Question about Microsoft Xbox 360 Console
XBOX had no power, so I found and repaired bent USB port pins, then the XBOX came on with three red lights. Any DIY repair possible?
XBOX had no power, so I found and repaired four bent USB port pins, then the XBOX came on with three red lights. Any DIY repair possible?
    Problem Solver:
  • 13 Answers
Thanks for your question. To fix the 3 red lights what you will need to do is stop the heat getting to the GPU and the CPU and to do this you can use a good Xbox 360 Repair guide or of course you can send it in to microsoft.
Posted on Jan 24, 2013
SOURCE: controller port usb pins are bent
is it in the warrinty / do they cover it
Posted on Feb 22, 2008
  • 8 Answers
SOURCE: Xbox 360 red light four red lights on the front of console
Yes you can fix it. Four red lights on is an indication that the video cable is not plugged into the console. I suggest you check and see if the pins in the cable and unit are not damaged and the cable is fully in the AV port. If all is well, than borrow another cable from a friend and try it in your console or try yours in theirs.
Ron
Posted on Apr 30, 2009
  • 10 Answers
SOURCE: Scratched Xbox 360 motherboard
Im sorry but this is the equivelant of a car being written off. It cant be fixed, simple as that. If it is possible to be fixed, it would work out cheaper to just buy a new one
Posted on May 20, 2009
  • 1019 Answers
Usually if a motherboard has been scored or damaged.
( tracks or resistors/capacitors dislodged et,c )
The board is in the Bin. ( scrap ) unless the damage can be repaired. The RROD Or red-ring of death. Is usually due to the x-clamps fitted to the console initially, by the manufacturer.
Replacing the x-clamps, with a kit ( bolts/washers thermal Compound ) And 4 x heatpads recommended. Can cure the RROD. And in my own experience the 1 red light And E74 error.
Bottom line, if the boards scratched. it,s in the Bin.
Mike @ Compurepair.
Posted on May 30, 2009
  • 22 Answers
SOURCE: my xbox 360 will not turn on but the power block light is orange
There can be a number of reasons for an Orange light on the Power Adapter. Here is the official link to MS help:
http://support.xbox.com/support/en/us/nxe/kb.aspx?ID=906102&lcid=1033&category=hardware
Hope this helps.
Posted on Jul 21, 2009
Lenovo USB port bent pins
The USB port/socket needs to be replaced it cannot be repaired.
It is not an easy DIY job, you need to take it to an IBM laptop repair center or a laptop repair shop.
Aug 25, 2012 | IBM Lenovo ThinkPad T400 (2767P6U) PC...
My 360 won't power up. Orange light on power supply. No extention cord, changed wall plug, bought new power supply, removed face plate and nothing changed.
Have a look into the usb ports on the front right of the console, look for any damage or bent pins, if any pins are touching this will cause a short, so the console will not turn on.
Or it could be an internal resistor problem, which would be best looked at by a pro repair center.
Mar 22, 2010 | Microsoft Xbox 360 Console
Tried to turn on my Xbox 360 today and it's dead. It will not come on. What type of problem is this and how can it be fixed?
This could be something simple, or something terminal,
If you are using a play and charge kit, remove the cable.
What is the status of the power pack?orange light good, red light means the power pack has overheated, let it cool, then make sure it is well ventilated, if it stays red, you need a replacement.
It could be a bent pin in the usb ports, have a check, if any are touching bend them back.
If its non of these, you may have a resistor problem, I can tell you which ones, but if you don't know what you are doing, you are best to get it repaired professionally.
Remember to thumbs up if this helps.
Mar 05, 2010 | Microsoft Xbox 360 Console
Xbox wont turn on and all of the cords are in
1st check light on power brick, red means it has overheated, let it cool and give it more ventilation.
2nd are you using a play and charge kit, if so remove the cable, this happens with mine sometimes.
3rd look into the usb ports on the right hand side under the big flap (this is easier if you remove the faceplate) look for damage or bent pins this will short the unit so it won't turn on, just bund any pins back.
4th it may be a resister fault, you would be best to book a repair with a professional repair centre.
Remember thumbs up if this helps.
Feb 02, 2010 | Microsoft Xbox 360 Console
Hello, trying to help repair an xbox 360 with no power. While I know the power supply is good! On n off switch is good! Tried pressing eject button but still know power! Power supply light is orange. Do...
This sounds like it could be one of the usb ports,unplug the console and remove the faceplate, see if there is a bent pin, this will short out the console, just stop them touching the console will work.
Let me know if this helps.
Jan 15, 2010 | Microsoft Xbox 360 Console
Console won't power on
check the date of manufacture on the back of the console and if its less than 3 years old register it with microsoft,l once you have done this contact them about your console and tell them it has the red ring of death
they will send a courier free of charge to pick it up and then repair it for you free also.
www.microsoft.com
Nov 19, 2009 | Microsoft Xbox 360 Console
Power cable light is orange and xbox 360 wont turn on
try checking the usb is it damaged? the pins in the usb may be shorted to ground..pry any pins up and the system will work..this happened to me.
Jan 02, 2009 | Microsoft Xbox 360 Console
Xbox360 and the 3 red lights
Three of the lights on the Ring of Light on the front of your Xbox 360 console flash red View products that this article applies to. if (!loadTOCNode) {var loadTOCNode = function(){}} Expand all | Collapse all if (kb_page_object) { kb_page_object.kb_imageExpandHoverText = 'Click to expand this image'; } SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Dec 06, 2008 | Video Game Consoles & Games
Three red light error
contact MS if your box is still under warranty(3 year for 3 red light)
or buy a xclamp replacement kit to fix it your self.
Repair Kit
Sep 06, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
55 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
