Question about Samsung Washing Machines
Samsung wf-j1254 front load washer 5e error persists
This error return repeatedly. Have drained, cleaned filter, unplugged machine... Help?
  • 1314 Answers
SOURCE: Samsung b1445 washer
let me do a little research can you turn the drum by hand to make sure nothing is jamming it
Posted on Feb 16, 2008
  • 27 Answers
SOURCE: Samsung Front load washer WF-J1254 stops mid cycle
motor control board is bad and needs to be replaced, contact sears or someone like that to replace.
Posted on Jun 14, 2009
SOURCE: LG Washer LE Error
Solved LE error for my WM1832CW by replacing Hall Sensor. Bought part 5016501KW2002A for $Cdn 26 at Sears parts store. Thanks to TC at http://www.howtomendit.com/answers.php?id=28214 for instructions:
1 Open rear panel. Take 17mm nut off (it's the only one)
2 Pull off what looks like a goofy hubcap (it's held by magnets)
3 Unscrew the six 10mm bolts and gently lower the coils
4 Remove and replace the Hall Sensor (plastic comb looking thing)5 Plug in the sensor and re-install the coils and cover.
30 minutes for me.
Test spin cycle if desired by following chart on page 19 of service manual at http://www.appliancefactoryparts.com/content/pdfs/125448.pdf
(note lower models skip step 10 (heater test).
Hall Sensor Part labelled as K351 in diagram on page 41 of service manual.
Posted on Jun 30, 2009
PSITECHNICAL
  • 71 Answers
SOURCE: getting error 5e WF7708 samsung front loader. Have
A 5E code means that the drain pump is iether clogged, with lint, impeller damage, drain hose clogged, or a loose connection on the pump connectors
Posted on Jan 06, 2010
Testimonial: "i was draining the water out only coming out in dribbles so i think you hit the nail on the head....ty ty will give it a go..."
blueextc3221
  • 15935 Answers
SOURCE: lg wm-2277hw front load washer getting a OE error
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
Samsung washer wont drain
  • Check drainage pump filter for debris
  • Check drain hose and waste connection for kinks and blockage
Select a spin cycle to drain remaining water. If problem remains, service may be necessary.
Aug 04, 2016 | Samsung Platinum Front Load Washer -...
Samsung WF-R1061 washing machine repeatedly trips
does it show an error code ? when it trips what is the washer doing filling water or spinning etc ? does it work on other settings like spin and drain with out tripping. ?
May 27, 2017 | Washing Machines
I have a Samsung front loader. It has been stopping with the error code 5E (filter problem ) for a few months now. Turning the machine off then on again after 20min gets it going again. The fault always...
The 5E error mean:
Pump won’t empty - not draining
As usual with these error codes for not draining the first thing to do is check the pump filter but, on Samsung washing machines, the drain pump itself is often faulty. You can find how to fix this problem on youtube, just text it "Samsung washing machine 5E error".
May 16, 2017 | Samsung WF520ABP - 5.0 cu. ft. Steam...
SAMSUNG WF-J1254 washer very shaky when it's spinning, Help.
machine must be level there are 4 adjustable legs (1 in each corner) place a level on machine , level left to right and front to back.also check manual for initial set up there may be shipping screws that need to be removed on the back of the washer. good luck
Jun 11, 2012 | Samsung 3.7 Cu. Ft. Stackable Front-Load...
Describe your samsung wf-b 1061 error code 5E Problem
Error code 5E is the code telling you that you will need to clean the filter. After you clean the filter the code will go away.
Dec 19, 2010 | Samsung WF317AAG Front Load Washer / Dryer
I have a 7kg front loader which was half way through a cycle before stopping. It makes a warning noise and then SE or 5E flash on the display. It won't spin or drain and now I cannot open the door to get...
Hi dear.5E code meaning on Samsung washer's,DRAIN fault.1-Please check drain hose for kink or clogged where it gets end.2-Please slowly open the machine's filter & drain the water inside the washer.Take out the filter & check it,if there is any thing blocks the filter or pump,try to clean it & put it back.It should comes back to normal.(If non of that's happening you might have defactive pump,call service centre.)Run the spin program & make sure it's draining now.I hope that helps.Thanks.
Aug 29, 2010 | Samsung WF337AA Front Load Washer
No water is going into my bowl after I fixed mt SE problem
This is a defective inlet water valve assembly. replace it asap.
Jun 24, 2009 | Samsung WF203ANW Front Load Washer
Detergent drawer
I ended up having to call Samsung support for this same question. Left to right two vertical bars = detergent (liquid or Powder) flower = softner, single vertical bar = bleach.
Oct 19, 2008 | GE Energy Star WCVH6260F Front Load Washer
Washing Machines Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
