Question about Mitsubishi 4 Fuso Truck Fe 2005 / 2008 Air Filter
05 fe fault codes
P1630 p1635 p1335
My 03 santa fe sometimes will not start as if the diesel is not getting to the engine any thoughts
most starting problems with diesels can be sourced to
low fuel pressures( pressure draining off over time), air in the system, glo-plugs not working and slow cranking speeds
run the fault codes first to check for possible electronic and sensor faults
take it to an accredited diesel shop and have the fuel system and fuel pressure checked
Apr 22, 2016 | Hyundai 01 02 03 04 05 06 Santa Fe Air...
Where is immobiliser
Where is the immobiliser box on a 1999 landrover freelander
Jan 05, 2014 | Hyundai Used 01 02 03 04 05 06 Santa Fe...
Mitsubishi fuso 2008 check engine light
Hello
When the service engine soon light (Also called the check engine light) is turned on this is to alert you to the fact that powertrain control module (computer) has detected a failure somewhere in the systems it controls, this can be the transmission or the engine or emission system, there are fault codes set in the modules memory for these faults. What needs to happen now is to have the powertrain control module scanned with a special tool called an OBD2 electronic engine control scanner or a OBD2 code reader. Once the code(s) are read then you must perform the diagnostics for each code and make the appropriate repairs based on the findings of the diagnosis that was performed, this is called doing "Pinpoint" testing.
Jun 23, 2012 | Mitsubishi 4 Fuso Truck Fe 2005 / 2008 Air...
Culligan Air Purfication System Blown Fuses
Check for an earth fault or short circuit. Most likely fan seized.
Apr 10, 2012 | Air Purifiers
WILL NOT START....NO POWER? BOUGHT AT SEAR JUNE OF 2010. HONEYWELL MODEL 17000
Make sure that the receptacle that it's plugged in to is still working. The circuit breaker for that outlet may have been tripped in your home's circuit breaker panel. Or there may be a loose wire or bad connection inside the outlet box. May not be air purifiers fault at all.
Mar 29, 2011 | Honeywell 17000 Air Purifier
Mitsubishi 4 Fuso Truck Fe 2005 / 2008 Air Filter Logo
Top Mitsubishi Air Purifiers Experts
Andrew Taylor
Andrew Taylor
richie46
Rob
Rob
Are you a Mitsubishi Air Purifier Expert? Answer questions, earn points and help others
