Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
No display on some of the cycles,whens set on cycle that timer lights up and i push start button, the dryer turns off
Turn on and half of the lights light up but timer will only display on delicate cycle, if i switch knob a few times the normal cycle time shows but as soon as I push start button, it beeps and powers down
  • 314 Answers
Start Switch
A faulty start switch will disable the dryer. To test the switch, access will have to be made within the control panel. Locate the start switch inside the control console. It will have two or three wires connected to it. Remove the wires by pulling at the connectors and taking them off the terminals.
Using a volt-ohm meter, test the terminals on the switch. Set the meter to "RX1" and touch a probe to each terminal. A reading of infinity should be seen. Next, while still holding the probes on the terminals, press the start switch. A reading of zero should be present.
If the switch does not pass either test, replace the switch with a new one.
Door Switch
If the door switch is faulty, the dryer will not run. To access the door switch, the top cover of the dryer must be removed. After the top is removed, open the dryer door and remove the two screws that hold the door switch on the dryer. Reach inside the dryer and remove the two wires off the door switch terminals and unsnap the door switch from the plastic mounting plate.
Set the ohm-meter to RX1 and touch each terminal with a probe. A reading of infinity should be seen. While still holding the terminal and probes together press the switch button. The reading should now be at zero.
Failure of either of those tests means the door switch needs to be replaced.
Drive Motor
The main drive motor could be faulty as well. It is located on the between the drum and the inside of the cabinet. Refer to the owners' manual for front cabinet removal and removal of the drum. To test the motor, disconnect the green ground wire and also the wiring harness from the motor.
Have the volt-ohm meter set to RX1. Place one probe on the white wire terminal and one on the brown wire terminal. A reading of between 28 and 40 ohms should be read. Next place probes on the white terminal and the blue terminal. This reading should be between 25 and 40 ohms. Finally place the probes on blue terminal and the brown terminal. The reading should now be between 58 and 70 ohms. Failure on any of those tests will require that the motor be replaced.
Posted on Jan 10, 2013
shinn8
  • 85 Answers
SOURCE: Dryer won't start after I push the Start button
If it is whirlpool--Make sure it has power. Then:Check the door switch. A little lever sticking down through top rightof door opening. If it is not there you will need new doorswitch(sometimes the little lever breaks off). If it is there and doesnot click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
Posted on May 27, 2009
aborcass
  • 2651 Answers
SOURCE: won't start
is the light going off when the door is closed, and on when opened??? sounds as if you having ansd issue withthe door switch, notthinkin the door is closed, try manually pushing the buton in, you should hear it "click", if it doesnt, i would unplug hte unit, nad witha screrwdriver you can pry the switch out from the side of switch. Dont ask me why buit for somereason afetr removing from the unit, it then will"click". somply prerss back inot place.Never actually had to replace teh switch, perhaps it gets stuck!
Posted on Jan 11, 2009
thaurfen
  • 623 Answers
SOURCE: Dryer won't start cycle. Sensing light turns on and it beeps then
Unplug the unit and take the back off. Down towards the bottom, near the exhaust connection, you will find a small, white thin plastic part with 2 blue wires connected to it. Remove the wires, put them together, wrap with electrical tape, and then plug the dryer in and see if it runs then
Posted on Jan 09, 2009
shinn8
  • 85 Answers
SOURCE: Dryer will not turn on.
Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
heatman101
  • 43501 Answers
SOURCE: Start button will not initiate on cycle. Get 3 beeps.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jun 21, 2010
Timer won't stop after cycle finished.
Dryer will not shut off:
The timer: Located in the control console of the dryer the timer consists of a small motor connected to a series of gears that rotate cams, which turn electric contacts off and on inside the timer. The timer contacts control the dryer motor as well as the heat circuit and the timer motor itself. A defective timer motor or a defect in the timer's electrical contacts can cause the timer motor to fail and the timer will need to be replaced. The contacts can be checked for continuity with a multi-meter. This test should only be made when the dryer is unplugged. Another test u can do is observe by eyesight and see does the timer advance or is it stuck on one cycle?
