Question about Philips 60P8341 60" Rear Projection Television
Screen bought the TV a few months ago and the screen suddenly was red tinted still clear enough to watch but just more red, I opened the back and adjusted it but still couldn't get the red to dial down, sharpness is great on the red but the blue and green when you cover up the the other colors is still blurry toward the outside, now when I turn the tv on the picture won't come on sound is there lights are on I turned up the adjust for the lights to go brighter but its just blurry no focus if anyone could help me and tell me what I need to replace or adjust so I can order parts or dig into the back
  • amanda O'Brien Jul 07, 2007
    took it to a shop that worked on it for free looking for the problem and found that a crkt card is the culprit 245 bucks for the card 800 total to fix
  • 41 Answers
What you may have needed to do was adjust the green & blue crt screens to match the red. Go into your picture menu adjust, turn color all the way down to a black & white px. Now adjust each crt screen so that you end up with a true black & white px. Then adjust each focus control to get a sharp px, have your tv on a channel like the home shopping network so you can adjust each crt focus one at a time for clarity by cover the other 2 up. Then go back into picure adjust & turn color ahlf way up, you should see a better px.
Posted on Jul 05, 2007
  • Anonymous Jul 05, 2007
    If you cannot get the blue & green to even out
    to a black & white screen you have other problems such as red crt is biased to hot
    due to a faulty part on the crt card on back of
    tube or could even lead clean back to the video IC being faulty, where you would need a scope
    & manual to pinpoint culprit bad part.
SOURCE:
Red tint on screen
Good Day,
Try resetting the TV by unplugging from wall outlet for 3 to5 minutes then plug back in. If no fixya take front grill off and panel and adjust the screen controls, turn color off adjust for Black & White Picture. Good Luck, big IRISH.
Sep 13, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Corner tints and white lines
it can be a picture tube problem. moreover, check if your tv is dusty inside it . clear it with blower and try again.
regards,
Jul 31, 2008 | JVC AV-32120 32" TV
Screen Green Tint
Turn down your color and see if the screen has a normal black & white screen. If it doesn't then the CRT is bad (picture tube). If it is black & White then you have a either lost your red or blue.That problem will be in your video driver circuit of which a service center can handle.
Feb 18, 2008 | RCA 20V500T 20" TV
Red or green tint on LG LCD 32" TV
Misaligned white balance adjustment. If you wish to get some details; visit the site linked here. Pull up older posts.
Jun 14, 2017 | LG Televison & Video
Strong red tint with horizontal lines across screen
if you have warrenty, return it. if not, then buya new one...the video fuses are dying...hard to fix it.
Oct 06, 2007 | Akai PT4799HD Rear Projection Television
Sanyo Tv color problem
I would check the green signal all the wat to the display screen to determine is this is a signal problem or a system short. I would recommend that you take this set to a qualified electronics technician
Sep 10, 2007 | Sanyo DS27910 27" TV
Heavy pink tint,lines.
you should have a problem in the matrix board (the r-g-b) output board should be seen by qualified regards please don't forget to rate thx
Apr 29, 2007 | Apex Digital AT2708 27" TV
Dark picture (HELP)
Open up the back of the set but be very carefull. Notice a large black block with a large red wire that runs up to the picture tube. on one side of that large block where the thick red wire is comming out of are two controls, one should be marked focus or F and one should be marked screen or S. With the set operating normally and not touching anything else, slowly turn the control marked screen or S clockwish till the picture gets bright enough. If you go too bright the set will shut down or you see small thin white lines so back down on the control. then touch up the focus and your good to go. good Luck.
Dec 01, 2006 | Toshiba 32A42 32" TV
Blurry Screen
ok your problem is the RGB section maybe crack soldered at the RGB try to resoldered it! you seen that at the back of the picture tube they have small board attach at the neck... resoldred all small part, and transistor drivers!!!
Nov 13, 2006 | Jensen TS2750J TV
Philips 60P8341 60" Rear Projection Television Logo
194 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
