Question about Weslo Cadence G - 40 Treadmill
Would not start
After heavy weight person ride it,stop working
    Top Expert:
  • Weslo Master
  • 12,223 Answers
Lube the rollers bearings too
if the problem persist ,time to replace the old board deck belt complete
God bless you
Posted on Jan 09, 2013
How do i disable passenger airbag?
Some models have a switch that can be turn off right on the dashboard. If you push in the lighted button, it should turn off the air bag feature. Some have a weight Switch / Sensor underneath the passenger seat. Meaning if you put a pocket book heavy for example, it is gonna to consider that weight as a person and turn on the seat belt sign and furthermore turn on the Passenger airbag. Put your heavy stuff on the floor or ignore it. But if you get in an accident the safety bag is going to deploy as if a person was sitting there.
Hope that helps. Here is a couple of links to Kia Support.
http://www.kia.com/us/en/content/owners/contact-kia
http://www.kia.com/us/en/content/owners/faqs/faq-001
Jul 15, 2015 | Kia Sportage Cars & Trucks
Machine stopped working during use.
Hello! There is a trouble shooting guide for major appliances that frequently suggest parts and video links on youtube that diagnose your problem & instruct you how to repair your appliance. The site is called Repairclinic.com. Make sure you have the model number before you begin since the instructions are model specific. Good luck.
Jun 21, 2015 | Candy CNW136 Front Load Washer/Dryer
How do i release air from the rear shocks in a 2002 bravada, the car it sitting up very high in the rear and there is no bounce at all when hitting bumps in the road
Try going under the vehicle the sir pump is located in the rear wheel area.it has an activating lever..when the it detects weight the frame makes contact with it and the pump comes on..when the weight is removed the frame releases the lever..sounds like it may be stuck in the heavy weight position..try moving it by hand..if it moves but does not release the air the activator is bad..and needs checked...don't suggest disconnecting the hose..it will ride way to low and effect the ride control.. Good luck
Oct 21, 2014 | 2002 Oldsmobile Bravada
I changed the oil on my sears riding mower and it run fine for over an hour and then started smoking real bad.
What weight of motor oil did you put into the tractor? And how much? The capacity of the crankcase is 1.7L (1.75 qt.). The recommended engine oil is SAE 30. If you put a 10W-30 product into the engine and operated it under heavy load or heat conditions, the oil may not be capable of providing sufficient lubrication.
Aug 05, 2014 | Craftsman Garden
Spread gravel with riding mower
Generally riding mowers lack the weight, power, and frame structure that is needed for heavy work like plowing dirt, moving stone, etc. You can maybe move small amounts of light stone by using a snow-plow set up with weights and chains but beware of over-loading the engine or trans. If you have a hydrostatic type transmission I do not recommend this at all as the one used in almost all riding mowers is simply not strong enough for any extra work at all, even mowing on decent slopes, or towing a small cart can severely shorten the lifespan of those transmissions and will result in an expensive paper-weight.
Apr 11, 2013 | Garden
How much a punching bag weight?
The most commonly purchased bag is the heavy bag, the heavybag weight between 70 to 90 lb., this standard bags fit an adult person in the140 to 170 lb. you can find out moreinformation about customized punching bag that will fit you at https://www.profightshop.com/heavy-bag-2010-heavy-bags-punching-bags-&-kicking-bags-online-catalog-prod.html?srt=2d&products_id=221&cPath=6_58_59
Jul 23, 2012 | Boxing
What type of cue should I prefer, light or heavy?
Weight of a cue is very personal. Some would gofor the heavy ones, some will prefer light but most people tend to prefer cuesin the 19 Ounce range.
Jul 09, 2012 | Sport & Outdoor - Others
Skate
Nope, has little to do with it. Practice is what it takes. You can do it.
--W/D--
Aug 18, 2009 | Sport & Outdoor - Others
Wht weight oil does a 5700 take?
allot the generators take 30 weight but thats a guss in the winter i had go with light weight.
i am on my second colman i lived woods for years with no electrci other generator 30 weight is heavy stops less wear tear on the insides. But winter time comes i had go lighter becuse oil was like malassas. And then i could not pull it to start it was so thick and heavy the oil in winter
go there web site look up ore try 1800 number for them to get
Jul 28, 2009 | Electrical Supplies
Weight Limt
thats a great question and i am wondering the same thing i weight in at about 240 and it seems to ride fine beside the noises it make but im thinkin the noise is because it is brand new... i have heard nothing about weight limits and read the entire manual and read nothing about weight limits so im assuming there is no limit .....
Jul 12, 2008 | Electrical Supplies
Weslo Cadence G - 40 Treadmill Logo
Top Weslo Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
