Question about VIA MSI K8T Neo2-F K8T800 Pro Socket 939 DDR 400 ATX Motherboard w/SATA, RAID, LAN(Gb), USB 2.0&Audi... (MMK8TN2F)
BUILT A COMPUTER HAVING PROBLEMS
I HAVE A DDR 400 MOTHER 3GB MEMORY GEFORCE VIDEO CARD AND 400 WATT POWER SUPPLY. EVERY TIME I TURN ON THE COMPUTER IT SHUTS DOWN.I'M NOT SURE IT'S THE POWER SUPPLY OR MAYBE THE VIDEO CARD.IF ANYONE HAVE ANY IDEA WHAT'S WRONG,PLEASE LET ME KNOW?
According to MSI's specification page, (http://www.msicomputer.com/product/detail_spec/product_detail.asp?model=K8T_Neo-FIS2R), this motherboard only supports 2GB of RAM. The system will likely not boot if 3GB is installed.
Posted on Jul 26, 2009
    Problem Solver:
  • 16 Answers
I am not sure which geforce video card you have, nor what motherboard nor cpu you have installed. but 400 watts should be adequate for a basic system.
I would need more info to try to help you solve this problem.
Posted on Jan 21, 2009
I have bfg 9800gt it wont boot .. just puts monitor to sleep ... am2 biostar mother 450 watt power supply 3gb ram triple 3.0 amd cpu
ive had a similar problem before. in the BIOS there somewhere, there is an option to make your computer use the ON BOARD VGA, or to use the PCXI. which ever one is selected is the one that the computer will use. if you can change this option in the BIOS, you might be able to use your video card.
Jun 28, 2012 | BFG Technologies GeForce 9800 GT, (1 GB)...
Hi, I have a GF FX 5500 graphics card (AGP) 256M 128B DDR TV/DVI newly acquired. Since I installed it the computer restarts at least once before it had entered password on this computer. With very...
I would check that your power supply is able to handle this card. This card requires a minimum 450 watt power supply. If you take the card out, I would imagine the computer will start fine. Also, verify that you plugged in the power connector into the video card. However, use a volt meter to test your power supply.
Dec 13, 2010 | Nvidia GeForce FX 5500 Video Card Graphic...
I have dell gx 260 with 2.4 ghz nd 1gb ddr ram with nvidia geforce fx 5200 can u name any graphics card which will be gud enough than geforce 5200...nd agp plz..
You need an AGP 8X graphics card for one.
AMD ATI Radeon series:
1) Better: XFX Radeon HD4650
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4914257&CatId=2234
A) 1GB (OR 1024MB) of DDR2 graphics ram memory
B) 128-bit bandwidth memory interface
C) 320 Stream Processors
D) 600MHz Core Clock
E) 800MHz Memory Clock
F) 55nm process technology
3) Best: HIS HD4670
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6076197&CatId=2234
A) 1GB (Or 1024MB) of DDR3 graphics ram memory
D) 750MHz Core Clock
E) 1600MHz Memory Clock
Likes POWER! Better install a 500 Watt power supply, to keep up with the power needed for this baby!
The GX260 supposedly has a 250 Watt PSU. (Power Supply Unit)
Back in the day this PSU was made, the PSU manufacturer 'fudged' the maximum rated wattage.
Actual is more like 60 percent of what is stated.
175 watts!
The above is just IMHO about graphics card choice.
(I have motherboard's with a PCI Express x16 slot, using the PCI-E 2.0 technology.
I use Nvidia graphics cards)
Oct 16, 2010 | Nvidia G-Force FX5200 256M DDR 8X AGP...
Not booting up
try changing your memory or your processor. you might get a result
Jun 11, 2009 | EliteGroup ECS L4VXA2 (CDL4VXA2)...
No signal on monitor
You might try switching the VGA cable if you haven't. If that doesn't work then I'd agree with you in saying the motherboard is likely fried.
May 26, 2009 | AMD ASUS A7V8X-X MOTHERBOARD ATHLON XP...
Computer wont turn on or boot
what size power supply are you using, if its under 400 watts it may just be under powered. Large video cards 512mb and over take a lot of power. Try removing the video card and see if you can get the pc to power up, hopefully you have on board video.
How did you blow the cpu_fan connector, did you short it out? I would first supect the power supply is under rated, second a blown power supply, or mother board.
Mar 14, 2009 | Computers & Internet
Pc died
Hello, I have had similar problems with that same motherboard in the past and have found that resetting the cmos (see users manual) or just taking the battery of the motherboard for a few minutes can solve this. CAUTION please remove the power lead on your tower before touching any components inside, and earth yourself first by touching metal.. as static discharge kills pc components..
Hope this helps.....
Tony.
Sep 09, 2008 | ASUS K8N4-E Deluxe Motherboard
Looking to buy a new graphics card
You have a PCI Express slot to put a graphics card in. You can get a bigger graphics card to install in the machine but the power supply you are using in your comptuer is only 300 watts. If the specs of the memory card tell you to upgrade the power supply if its blow x amount watts you will have to do that in order to not run into problems. The good thing about e-machines is that you can upgrade the power supply at the same time. Usually they don't cost a lot of money.
You might have to get one thats around 425 to 475 watts depending on what the instructions tell you. If the new video card you are using is running a fan for cooling, chance are it will need an upgrade.
Jul 12, 2008 | Graphics BV200 BizView 128MB (128 MB) PCI...
P4MBMS Motherboard Problem
look for the reset jumper on the board and then reset it then try again
Jun 03, 2007 | Mach Speed P4MBMS Motherboard
New build computer wont turn on (ASUS A8N32-SLI Deluxe Socket 939)
The ATX power supply needs to have pin16(PS_On#) to be connected to COM for it to work. When you press the power switch on the front panel of the computer, you are essentially making this connection. Check that the cable from the power supply to the motherboard is making good connection. You can verify operation of the power supply by shorting Pin16 to pin17 on the powersupply output, with a paper clip. Pin16 is usually a green wire and 17 is black. Hope this helps. -Vish
May 04, 2007 | ASUS A8N32-SLI Deluxe Motherboard
VIA MSI K8T Neo2-F K8T800 Pro Socket 939 DDR 400 ATX Motherboard w/SATA, RAID, LAN(Gb), USB 2.0&Audi... (MMK8TN2F) Logo
85 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
Abhinandan  Patil
Abhinandan Patil
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
