Keys Fitness 5600T Treadmill Drive Motor Logo
Jim lord Posted on Jan 09, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
5600t speed adjust does not work
Unable to adjust speed from either the hand grip control or the main board buttons. speed control board has been replaced
ernesto cuadra
Level 3:
Top Expert:
  • Keys Master 12,223 Answers
  • Posted on Jan 09, 2013
ernesto cuadra
Keys Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4080781
Points
34431
RUN the software calibration, for troubleshooting and fix it.
See the steps for calibration.
God bless you
The Steps for Newer Style Console Calibration
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the
    "F" appeared in). Troubleshooting the failure would be the next step
1helpful
Is my console going out? On my Sole F63
Just replace the micro switches. You will get it any electronic repairing shop. it would worth more Buying than new boards.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
How do i replace grips on 2009 electra glide ultra classic
For twist grip equipped motorcycles to remove the throttle or right side grip remove the upper and lower switch housing screws, loosen the upper screw securing the handlebar clamp to the master cylinder housing. Remove the lower clamp screw with flat washer, separate the upper and lower switch housings and remove the throttle grip from the end of the handlebar. (To remove the throttle grip, a slight tug may be necessary to release index pins in grip from receptacle in seal cap of twist
grip sensor.)
With throttle cables, to remove the throttle or right side grip slide the rubber boot off of each cable adjuster, loosen the jam nut on each adjuster, turn the adjusters in the direction that will shorten the cable housings to their minimum lengths. THEN remove the two screws and separate the upper housing from the lower housing, unhook the ferrules and cables from the throttle control grip and the lower housing, (remove friction spring, throttle friction screw and spring from the lower housing only if necessary), (only if and as necessary mark the position of the master cylinder assembly forward position and split line on the handle bars) (to be safe squeeze the front brake lever and place a 5-32 inch thick cardboard insert between brake lever and lever bracket and then release brake lever to hold the lever in this place to protect the brake switch from damage if the switch housing and the master cylinder get separated) (and only if and as necessary, loosen the two perch screws) move the lower switch housing as necessary and remove the grip.
To install the throttle grip apply a light coating of graphite to the handlebar and the inside surface of the upper and lower housings, (if removed, install the spring, throttle friction screw and friction spring in the lower housing) (and, if removed, attach the cable assemblies to the lower housing), (throttle control cable has a 5-16 inch fitting end and is positioned to the front of the lower housing. and the idle control cable has a 1-4 inch fitting end and is positioned to rear of lower housing. Install the throttle control grip over the end of the right handlebar, position the lower housing onto the right handlebar, engaging the lower housing with the throttle control grip, position the ferrules over the cable ball ends, seat the ferrules (with the cables attached) into their respective notches of the throttle control grip, install the upper housing over the right side handlebar and secure it to the lower housing with the appropriate two screws and hand tighten them, then align the brake master cylinder and perch assembly with the marks made prior to loosening them, and beginning with top screw, tighten the two screws to 108-132 inch lbs using a T27 TORX drive head and then tighten the upper and lower housing screws to 35-45 inch lbs. THEN point the front wheel straight ahead and WITH THE ENGINE OFF, adjust the throttle and idle cables by turning the adjuster in the direction that will lengthen the cables. Gently twist the throttle control grip to the fully open throttle position (fully counterclockwise) and hold it in this position and turn the throttle control cable adjuster counterclockwise until the throttle cam on the induction module (or carb) contacts the throttle cam stop, release the throttle control grip and turn the adjuster counterclockwise an additional 1-2 to 1 turn and tighten the jam nut on the throttle control cable adjuster. THEN turn the handlebars fully to the right and turn the adjuster on the idle control cable counterclockwise to lengthen the sleeve until the end of the cable housing just touches the spring within the cable guide. NOW check the adjustment by, with the throttle friction screw loosened, twisting and releasing the throttle control grip two or three times. The induction module throttle wheel must return to the idle position each time the throttle grip is released. If the throttle does not return to idle, turn the idle adjuster, shortening the cable sleeve until the correct adjustment is obtained, tighten the jam nut and slide the rubber boots over each cable adjuster. NEXT start the engine and with it idling turn the handlebars through their full range of travel and if the engine speed changes at all during this maneuver, adjust the control cables according to the foregoing procedure so that there is no change in the idle speed when the handlebars are rotated through their entire range of travel.
