Question about Kenmore HE4t 3.8 Cu. Ft. King Size Capacity Plus Front Load Washer
Control lock lit, no other buttons work - Kenmore HE4t 3.8 Cu. Ft. King Size Capacity Plus Front Load Washer
  • Kenmore Master
  • 8,220 Answers
Instructions
    • 1 Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
    • 2 Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
    • 3 Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
Read more: How to Unlock the Control on a Whirlpool Duet ' eHow.com http://www.ehow.com/how_5701217_unlock-control-whirlpool-duet.html#ixzz2HVS4i8hL
Posted on Jan 09, 2013
Tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
on Feb 01, 2010 | Whirlpool GEW9250 Electric Dryer
The "Control Locked" is lit up and the control
Try holding down the CONTROL LOCK button down for about 3 seconds.
See if that works.
Comment back here if it doesn't and I will provide additional instructions if required.
Good luck.
Joe.
Feb 27, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
The contol lock red light is lit and I can't get it to work
Jun 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
"Controls Locked" light lit, unlock button has no effect
Have you tried unplugging the machine for awhile to let the board reset?
Nov 14, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Gas duet. Mod: GGW9250PWO Ser: MR3604435. Front panel under Status: "Control Locked" light is lit..nothing else works, including Control On button. Dead. Can the dryer be reset??
is the other lights DIM(partially lit)?
If so it could be one of the following.
1.) Intermittent ribbon cables between the control board and the Interface board (one with the buttons) Reseat all four cables.
2.) faulty control board.
3.) faulty Input board.
Nov 11, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
The Dryer says "Control Locked"
Try pressing an holding the "End of Cycle Signal" button on the front panel in for 3 seconds. This button is used to lock/unlock the control panel to keep small children from manipulating the controls when the dryer is not in use. A designed safety feature. If this does not work for you, please post back and let me know. I hope this helps you.
Jun 25, 2009 | Whirlpool GEW9250 Electric Dryer
Duet HT GHW9300PW4 - The control lock is on
Hold down "end of cycle" button for 3 seconds.
chrisxx
Jun 03, 2009 | Whirlpool GHW9300 Duet Washer
The "control locked" light on my ge whirlpool stays lit and
its in small print under one of the buttons. I can't remeber which one it is either. usually you will see a pad lock symbol press andhold tha key down for 3 seconds
Jan 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dryer control locked
Hi ... You press the end of cycle signal button for 4 seconds ... This button is on the far right side & it does work!
Jun 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE4t 3.8 Cu. Ft. King Size Capacity Plus Front Load Washer Logo
272 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
