Question about Whynter FX-6SB Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D
Probe receptable is cracked around the threading
Sunbeam bottled water cooler ylr2-5-24h2
SOURCE: Sunbeam water dispenser Model YLR2-5-90HZ3 Ser# 2003
water leak from inside the refrigerator
Posted on Jul 16, 2008
  • 508 Answers
SOURCE: WATER COOLER DOESN'T COOL THE WATER ENOUGH
clean coils check for temperature setting!
Posted on Jun 30, 2009
carlsbiz
  • 1124 Answers
SOURCE: water doesn't get hot
It is probably a faulty valve..
Posted on Sep 14, 2009
SOURCE: Sunbeam Drinking Water Cooler model YLR2-5-24H2
my hot water faucet is broken!!.. when can i get new?
Posted on Sep 28, 2010
SOURCE: SUNBEAM WATER HEATER/COOLER WITH WATER FILTRATION BOOTLE
i am having the same problem and i lost the model number for it but can you please share the modle number if you have it because i call sunbeam and they need it so they can find it for me! thaky e mail @ hateandlove_1988@yahoo.com
Posted on Nov 15, 2010
I have a obsolete but modern-ish Whirlpool water cooler. The white plastic ring the 5 gallon water bottle sits on is cracked, and chunks are coming off. Whirlpool doesn't stock parts for old model
The collar is only there to keep the bottle at the correct height in relation to the water in the cooler. The principle is that when the vacuum inside the bottle is not being release by the water clearing the opening no more water will run out. To understand what I mean fill up a bottle ( any old bottle) right to the top. Fill up the sink and with you finger over the top of the bottle place the bottle upside down in the water. Take you finger from the hole and it will glug once maybe twice then no more water will run out until you lift the bottle out of the sink water. To stop more running out simply put the neck of the bottle bac in the sink. It is the same with you water cooler bottle. So all you need to do now is to to cover the foam with a piece of vinyle and it will be fixed.
Mar 08, 2013 | Cars & Trucks
Cracked the ring where the water bottle sits on my Whirlpool Water Cooler model # WHAC 5008 GA. I see it is one piece with the holding resevoir. I would like to order and install a replacement, but...
SAME SITUATION, Plastic Ring that water bottle sits on is one piece with two o rings to the probe. Unable to locate and purchase a replacement ring seat probee part. You have any luck. Purchased at Lowes few years ago. Works great. Poor seat designed to fail common problem reported by many.
Aug 12, 2011 | Whirlpool Kitchen Appliances - Others
I HAVE A G.E. SMART WATER COOLER THAT LEAKS WATER FROM UNDER BOTTOM BASE I HAVE TO KEEP A TOWEL ON THE FLOOR UNTIL ITS GETS SOAKED THEN I CHANGE IT, USUALLY OVERNIGHT, I'M USING A 5 GAL. BOTTLE...
try replacing the bottle...it might have a hairline crack that is causing the "leak". I have the same cooler and had the same issue...replaced the bottle and all was well then.
Roy Martinez
Jan 12, 2011 | General Electric GE SmartWater Household...
GE Water Cooler Reservoir overflows.
There should be no crack or pin hole in your water bottle.
Water bottle should be air-tight to make proper pressure inside bottle.
Whenever lose pressure, water overflow with no bubble.
Just replace water bottle with no crack or pin hole.
Good luck.
leey05
Jan 07, 2010 | GE Refrigerators
After emptying our water dispenser for cleaning,
Good luck.
leey05
Dec 07, 2009 | Hamilton Beach Water Cooler with Storage...
The plastic handles that dispense the water are broken
Where can I buy the spigets for a Sunbeam water cooler. I need one for hot and one for cold water. These handles are not strong enough plastic to last the lifetime of the unit. They should be made from metal. If the taps on our kitchen sink was made from plastic you can imagine how long they would last.
May 27, 2009 | Sunbeam Refrigerators
May 23, 2009 | Whynter FX-6SB Free Standing Hot & Cold...
Sunbeam water cooler model # YLR2-5-25H2
I called a bunch of different numbers and finally found the people who can help with this. It's called Elite Group (877-383-6399) - I guess they're the ones licensing the Sunbeam name and making these water coolers. If you call that number with the model number, they'll replace the "top" part of the cooler, which should also have new taps, the lady said. The cost is $13.35
Mar 26, 2009 | Avanti Hot and Cold Water Cooler
Advise
you need to purge the air out of the "hot" side after placing the bottle on top. If not enough water is inside the chamber the water will boil.
Jul 07, 2008 | Hamilton Beach Water Cooler with Storage...
Whynter FX-6SB Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D Logo
67 people viewed this question
Top Whynter Water Filters & Coolers Experts
John Tripp
John Tripp
Tom Chichester
Are you a Whynter Water Filter and Cooler Expert? Answer questions, earn points and help others
