Question about Toys
Needs a screw but don't know what size I need plz help me and its a small screw
    Genius:
  • 1,669 Answers
Conner, I couldn't see your video at all. Please take the toy to a hardware store and have a person working there help you find the best screw.
Posted on Jan 09, 2013
  • connorjbrand Feb 18, 2013
    Ty and my name is spellet with an o not an e
I want to get a futon but I have very minimal space to put it. Does anyone know of a small size futon?
You should be looking at love-seat futons. I don't know the size of space you have available; however depending on the size you want/need you can go as small as only taking up 45" of wall space.
Aug 01, 2012 | Furniture
I play fifa 12 but it is very very slow so i cant play plz help me
First I need to know about your machine (technical details) like Model of processor, Installed RAM and Video card with memory size or model number of it.
This is normally happens for the Graphics (Video) card. If it has lower memory capacity as well as processing speed of video card's GPU than the games required.
This is also cause for the lower installed memory (RAM) size, as Games requires.
You can get several information of your PC by System Properties. I don't know which operating system you are currently using so I can't tell you specifically how to get them. In case of windows go to Start > All Programs > Accessories > System Tools > System Information 6_25_2012_10_12_23_am.jpg
Jun 25, 2012 | Electronic Arts PC Game - FIFA 12 DVD-ROM
I need to know what tools are needed to change the starter
a socket set from size 6mm to at least 16mm and a ratchet honestly i think that is all that is required. the small socket size will be for disconecting wires. the bigger size socket will be used to take the mounting bolts off. you might need a philips head screw driver or a flat head screw driver I am not entirely sure because almost every veicle is different but some sockets a ratchet and maby a screw driver should be all you need. i hope this helps and if it doesnt i am sorry. be carefull and have a nice day!
Dec 23, 2011 | 1993 Suzuki Sidekick
Does anybody know what size plug/powerpack I need to order for my 5ft singing dancing santa! please help I'm desperate! Julie :-)
You need a 9volt small transformer. People have them in the basements every where, or a friend will have one from some other toy. Lots of them around clearly marked for 9 volts. These are low amp cords. Hope it helped. Joe
Dec 13, 2011 | Gemmy Life-Sized Animated Santa
I need a chain for a 21speed mountain bike it is an older mongoose MGX i dont know what kind or size chain i need can you plz help me out???
Look around for a 7-speed chain. Special tools are involved for 'cutting' it to size so why not just establish a relationship with your Local Bike Shop now?
http://www.parktool.com/blog/repair-help/categories/chain-repair-and-service
If it's really worn you'll probably also need to replace the cogs and possibly the chainrings. Old drive train parts don't mesh well with new ones.
Use the web to answer common questions.
http://sheldonbrown.com/chains.html
Sep 19, 2011 | Cycling
Drained old gas put in new new now its poping from exhust
Crackling and backfire is nearly always lean on fuel condition...
open your air fuel mix screw tiny amount at a time and test to see if helping this should clear up the popping..
Please note if you need to open the air fuel mix screw more than 3 full turns from fully closed then the easiest solution is leave the air fuel screw at 2 turns out from closed and increase the size of your pilot jet by one or two sizes.. they very cheap to buy few dollars each.
I would suggest if your only popping and crackling a little then small adjustment on the air fuel mix screw will cure it for sure
Being YZ I find an occasional pop or backfire when de acelorating is exactly how they should be if you don't get a pop or crackle every now and again then chances are it running to rich.
but if it is regular occurance then definitely needs fine tuning or larger pilot jet installed
good luck regards Jamie
Sep 09, 2011 | 2003 Yamaha YZ 450 F
I borrowed my friend's Dremel to cut a few screws...originally she had the EZ Lock Cutting Wheel but it is too big so the smallest they make is not with the EZ Lock head so I was told to get Dremel 420...
I don't know what the numbers are, but the little abrasive cut-off wheels are held on with a mandrel type bit and a screw. Make sure you get the right size wheel and the right size mandrel, they make a couple different sizes, you can't fit the small wheels on the bigger screw. Anyway, I use my cut-off wheels all the time, usually to get stubborn screws out by cutting a slot in the head and turning it out with a flat blade screw driver. The wheels will cut anything, most people scoff when I say that, but it is true, they will cut anything.
Jul 15, 2011 | Dremel Garden
Stalls out, does not want to take gas
it most likely does, this takes a very small screwdriver, i was told by a tech to just get a common screwdriver very hot( a small one) and place it in the adjuster screw so the plastic melts to its size, it is all the way in and out 3.5 turns for air mixture, and usually all the in and out 1.5 turns for idle. Those carbs are very difficult to adjust with the small screws so I found his advise to be helpful.
Aug 08, 2009 | Husqvarna 28cc Gas Line Trimmer
Toys Logo
149 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
