Question about Bulova Watch
How to remove the cover from a Merona fmd watch
I do not see how to remove the cover from Merona fmdm132 watch so I can replace the battery
What size battery for a FMD PU003 watch?
Can you open it to replace battery?
If you can open, you can take note about the battery it has
May 31, 2015 | Watches
Where do I get the battery of my merona watch? Nd is it possible to change the battery? Or do I hv to throw it away?
Not to cast aspersions but it might cost 30% or more of the watch price to replace the battery :)
But yes, you can pop the back off and carefully remove the tiny button cell inside and purchase a comparable battery. I've only seen a couple of Merona watches but both of them had backs that popped off with a Watchmaker's knife.
Apr 25, 2015 | Watches
FMDPU003 IS THE SERIAL NUMBER ON THIS WATCH MALES AND I DONT KNOW WHO MAKES IT IS IT WORTH ANYTHING
The watch is made by FMD, and has a retail value of just around $100.00. If its been used in any form it would probably sell for around $40.00
Feb 24, 2011 | Watches
Can't set the watch china module fmd fmdaw015
http://forums.watchnet.com/index.php?t=tree&goto=110449&rid=0
I know isint the same watch number but it worked for me no problem!
Nov 10, 2010 | Watches
How do you remove back cover to replace 296 wrist watch battery
Thank you for contacting FixYa.
  • Place the watch face-down on a clean towel to protect the crystal.
  • 2
    Gently unscrew the backplate from the watch with a small jeweler's screwdriver and set it aside.
  • 3
    Locate the battery compartment and remove the screw holding the cover in place, using the screwdriver. The battery is a small, round silvery button.
  • 4
    Make a note of the battery polarity before you remove it. Is the battery positive (+) side up or negative (-)?
  • 5
    Take the battery with you to a watch shop or electronics store to buy a replacement.
  • 6
    Insert the new battery in the compartment. Replace the battery cover and reverse the above steps to reattach the back cover of your Peugeot watch
  • Sep 14, 2010 | Peugeot Watches
    How do you adjust a merona watch band
    this is all the info available. Try to contact them yourself:
    Merona AG
    Birmensdorferstrasse 83
    CH-8003 Zürich
    Tel +41 44 465 80 80
    Fax +41 44 463 16 96
    E-Mail mail@merona.com
    May 19, 2010 | Watches
    Adjust the band on my merona watch
    at the back side of bracelet you can find direction mark, use fine and strong pin with tiny hammer to remove pin out. if there no mark , just look at both side of bracelet, thru narrow hole push your pin, then fastening pin come out thru wider hole
    Feb 23, 2010 | Bulova Watch
    My son received a merona watch and we cannot figure out how to remove the extra links to make it so it will fit him. Can someone help?
    i have a merona watch too. i found wire brads in my garage, then pounded out the pins partway. then i put the end of the pin that was sticking out into a vice grip and pulled the pins out. then remove the link, and use a small hammer to put it back in place. it might take a while, but it works.
    Dec 26, 2009 | Watches
    Can't set inner dial on merona watch
    You just remove one of the links. I don't think there's a way to set the inner dials. I think it's just for show.
    Oct 04, 2009 | Watches
    Bulova Watch Logo
    Top Bulova Watches Experts
    Geoff
    Ansel Alberto
    Ansel Alberto
    Are you a Bulova Watch Expert? Answer questions, earn points and help others
