrost controller or you could be low in freeon.
Dec 24, 2014 | Sanyo 09KHS71 9,000 BTU Single Zone...
Panasonic CS-A12DKD Air conditioner does not
This could be an inoperative reversing valve or bad reversing valve solenoid coil.
Oct 31, 2013 | Panasonic Heating & Cooling
What does E1 stand for in a window air conditioner unit - Haier brand
Here is a tip that gives a further explanation of that E-1 code. The causes ofthe E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening withyour window air conditioning unit and give you some things to try to help youget your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
Sep 27, 2010 | Haier Portable Air Conditioner, Electronic...
Remote is not working anymore...how to control temp??
I bought the 9,000 btu and the remote stopped working the second time I used it. I returned it and bought the 7,000 btu and the exact same thing happened; it died the second time I used it. The only thing I noticed, not sure why, but if I take the batteries out of the remote for a while and put them back in, it works. Not being able to control it without the remote is definitely a design flaw.
May 14, 2008 | Haier HPAC99ER Air Conditioner
Panasonic CS-S9NKUA Ductless Mini Split Wal Cool Air Conditioner Logo
12 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
