Question about Samsung LN-T4665F 46 in. LCD Television
I've a CPTEC plasma TV, with half of the screen black
I've a CPTEC plasma TV, Don't know what model is though... It's pretty old, but I got a problem... sometimes, half of the screen just goes black and I can't see that half anymore except if I restart the TV!
zjut
  • 106 Answers
SOURCE: Half Screen went black
Try to replace the Logic board.
Posted on Jan 04, 2008
  • 118 Answers
SOURCE: Samsung Plasma TV - picture has 6 sections of horizontal lines
All I can say is when you watch T.V. the plasmas run off of plasma gas and when you leave something on for so long it burns in the screen. I have the same T.V. and when watching like the weather channel it leaves lines but they go away. If yours are permanent then you can't do anything, but it may help if you go on your remote and go to "menu" then look for "setup" and scroll down with the arrows on your remote. Look for "screen burn protection" and select "white screen". This will make your whole screen white and it may take out the lines. If you let it sit white it won't hurt it. All one color won't hurt, the only thing that hurts is like bright white lines in front of a dark background. Just give your T.V. a break from time to time ESPECIALLY ON VIDEO GAMES. T.V. shows that are HD usually have their channel icons that move or are very dim and they won't hurt. Just go to what I told you and let it sit about 20 minutes, if that doesn't help, then the T.V. you have i believe comes with a 2-year standard warranty and if it's under warranty take it back if you have the reciept. If no reciept then call 1-800-SAMSUNG.
Posted on Jan 30, 2009
  • 12 Answers
SOURCE: 42 inch samsung plasma screen is half blacked out
the problem lies in the y or x board just replace the on thats acting up and you should be ok
Posted on Feb 07, 2009
  • 58 Answers
SOURCE: Black stripe down TV plasma screen
if your TV is still under warranty, call Samsung to get it fix. I seen this problem and is quite expensive to repair
Posted on Jun 15, 2009
toddthetvmd
  • 101 Answers
SOURCE: my plasma, bottom half of the screen is black
Hi, It is your lower Y sus Buffer. Runs about $80
BN96-03362A Y main buffer lower.BN96-03361A Y main buffer upper. Encompasparts.com Also try Shop Jimmy, And Ebay. Sometimes they are lower in price.
Posted on Oct 31, 2009
My LED TV has the picture in two equal vertical sections with the right one having lower black level and that is for all inputs and even with no input , the black screen is half black and half gray
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size. Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Nov 21, 2016 | LG Televison & Video
I have a LG 50" Plasma TV #PDP50H30022 the top half of the screen is black. The screen is not damaged. I tried reseating ribbon cables on upper buffer board. Does anyone know what might be the cause?
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size...
Jul 30, 2016 | LG Televison & Video
How do I connect my hp laptop to my lg LCD tv? I've tried plugging in the hdmi cable to both but my tv keeps sayin ' no signal' please help meeee :(
you need to select the screen you can use because most of laptops don't support to use both screens(laptop screen & monitor / plasma tvs that have VGA port) at once.. you can select your screen by check on F function buttons on your keyboard ...you can identify that button easily because it shows two screens on it just press that button you will choose the screen you can use.
Mar 06, 2012 | LG Televison & Video
After awhile my t.v. has been on, half the screen will go black. How do i fix this??
May I know what portion on the screen turned to black, is it top half, bottom half, left/right side. Also please confirm if your TV's model no. is 50PQ30C, it is printed at the rear panel, manual, and receipt.
Dec 15, 2011 | LG 50PQ30C 50 in. Plasma TV
46in Vizio LCD HDTV distorted black picture when tv is turned on
Hi There are three things that can cause this problem. Your lcd screen, t-con board or the signal board. Most likelly in your case since you say it's only half the screen it's going to be your t-con board. You can try removing it and cleaning all the contacts and replacing it see if that helps. If that doesn't help then replace it. If that does not solve it then it's going to be your screen.
You can get parts at www.interliquidparts.com
Nov 28, 2011 | Vizio VW46LFHDTV10A 46 in. LCD TV
I was going to get a plasma TV specifically the Samsung PN50C6500 and i was wondering if the whole thermal expansion controversy problem was over and samsung had become more reliable and this problem had...
No,don't buy plasma tvs any tvs make or tvs brand.Don't buy any kind of tvs using plasma gas as for plasma screen panel as a power sourced if u play major hours of gaming on the plasma tvs,u will still have thermal expansion problems but less.Plasma tvs still have major problems,with screen BURN IN problems though.
Aug 22, 2011 | Samsung PN50C6500 50 in HDTV Plasma TV
Black screen w/ my sony bravia KDL-40V4100 and it will turn on, but there is no picture or sound. I was told it could be a possible issue w/ the kdl 40s4100 board, but I'm not entirely sure. I've...
If you wish to get some details; visit the site linked here. Pull up older posts.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 10, 2017 | Sony Bravia KDL-40S4100 40 in. LCD TV
47" plasma 1080p ... screen went black , sound
Plasma TV's have a shelf life. By that I mean the screen is only good for so many hours depending on the model. Most likely, you have burnt out the screen and the set will need to be replaced. The good news is, plasma TV's used to be better than LCD but that is no longer the case. You can get a very high quality LCD TV for a very low price now. Also they use a fraction of the power and don't generate all of the heat of a plasma.I'm sure this is not what you wanted to hear but the reality is that ALL plasma TV's do this eventually, and it is something that most salesmen back in the day didn't bother to tell customers. If you have an extended warranty, you may be able to get it replaced.
May 05, 2011 | H&B HP5500V Plasma TV
Tv flat screen only half the screen works rest is black
This is casued by the buffer boards on the right or left edge of the plasma tv. You need a direct replacement for the top buffer and then your picture will return!
Please rate if this helps!
Parts are found on ebay or shop jimmy
Mar 07, 2011 | Sony 50 in. Plasma TV
I HAVE AN LG PLASMA TV APPROX 7 YEARS OLD HALF THE SCREEN IS BLACK?
Deal with this problems before.Sorry,tv some how the plasma screen itself,it is shorted and plasma screen it is dead.This problems ur tv have it is nothing to do with it elctronics boards problems.This tv it not repairable except by replaced the whole plasma screen as u know the screen are 90% important to tv and in limited in production by the tv corporation.Nowhere to buy the screen,but except the tv corporations themselves.By replacing the plasma screen,will cost the same as a new tv.
Feb 12, 2011 | LG 42PX5D 42 in. Plasma HDTV
Samsung LN-T4665F 46 in. LCD Television Logo
109 people viewed this question
Henry  Thomas
Henry Thomas
