Question about Acer Aspire Z3731-UR21P
Acer aspire Z3731 no sound but sound bar moves up and down
Second time this has happened. First time under warranty and returned. They said loose wire and fixed it and it was fine. Now 6 months later same thing. Suddenly no sound. If I put something on from You tube I can see the sound bar moving up and down but no sound comes out.
priyabrat
  • 123 Answers
SOURCE: Monitor screen is off center
Adjust it on your monitor they are not all quitte the same but there must be a button there.Use adjust horizontal if you can find it.
First find your Monitor manual.Then find where it mention something about HorizSync and VertRefresh.
Next open the terminal:
Code:
sudo gedit /etc/X11/xorg.conf
Go to the Section "Monitor"
and add the correct HorizSync and HorizSync
CAUTION: Make sure it's correct it can damage your monitor if you use incorrect numbers!
save and exit. Reboot.
Eg. Mine looks like this:
Code:
Section "Monitor"
Identifier "DELL P992"
HorizSync 30.0 - 107.0
VertRefresh 48.0 - 170.0
Option "DPMS"
EndSection
Another way is to backup your /etc/X11/xorg.conf
Posted on Jan 26, 2008
topshy
  • 19 Answers
SOURCE: Acer Aspire 5720Z Notebook - Screen flickers, goes blank then comes back on when screen/lid is adjusted
In most cases like that,where we have screen flickering,first look at the graphics card maybe the signal flex from the back of the screen is well fixed on the motherboard.then if it is well fixed on the board you will need to look at the signal board at the back of the screen maybe it is well fixed if it is not well fixed then fix it properly to solve ur problem then if the problem still persist then u will need to disable the VGA in device manager.to get to device manager u will need to open my computer and after that, u can right-click on it and then click on propertise then click on hardware and then click on device manager where u can disable the VGA.
Posted on May 29, 2008
SOURCE: white screen problem in acer aspire 4710
You will have to disconnect and reconnect the video signal plug located under the upper cover (the one with the power button on it). Best you start with a screwdriver in the very corner).
See also: http://blog.shimpossible.com/2007/07/18/white-screen-of-death/
Additionally I removed a small magnet located under the lid cover (remove 6 screws under rubber placers and lift the lid), which I found next to the video cabling. This could have affected the video signal negatively. Lets see how long this fix lasts.....
Posted on Dec 26, 2008
SOURCE: Acer Aspire 5100 PC Notebook BIOS: "Fixed Disk Failure 0200"
I had the Error 0200 problem. First the existing hard drive started to play up, so I replaced it with a new 250GB drive. I started getting the 0200 issue after installing the new drive. I wasn't sure what the problem was, I started to wonder if the old drive had been fine. I took out the drive, and opened up the rest of the covering on the laptop to clean it. I found some fluff around the fan, so cleaned this away. Still the problem existed. I was about to give up thinking it was a motherboard problem, when I came across an article where someone mentioned that taking the hard drive out of it cover fixed the problem. Rather than take the drive out of the casing, I loosened the 4 screws holding the hard drive. I put everything back together, powered it up, and it has now been running for 14 hours continiously without any problems.
Solution, If you have replaced the hard drive, don't tighten the screws holding it in the caseing too tight.
Posted on Jan 13, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Power cord cuts in and out
There are two places the trouble can be happening, at the adapter plug or at the power jack in the laptop. To determine which one is causing the power loss, hold the plug in the computer steady with your fingers while you wiggle the adapter cable. (If you have access to a voltmeter you can measure the voltage at the plug while you wiggle the cable to see if remains steady.)
If the charge light flickers it's the adapter cord that's bad. Because the wire flexes so much at the plug, it can break inside the insulation and cause the power loss. You either need to replace the adapter or repair it by cutting off the bad end and installing a new plug.
If the charge light remains on with the plug held steady but flickers when you wiggle the plug itself, the trouble is on the main board in the computer. The solder connections at the power jack have broken from the plug flexing and need to be repaired. This involves opening up the computer and getting at the solder side of the main board. It's tedious but relatively simple. If you are not experienced with soldering on small electronics, leave this to a professional shop.
Posted on Apr 23, 2009
Sound not working ; how do I remedy this?
Make sure you have the correct driver for the operating system you are using. If not look it up at the manufactures website and get the correct driver for that
Mar 18, 2014 | Acer Aspire Z3731-UR21P
Hi I want to upgrade my z3731 Ram but don't know
Dear craig_hep935,
Please visit this Link their you will get a video link on left middle side of the page demonstrating how you can upgrade your aspire z3731.
http://www.crucial.com/upgrade/compatible-memory-for/Acer/Aspire+Z3731/list.html
hope this will solved your confusion
Enjoy
Jun 17, 2011 | Computers & Internet
Computer heats up and shuts down
I would suggest you open the notebook by yourself and clean it from dust. I had an Acer notebook that shut down very often because it had so much dust inside that it overheated.
Jul 23, 2010 | Acer Computers & Internet
We got the Acer aspire one a week ago, registered and got started. Everything was fine, then I went to get on it and there is a windows screen with a bar moving and it will not proceed to the desktop bar...
Sounds like your stuck on the Loading screen for the OS. If you bought it one week ago contact customer support or return it and get it fixed. You could easily do this by reinstalling the OS but you should have a professional do it since your waranty for a year should be up from the maker.
May 06, 2010 | Acer Aspire AM5641-U5520A PC Desktop
My mouse pad and keyboard has stopped working on a brand New Acer Aspire 5515 I have only had it for 3 weeks and used it 4 times.
I suggest that your laptop is still under warranty, and you should return it to the supplier to have ot fixed or replaced. If you try to fix it yourself you will possibly void your warranty.
Jul 17, 2009 | Acer Aspire 5610-4648 Notebook
Black, cannot boot up... etc.
Try taking out battery and plug in power. If it works, battery is faulty.
If not, try taking out your hard disk plug in power, if it works, hard disk is faulty.Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Jun 02, 2009 | Acer Aspire 5520-5908 Notebook
Acer Aspire one keeps freezing
I have this too except i have had it 7 months and i just had to clear off about 50 viruses and then this shows up and really bugs me. On mine it happens whenever i click on something or 2 minutes after start up any help??? it is very irritating and is out of warranty
Feb 01, 2009 | Acer Aspire One PC Notebook
Acer Aspire 3680 screen problem
dropping a laptop doesnt mean that damage will happen instantly, alot of the time it will take a while for the damage to come into affect, it could be that the screen has become loose from its connectors, i wouldnt recommend you do this youself, LCD's are very flexible and can break easy, if it is still under warranty ring acer and ask, even if it is not, ring acer and they could advise on a action.
Feb 05, 2008 | Acer Aspire 3680 Laptop
Acer Aspire Z3731-UR21P Logo
108 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
