Question about Maytag Refrigerators
Msd2352kew door handles loose
3 Suggested Answers
SOURCE: LOOSE DOOR HANDLE whirlpool frige GC5SHEXNQ00
Pulled the handle up to release it from the clips on the door. The screw in the plastic door handle that attaches the handle to the door clip was striped. I used a small amount of J B Weld epoxy to repair and reattach the screw. Realign the handle with the clips and push handle down to reinstall.
Posted on Jul 30, 2008
mc1bean
  • 3053 Answers
SOURCE: side by side refrigerator, handle
Hello, mark
I am trying to help you out here. Maybe this will help some? I am know on Fixya as the cleanup expert pro. Which means I spend my own personal time to seek out customers that maybe have not had there problem yet solved. I do this on my own for free. Think of me as a Specialized Trouble Shooter.
I have found out that it appears that lots of customers appreciate my efforts and help. So, I thought I would take some of my own personal time
to see if I can help you. Even though this Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about refrigerator and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/how-to-repair-a-refrigerator.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just try to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Posted on Oct 31, 2011
How do I repair of loose door handle on rerigerator ge model 20?
I believe the door handle slides up after you get the screw out
Mar 02, 2018 | Refrigerators
Bosch refrigerator door handle is loose
there is only one screw on the handles from what i found out from fixing my loose handle. the bottom of the door handle has one screw. once you loosen that one up then you lift it and it comes out at the top enough to slide the handle out and tighten it.
Aug 03, 2014 | Bosch Evolution 800 B20CS80SNS Stainless...
Inside door handle is loose. how to fix handle on my 2003 kia Sedona mini van?
you need to open the inside door and check for loosing screws or anything that looks loose or out of place
Oct 11, 2013 | Kia Sedona Cars & Trucks
Side by side refrigerator, handle is loose. Top right hand screw is out of the door. It seems that part of the handle should snap off to allow access to screw back into the door, but I can't get this...
Hello, mark
Sep 15, 2011 | Maytag MSD2756G Side by Side Refrigerator
Sub-Zero 601R door handle is loose
My Sub is a 650S. Not sure your handle assy. is the same or not. But each of the 2 attachment points have a small 3/32" set screw on the bottom of each short piece between the vertical handle and the door. These set screws grab onto posts that are screwed into the door. There can be 3 points where the handle can work loose.
1. The set screw(s) have backed out and not holding tightly onto the door studs. 2. The studs in the door are loose and need to be tightened with a screw driver. 3. After loosening the handle via the set screws, when you look back into the cavity vacated by the studs from the door, (pivot handle clockwise past edge of door) you will see a Philips-head screw that secures the spacer to the handle. If the spacer is loose, tighten it with screw driver. Then mount back into door stud and tighten set screw. Problem Solved. Have a beer!!!
Nov 26, 2010 | Sub-Zero 601R
The driver's side outside door handle is loose, toyota celica '95
I assume that the entire handle unit is loose in the body work of the door.
The interior door trim will need to be removed to access the inside of the door to fix the loose handle.
Do not attempt his yourself unless you have some experience in this area.
Take the vehicle to the nearest reputable auto body repair shop and they can easily fix it for you. There could be a breakage on the retaining system on the handle or the retainers may just need tightening.
Typically door handles which have not been subject to damage or abuse will not usually loosen like this. It's possible the door was damaged and the panel repaired and repainted at some stage. If so the door handle may have been removed and refitted in a sloppy manner.
Dec 03, 2009 | 1997 Toyota Camry
Loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Apr 12, 2009 | GE Profile Stainless Bottom-Freezer...
Door handles loose
i have a whirlpool conquest side by side and had loose handles,couldn't figure out.but then i grabbed handle and push in and up,handles slide off you can then tighten bolts then slide it back on.hope this helps.n
Oct 14, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Jul 29, 2008 | Refrigerators
Loose Door Handle
There is no adjustment for the door handles.  The brackets are metal pressed and if they become loose, it is recommended that they be replaced.
Mar 25, 2008 | LG LRFC22750ST French Door 22.4 Cu. Ft....
Refrigerators Logo
21 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
