Question about HP Officejet Pro K5400dtn Printer
Hp officejet pro k5400 paper pickup roller for second paper tray
  • 138 Answers
SOURCE: Tray2 Paper emty message after swapping out tray2 pickup roller
Your problem is more than likely that the sensor lever is not properly positioned. You may also have dislodged the shaft from the drive gears (gears on right out side of carriage). Both are easy to do.
Here's a couple pictures of the exact positioning of the paper sensor positioning. It should freely flip up and fall back down with gravity. Remove the tray and check the flag that hangs down.
Just in case you have dislodged the shaft from the geartrain, here's a free copy of the HP Service manual for the printer that will walk you through disassembling the right side for re-mounting the shaft and holder clip for the shaft.
Hope that helps you. :)
If this resolves the issue, hit me with a Fixya! If not ask me further and I'll try and help you some more.
Posted on Sep 10, 2008
Joed911
  • 4338 Answers
SOURCE: replace the tray 2 pickup roller assembly
The tray two pickup roller is a roller in the front of the tray. Remove tray 2 and place it on a level work surface. Locate and open the cover that is
next to the roller in tray 2.
Pinch the blue latch that is on the left side of the roller. Slide the roller off of the shaft.
Then you can slide the new roller back in.
CAUTION When you install this roller, make sure that it locks into place. Verify that the
roller is correctly oriented, and that the round, black spacer next to the roller is correctly
positioned against the locking pin on the shaft.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 16, 2009
SOURCE: Officejet K5400 Won't print black
  • If there are defects on the page, run a Level 3 clean from the control panel of the printer. Follow the steps below:
    1. Press and hold the Power button.
    2. Press the Cancel button one time and the Resume button nine times.
    3. Release the Power button.
Posted on Jul 13, 2009
cns assoc
  • 677 Answers
SOURCE: I there a service manual for the HP OfficeJet Pro
Here is service manual for the HP.
http://printer1.blogspot.com/2008/09/hp-officejet-pro-k5400-color-printer.html
Good Luck.
Posted on Nov 04, 2009
  • 685 Answers
SOURCE: My hp officejet pro k5400 has a stalled carriage.
This should help...
Posted on Mar 10, 2010
Hp officejet pro l7780 all in one printer, Cleaned the pick up roller still not picking up paper
The pick up roller may be worn and in need of replacement. The slight grinding noise is the pickup roller trying to work but slipping
Oct 30, 2012 | HP Office Equipment & Supplies
I have an HP 8500 premier with 2 paper trays. When I try to print from tray 2, the paper feed rollers don't touch the paper. I can pull the rollers down, but they spring right back up. on tray 1 the...
it touches the tray according to he size needed so if u want in the second tray can keep the size greater then a4 and chnage the settings so it takes from the second tray .................
Oct 27, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Printer out of paper message
I know this probabley does not help you too much. But did you use a roller cleaning solution? If you have i would say to have the rollers replaces. I know its a bad solution. but just trying to help out what little i can thanks (i have used rubbing alcohol before and it helped me) (make sure to dilute it with water 50/50) so 50 percent water and 50 percent alcohol. just make sure to read up on your rollers (google) and make sure the alcohol will not damage the roller. (also if you have warranty just send it off) assuming you have warranty left.
thanks again
sorry if this doesn't help you out :)
Steven.
Apr 21, 2010 | HP Officejet Pro K5400 All-In-One InkJet...
Printer does not attempt to pick up paper but gives out of paper message and or flashing paper sign on panel
steps:
(a) driving a pickup roller, picking up printing paper stacked in a paper cassette, and then, feeding the picked up printing paper to an image forming unit
(b) after picking up the printing paper in step (a), checking to determine whether or not the printing paper has been fed to the image forming unit(c) when it has been determined in step (b) that the printing paper has not been fed and a paper feed error has been generated, again driving the pickup roller, so as to attempt to pick up the printing paper stacked in the paper cassette again.
My Officejet pro has a paper jam and I can't release it. Thanks
  1. Turn off the printer.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and i suggest contacting the printer manufacturer for additional assistance and/or repair.
Jul 13, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
May 15, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
On button flashing and paper feed button flashing - new purchase?
Please see your duplicate problem posting for the solution:
http://www.fixya.com/support/t1691524-k5400dtn_paper_feed_buttons_flashing
Feb 21, 2009 | HP Officejet Pro K5400dtn Printer
OUT OF PAPER
The printer will attempt to pull in a sheet of paper out of the tray. If none is pulled, this is noted because a microswitch is not closed by the paper sheet as it goes by. This is the cause of the message. Check to be sure that the rubber roller that grips the paper initially is clean. I'll leave further comments to Benimur our local printer expert.
Dan
May 01, 2008 | HP Officejet Pro K5400 All-In-One InkJet...
HP Officejet Pro K5400dtn Printer Logo
177 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