To remove the clutch or left side grip remove the two screws and separate the upper housing from the lower housing. Mark the forward position and clutch perch split line on the handlebars and then as necessary loosen the two clutch perch screws and move it out of the way so that you can access the grip end. If you want to save the grip take a small screwdriver with about an eight inch length and insert it into the grip, wiggling it to loosen the glue somewhat and then spray some brake kleen into the space under the grip where the screwdriver blade is inserted and wiggle and twist the screwdriver around to loosen the rest of the grip glue and pull the grip off. Sand down the handle bar area where the grip will rest and apply grip cement to the area and slip the grip on. If the left hand grip is patterned, align it with the pattern on the right hand grip with the throttle in the fully closed position, immediately push the grip completely onto the end of handlebar using a twisting motion. Do not hesitate when installing the grip or the adhesive may dry before installation is complete. Allow 6 to 8 hours to elapse at 70 degrees F to allow the adhesive to fully cure. If a newer non-glue grip is being installed slip it on with the flats properly oriented to fit with the switch housing halves when they are installed. Install the switch housing halves and lightly tighten the two screws and then orient the clutch perch to the previously made alignment marks and beginning with the top screw, tighten the screws to 108 - 132 inch lbs using a T27 drive head and then tighten the switch housing screws to 35-45 inch lbs.
Sep 20, 2014 • Motorcycles
1helpful
How do I slow down my power chair
You may have a faulty speed control depending on the model. There are hand held programmers that are used to adjust the speed and other parameters. Your local dealer or mobile technician should be able to make that adjustment for you.
I have a kenwood KMx 50 mixer & it has a speed control problem when you trurn the speed knob a little way the mixer accelerates to top speed then slows to approx 30% speed, then you can adjust the speed....
KMX50 would start and accelerate to high speed, then slow down some with fairly erratic speed. I tried changing the triac on the main speed control board, then also the whole board (£45). It made no difference.
The only other component I realised it might be was the speed control board which is on the rear end of the motor under the main cover (I found this component on a site selling Kenwood parts, and was where I got the main board from, which is how I know it's speed control). When I inspected it I found two of the terminals broken. You had to look very closely to see they were broken. It's a poor design as the three legs of the terminals are quite long, and very thin, so on high speed when kneading there is much vibration, which is why I suspect the terminals broke. I cut them back just enough to resolder. The component isn't quite fully inside the sensor wheel on the motor shaft, but it still picks up sufficient signal to control the speed and now works fine. Haven't tried it under load yet, but no reason to think it won't work correctly. So check this before ordering a £45 board!
1helpful
I bought a used Cybex Trotter 700 T treadmill that works fine except the increase speed (+) does not work. I tried to fix it and now all of the buttons don't work. Any sugestions?
Dear Sir:
This is probably a 1(faulty speed sensor or the 2( speed sensor is not plugged in properly. Its also possibly a 3(faulty motor control board or lower board+ 4( Main motor faulty. Adjust the speed sensor see the diagram.
Run the software calibration for easy diagnose and troubleshooting.
See my personal TIPS for HELP
sincerley. God bless you.
ernesto cuadra
managua, nicaragua.
T931 not starting
1) Exchange batteries by new ones.
2)Tight the flexible cord Keypanel vs display board.
3) Tight the connector from display board vs lower board.
4) Adjust the sensor reed switch see the diagram by 1/8"
5)put your software calibration to work, for diagnostic and adjust.see the instruction in your owner manual y/o under hood.
6) Adjust the speed sensor and tigh the connector very well.
7)Test the main motor for 115VAC, see the plate from motor for to check the voltage.
8)See the main motor board or lower board, Test for 115 Vac, and +5VDC for output from the main controller board and display board
See the block diagram and take the diagnostic very effective. sincerely.
Merry Christmas.
ernesto cuadra
managua, nicaragua. c.a.
NordicTrack Elite XT Treadmill-display problem
1) Run the calibration software for easy diagnostic and fix it. go to owner manual, and go under the hood for following the steps.2) Exchange the batteries by new ones, cleanup contact from the batteries for oxide, and see if there are Not SOME WIRES BROKEN OR LOOSE.3) Tight the keypanel from flexible cable vs display board, 4) tigh the display board vs lower board. 5) attached the sensor reed switch by 1/8" or 3 mms adjusted according. 6) Test the main motor controller board for 115 Vca, and then +5 vdc for output coming to display board very important.
7) Test the transformer for primaRY VOLTATE see the tip adjust how to do it. 8) Finally see the block diagram that I did like like you for easy diagnostic and fix it.to.
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness
sincerely. Happy new Year. G-d bless you
ernesto cuadra
managua, nicaragua
Can't adjust the setting (color, brightness, contrast, etc.)
It sounds like you may have issues with your main board
Hi I have a makita drill 18 volt. I lent the drill to a friend and got it back not working properly. When I squeeze the button, the motor is running but the head of the drill is not turning and doesn't...
Check the speed control. There is a speed control usually from hi to low... sounds like it's in between speeds... try adjusting it back and forth...
It should go back into one gear and work fine.
Top Keys Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you a Keys Exercise and Fitnes Expert? Answer questions, earn points and help others
