Question about Microwave Ovens
How to replace light under kenmore microwave
I tried to replace the light under microwave (Kenmore 721.80042700) but when I couldn't figure out how to take out the bad bulb, and then I think I made the mistake of tugging at it, and just the glass part of the bulb came out. It didn't seem like it was a bulb I could easily unscrew. Help please! Thanks!
  • Microwave Ovens Master
  • 9,098 Answers
This is pretty common and can be a pain. It's tacked in place with contact cement or hot glue, and sometimes there may have been enough moisture to corrode and seize up.
Number one, be sure to unplug the oven!
You could heat it up (hair dryer, maybe?) then use needle nose pliers. Be careful if heating so you don't burn anything.
You may be able to put the tips of needle nose pliers inside the broken bulb's socket, gently but firmly force the pliers jaws apart and then rotate the pliers to loosen it.
Another cool trick is to put a big glob of hot glue on the end of a stick or dowel, then shove it into the broken base and let it cool about 5 minutes, then turn the stick.
I like to put a little WD-40 or rust buster on the threads of the new bulb, too. Grease, Vaseline, cooking oil, or anything like that will work. Just a thin coat.
Posted on Jan 10, 2013
  • natalielum
    natalielum Jan 10, 2013
    Thanks for the advice! Got it out and replaced the bulb- thanks!
MicrowaveSvc
  • 9098 Answers
SOURCE: kenmore microwave range hood model 665.61612100 manufactured 2001
The problem is likely on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Oct 22, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: kenmore microwave model 721.62644200
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 20, 2008
  • 3 Answers
SOURCE: kenmore galaxy model 721 microwave hood combination
You put a mounting plate on the wall behind where the unit will be mounted. Then the microwave hooks onto the bottom of the mounting plate and you swing it up to the cabinet above it. Then you must screw 2 mounting screws through the floor of the cabinet above into the bracket on top of the microwave.
Posted on Jul 01, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Interior Microwave Light does not work
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number 721.63664300 at the Sears parts site.
Posted on May 12, 2009
Kenmore microwave nights light don't work.
That's a problem on the circuit board which can be repaired simply and inexpensively.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Nov 30, 2012 | Kenmore 62622 Microwave Oven
Http://tinyurl.com/yzjozk
i think your bulb fused because you change it without unpluging and the current\
directly hit the filament.
you should buy new one and try it again and remenber that you shoul unplug it first.
Dec 28, 2011 | Kenmore 62702 Microwave Oven
I just bought an 1100 watt microwave oven from K-mart and when I opened th box there was no manual in the box. The microwave number is 66222. how can I get a manual
Many Kenmore appliance manuals are available from Manage My Life. com . The Kenmore 66222 manual is here: http://www.managemylife.com/mmh/owner_manuals/23454/KENMORE-Countertop-Microwave-L0520944?brand_name_search=Kenmore+66222 . A printed copy is available from Sears Parts Direct: http://www.managemylife.com/mmh/owner_manuals/23454/KENMORE-Countertop-Microwave-L0520944?brand_name_search=Kenmore+66222 . Scroll down for the manual; it's the fourth from the bottom.
Unless the microwave was labeled as a refurbished or open box unit, I'd contact K-mart customer service and see if they'll send you a replacement manual before you order one.
I hope this helps.
Jul 15, 2011 | Kenmore 66222 Microwave Oven
My built in microwave stopped cooking. The light & turntable continue to work however. Help?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';
Jun 07, 2011 | Kenmore 62622 Microwave Oven
The light went out an the turntable won't stop when I close the door...i tried to push clear, but it still turns. I couldn't find my model number on the below pull down, but my model is 721.8001...
721.80019401 (without spaces) is the correct model number.
If it was the cooktop lamp(s) that went out, I would suspect that it shorted, damaging the control circuit board.
We see and repair this problem on a regular basis with our $39.95 repair service.
Or you can order a new control circuit board (part number 6871W1S354A) for $75.80 from the Sears Parts Direct Web site.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
May 24, 2011 | Kenmore 80012 Microwave Oven
Microwave turntable not turning, not heating up I have a fuse to try to replace, but don't know where it's located. Model # is 565. 69421
heatman101 ,./';';
May 21, 2011 | Kenmore 63252 Microwave Oven
MY KENMORE MICROWAVE OVEN MAKES LOT OF NOISE WHEN STARTS.
heatman101 ;
Apr 19, 2011 | Kenmore 62622 Microwave Oven
Microwave will not heat. kenmore model 363.2450MHz
heatman101 ';';
Apr 16, 2011 | Kenmore Microwave Ovens
I have a 2005 kenmore microwave over the counter hood type. stop getting hot. clock,timer and everything else works
heatman101 ';
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
