Question about GE Microwave Ovens
Microwave only runs with door open (!?)
I have a GE microwave that only runs with the door open, or the latch held in and the door held closed. Interlock, monitor and latch swtiches test OK. There is some charring around one of the interlock switch terminals. With just the door closed, the timer counts down normally, but the oven does not operate.
  • GE Master
  • 9,085 Answers
"There is some charring around one of the interlock switch terminals"
You have a bad connection. The connector and the switch it goes to should be replaced.
Our help file on door switches is here.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on Jan 10, 2013
2 Suggested Answers
  • 4088 Answers
SOURCE: Sharp Microwave stopped working. lights up, counts down. Fine'
High voltage power supply for the magnetron is likely problem. Multi-thousand-volt section--be careful.
Posted on Jul 12, 2009
My GE Microwave Convection Oven model JE 1390WV runs whenever the door is open. It microwaves on the normal settings, but when the door is opened it turns on and runs.
DO NOT USE IT!!!! THERE IS A SWITCH IN THE DOOR LATCH THAT NEEDS TO BE REPLACED.
AGAIN DO NOT USE IT!!!! IF ITS RUNNING WITH THE DOOR OPEN YOU COULD DO SERIOUS DAMAGE TO YOUR HAND OR ARM IF IT IS NEAR THE OPEN DOOR
Sep 19, 2017 | GE Microwave Ovens
Fix my ge spacemaker microwave door from wiggling at the door hinges (not the latches)?
http://youtu.be/nIdT4kS3noY This link will show you how to gain access to the problem. Sounds like a lose screw or two
Jan 03, 2015 | GE Microwave Ovens
GE Countertop Microwave Oven Door is stuck closed
Remove the cover. You should be able to access the two latches and release them. Once open you will have to take the door apart and repair the latch
May 05, 2014 | GE Profile Spacemaker Over-the-Range...
Microwave oven will not start but the light stays on even when door is open.
One of the micro switches in the door is stuck ( faulty ) there are normally 3 switches so after removing the lid open and close the door and you will see the door latches pressing in the button of the micro switch and one of them would indicate that one of the switches is not in line with the latch to press the button in or one of the micro switches has melted inside cosign the switch to release normally open or normally closed, you need a multimeter to test the switches in that case
Oct 07, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
My GE 1660 profile microwave oven will not cook or rotate, but the timer reduces in time. I have tried to gently press up or down on the door in case it is a door latch issue with not change. Also it keeps...
Check the door safety interlock switches. If they are burned (because you frequently open the door while the oven is running) they tell the magnatron that the door is open (forget what you know about the door) and not to run that magnatron (which produces the microwaves that actually heat the contents of your oven).
Check the switches with a ohm meter. Remove the cover to find the switches near the door latches.
Thank you for your interest in FixYa.com
Dec 26, 2009 | GE JE1660 Microwave Oven
GE microwave Model JVM1650SH01 innternal fan runs continuously
Check the door switches-I think you will find one or more either bad or not being contacted with the door latch.
Eric
Jun 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL1800 Micro fan won't shut off after light burned out
The problem appears, at least in part, to the door latch circuitry which cannot be serviced by the owner. If the unit is still in warranty, call GE customer care. If not, replacing the unit is your best bet. I just bought a new GE 1100 watt oven with great features for less than $100 If the door dosen't latch correctly, you could be exposed to dangerous microwave energy.
Ray
Nov 15, 2008 | GE XL1800 1100 Watts Microwave Oven
Door will not latch
The door switch mechanism is broken. Microwave doors have a special arraingement of double switches to ensure it is not open during cooking. Because everything is made from plastic nowadays, stuff like this breaks easily. The switches are commona nd cheap but the mounting parts may not be.
Dec 28, 2007 | Panasonic NN-T774SF Microwave Oven
Microwave Ovens Logo
48 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