1. On gas and electric dryers that have an "Auto Dry" cycle, the cycling thermostat is often used to advance the timer as well regulate the drum temperature. Essentially, thermostat will alternately turn on the heat source or the timer motor when the temperature has been satisfied. To check this thermostat, you will have to check for power to the timer motor with a multi-meter, during a cycle. This is a live voltage test and caution should be used.
2. Some dryers will use a cool down thermostat to tumble the clothes without heat, at the end of the dry cycle. Power is routed through this thermostat to the drive motor to keep it running until the drum temperature has dropped to a specific temperature. If this thermostat fails it can cause the drum to turn indefinitely or until the door is opened. You can check the thermostat for continuity with a multi-meter. This test should only be made with the power removed from the dryer.
Lastly check the moister sensor for OHMS according to ur schematic as it must show a certain amount of ohms as per ur unit. When unit has been on short while
May 20, 2015 | Dryers
I have an electric Estate Dryer made by Whirlpool TEDS840PQO. It has "Timed Dry", "No Heat Fluff" and "Auto Sense Drying" settings. On the Auto Sense Drying it has...
Verify that the wrinkle prevent switch is good. If so, the timer is likely the problem. Sometimes the switch contacts inside the timer can be cleaned to restore operation, bit it is a tricky item to disassemble and reassemble.
Mar 07, 2017 | Dryers
105I have a samsung dryer dv409AER/XAA. Currently, I turn the power on and select a cycle and push the start button. When I push the start button - nothing happens. This occurs for any cycle. There is...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 27, 2011 | Dryers
When the start button is pushed there is a loud buzzing sound like the cycle has ended. after turning the timer to start another cycle the start button continues to buss.
heatman101
Apr 17, 2011 | Amana NGD5200TQ Dryer
I have a Frigidaire LEQ2152ES Electric Dryer. The light comes on when you open the door. And the lights and sounds come on when you push the settings. Push the start button, and you hear the tick for...
heatman101
Sep 15, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
How do I set the hb51r so it turns on and off after 6 hours?
manual for HB51RC
http://www.intermatic.com/%7E/media/files/intermatic/products/instructions/timers/hb61rc%20-%20english.ashx
See timer at Amazon
http://www.amazon.com/Intermatic-HB61RC-Digital-Outdoor-Control/dp/B00004W4X5
Plug timer into outlet
Plug lights into timer
Timer turns on automatically at dusk unless you set override feature shown below
Timing cycle repeats each 24 hours
Use selector button to set timer
Timer must be reset after power outage or after unplugging timer.
Push selector button and choose one of following
F > Lights are OFF
O > Constant ON
1 through 9 > timer turns ON at dusk and turns OFF 1 to 9 hours later
d > timer turns ON at dusk and OFF at Dawn
1. through 9. > timer turns ON immediately and then turns OFF 1 to 9 hours later
Maximum wattage 1000
50 mini-bulb-string of Christmas lights is 25 watts
From these instructions, you should push button until 6 displays. Timer will turn ON at dusk and turn OFF 6 hours later
If timer.
If you want timer to turn ON immediately and turn OFF 6 hours later, push button until 6. shows in display.
If timer does not display or does not operate correctly, then timer is suspect. Return timer for another one.
Oct 02, 2009 | Intermatic Outdoor Timer/Photo Control...
Whirl pool dryer LEC9000PW0 will not turn on
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dry cycle
Try setting the washer dial to the stop setting at the end of setting number 4 then set the dryer timer and turn on the machine.  This works for mine to get the dryer to run by itself.  It should begin about 30 seconds later, when the door locks.  Hope this helps.
May 13, 2008 | Malber WD1000 Front Load Washer/Dryer
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
247 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
