Question about Whirlpool Refrigerators
WATER UNDER CRISPER DRAWER MODEL ET8MHKXMQ04
HOW TO FIND DRAIN TUBE
  • 93 Answers
SOURCE: How do I find the drain hose/plug on a 1996 kenmore refrig.
if you open the fridge door in the top you will see a small funnel typy that goes tru your back wakk this is where it normally cloged pull it out if no screws that hold it then clean it out or blw tru hose in the back of fridge if you can get access to it thanks from gille
Posted on Mar 15, 2009
wheelshot
  • 102 Answers
SOURCE: Water draining under crisper bins & onto shelves. Try again
Your drain tube is stopped up. Take the panel off in the freezer section and chip away the ice in the pan below the coil. When you get to the drain hole pour hot water in it until it free flows. You will need a towel in the freezer to catch the excess water. Run some extra hot water through it to assure that you clean the drain out good.
Posted on Apr 01, 2009
  • 531 Answers
SOURCE: water build up under crisper drawer
clogged drain line
Posted on Apr 07, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Water collecting under crisper drawer at bottom of
There is a leak somewhere in your defrost drain. Most times this is caused by a blockage near the area of the leakage. Below is a link to a very informative way to help you resolve the problem. Thanks.
http://appliancejunk.com/forums/index.php?topic=22.0
Posted on Jun 28, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Samsun RS265LA Water is under crisper drawer
Sounds like the typical defrost condensate line is stopped up and every time your refrigerator goes into defrost instead of water following the drain tube to the pan below your refrigerator where warm air blows over the water and returns it back into the air inside your home. This is a common problem that happens. Sometimes just the refrigerator leaning to left or right will begin the problem. Other times the tube gets backed up because of slime an crud and begins slowing the drain flow down to the point it backs up and spills over into freezer or fresh food compartment. Every refrigerator is a little different so click here=> REPAIR OF LEAKING REFRIGERATORS and scroll down to near bottom of page. Read and watch the You Tube movie clip and other material and if you have more questions ask. You may need to remove the rear panel in back of the freezer compartment or if your brand has dual evaporators you may need to go into the rear of the fresh food compartment. Not every Samsung has dual evaporators. here is your Service Manual=> RS265LA It does appear that you have two evaporators on your model. Look this may take a wet and dry vacuum and Clorox with warm water and once the drain is cleared you will not need to do this often. On page 17 is a view of the two evaporators. Watch the movie at the link above and it will be so much easier. Contact me if you run into problems. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Posted on Mar 14, 2010
I have a problem with my Samsung model no. Sr-L628EV water gathers under the chiller drawer, any idea?
Not familiar with this particular model, however it sounds like a plugged drain. Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged with gunk, resulting in standing water at the bottom of the refrigerator. (A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer).
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Try c
learing the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ΒΌ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
Jun 12, 2017 | Samsung Refrigerators
Water in crisper drawer of Whirlpool model number ET18TK
the water in the bottom of the fridge will be from condensate running down the back wall and not collecting in the drain ridge to flow outside to the dish on top of the compressor. It comes from overloading the fridge by opening the door too often and excess food trying to cool down. check and unplug any blockages in the drain and pull any containers away from the back wall as water will flow off the wall onto them and miss the drain all together. The drain ridge will be under 1/2 way down the back
Dec 25, 2013 | Cars & Trucks
Why is water leaking from the inside bottom of refrigerator?
Hay Lola , your drain hose is clogged open the back panel and blowdry all the ice until the water drains good luck APPLIANCES R EN
Mar 14, 2013 | Magic Chef Refrigerators
Water build up under crisper dwawer
I would check the defrost drain cup located in the frig section on the back wall. Take a large syrenge filled with hot water. Insert it into the drain cup and try and seal it into the drain hole at the rear of the cup. Farce as much hot water into the cup to clear any debris cought in the drain cup and hose assembly.
TIP: insert a short rubber hose into the end of the syrenge to make it more flexable to get into the drain cup.
Dec 30, 2009 | Refrigerators
I have a Kemore 970-651020 and water is collecting on the bottom shelf under the crisper. I have to sponge it out daily. We never put a water line to the icemaker so not sure what is causing this water to...
Hi, The defrost drain hole is plugged inside the freezer. Remove the rear inside panel and locate the drain hole undr the evaporator coil.
Once the drain hole is cleared, flush it with hot water to be sure it is open. Some models require an after market drain heater kit. I tried looking you model # up and it does not show up. Please check the number again so I can see if you model needs the heater.
Vic
Jul 04, 2009 | Refrigerators
Water collects on shelves in refrig.
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Nov 26, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerator
is it collecting under the crisper drawer? if so the drain line for the defrost system might be clogged. find where the drain tube empties by the compressor. blow into that tube. did a bunch of water come out? if yes, prob solved. hope this helps. let me know if it doesn't.
Oct 26, 2007 | Kenmore Elite HE4 Electric Dryer
Refrigerators Logo
46 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
