Question about Royal JS800 Shredder
How to replace paper sensor - Royal JS800 Shredder
  • 3,904 Answers
I have never taken one apart that far but you should be able to access the screws to remove the cutters once the top is off. From that point you should be able to see the optic sensor you are looking for. Not sure if this a plug and play type of connection but should be an easy solder if not.
Posted on Jan 09, 2013
Brother mfc8440
yes there was a sensor switch, which can be broken and faulty that needs to be repair or replace.
Sep 07, 2008 | Office Equipment & Supplies
Paper won't load
Cke media detect sensor which is mounted inside of cleanout.
clean the sensor or replace the sensor..
1. Remove roller cover upper & roller cover lower
2. Disconnect paper sensor connector
3. Remove clean out (P/no CN727-60047)
4 remove paper sensor..
4e39f03f-171b-4929-bb03-f6046bc6541d.jpg 61e68018-3652-472c-8706-5e97150bb38c.jpg
Dec 18, 2013 | HEWLETT-PACKARD T2300 eMFP InkJet Plotter...
I have canon 2900 and it having every time paper jam problem please help me
Analyse where paper jamming is happening? remove right left back & top covers..press door switch, shoot print command. Remove cartridge after paper jam, check upto where paper travel?
1. If paper jams with curl foldings in cartridge bank area..before entering the fuser assmbly..
# Teflon sleeve not rotation properly due to this paper not passing through it result curl foldings..Replace teflon sleeve..
2. If paper passed fuser assmebly little bit(near about 2-3 inches.
#Problem with paper out sensor/flag. clean sensor, check sensor flag movement & spring.
3. Check registration paper sensor located back side.
# while passing the paper, sensor flag has to act & once paper out it has to reach home,other wise paper jam error will appear.. check flag spring.
Aug 27, 2012 | Office Equipment & Supplies
My print paper tray not work
Contact the dealer and replace the paper tray///
May 30, 2010 | HP Deskjet D2360 InkJet Printer
Codigo C7760 de una Kyocera kilometros 1635
C7410 C7800 C7810 C8010 C8030 Drum unit connector insertion problem • Absence of the drum unit is detected continuously for 1500 ms while there is no error on the copier. Broken external temperature thermistor wire • The input voltage is above 4.5 V. Short-circuited external temperature thermistor • The input voltage is below 0.5 V. Finisher* paper conveying motor problem • The paper conveying motor lockup signal is detected for 0.5 s or longer. Finisher* paper conveying belt problem • An on-to-off or off-to-on state change of the paper conveying belt home position sensor is not detected within 2 s of the paper conveying belt clutch turning on. Drum unit connector inserted incorrectly. Defective drum unit connector. Poor contact in the humidity sensor PCB connector terminals. Defective external temperature thermistor. Poor contact in the humidity sensor PCB connector terminals. Defective external temperature thermistor. Poor contact in the paper conveying motor connector terminals. The paper conveying motor malfunctions. Defective finisher main PCB. The paper conveying belt is out of phase. The paper conveying belt clutch malfunctions. The paper conveying belt home position sensor malfunctions. The paper conveying belt home position sensor connector makes poor contact. The internal tray is incorrectly inserted. Reinsert the drum unit connector if necessary. Replace the drum unit. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the humidity sensor PCB. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the humidity sensor PCB. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the paper conveying motor and check for correct operation. Replace the finisher main PCB and check for correct operation. Adjust the paper conveying belt so that it is in phase and check for correct operation. Replace the paper conveying belt clutch and check for correct operation. Replace the paper conveying belt home position sensor and check for correct operation. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Check whether
Jan 19, 2010 | Office Equipment & Supplies
My HP photosmart C5200 all-in-one series printer keeps saying its out of paper when its not? i keep loading it with paper and nothing happens.there is no jams or anything either. what can i do to fix it?
Most likely the paper sensor is faulty. Sometimes you can clean the area and/or free a stuck sensor. Otherwise you will have to replace it.
This Youtube video demonstrates how to fix a stuck sensor:
This photo shows the location of the paper sensor:
The printer manual can be found on HP's website here: http://www.hp.com/ctg/Manual/c01009068.pdf
You can purchase a replacement paper sensor here:
Buy HP Hewlett Packard Q8330B FLAG PAPER
Sep 08, 2009 | HP PhotoSmart InkJet Printer
Cannon printer pixma mp470 paper jam
hmm, could you be more specific?. But I'll try to solve anyway
Paper jam error occurs because:
  • Paper end not detected by paper sensor; set paper properly and press Stop/Reset button
  • Paper sensor broken; replace paper sensor
  • Drive assy broken; replace drive assy
But before it all please check if any broken paper or another material is in paper path blocking the paper to reach paper sensor.
Nov 09, 2008 | Office Equipment & Supplies
Paper jam
The paper jams in the bottom because the leading edge hasn't reached the correct sensor in time, thus causing a jam message. Do a sensor test on the front panel of the printer before replacing any parts. Go into Diagnostics/Sensor test and you will see the letters across the top follwed by numbers below. Then you want to toggle the sensors located through out the paper path-usually black plastic hanging done into the tray areas. Up in output tray has black plastic hanging down-sensors. lift top cover and you can see the sensors on the left side of the top a black horseshoe shape is a sensor. This will help with the correct parts needed to be replaced.
Oct 02, 2008 | Toshiba TEC B-882 Thermal Label Printer
Royal JS800 Shredder Logo
121 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
