Question about Whirlpool Refrigerators
WATER UNDER CRISPER DRAWER MODEL ET8MHKXMQ04 - Whirlpool Refrigerators
  • 148 Answers
SOURCE: water and ice in fridge leaking on floor.
you have to defrost the freezer it will take almost a day byitself,but you can speed it up with a hair blower pointed inside the freezer toward the back at the bottom,unplug your fridge and hair blower on low you dont want to melt the styrofoam,put 2 bowls in you fridge top shelf towards the back to catch watr falling from the vents,when you see water come into the pan under the fridge your all set ,clean up water and plug fridge back in,its the drain hose is blocked with ice
Posted on Jul 08, 2008
  • 3 Answers
SOURCE: water accumulation under crisper bins
Check that the hole at the back of the fridge is not blocked with gunge.  There should be a drip tray at the rear with 2 slopes towards the hole where the condensation drains to.  Some cabinets come with a little rod to clear the blockage.  The rod may live in the hole alowing water to drain around it.  Have a peek!
Posted on Feb 22, 2009
SOURCE: water standing under crisper drawers
small drain hole/tube inside (behind crisper pans) is stopped up. Clean out with flexible wire, etc.
Posted on Jun 24, 2009
arikrom
  • 528 Answers
SOURCE: whirlpool refrigerator has water pooling under crisper
  1. take all things out from freezer
  2. open back wall of freezer
  3. clean the drain hole in the bottom middle
  4. put all back
  5. good job you fix it
Posted on Jan 01, 2010
Sea Breeze
  • 4654 Answers
SOURCE: Samsun RS265LA Water is under crisper drawer
Sounds like the typical defrost condensate line is stopped up and every time your refrigerator goes into defrost instead of water following the drain tube to the pan below your refrigerator where warm air blows over the water and returns it back into the air inside your home. This is a common problem that happens. Sometimes just the refrigerator leaning to left or right will begin the problem. Other times the tube gets backed up because of slime an crud and begins slowing the drain flow down to the point it backs up and spills over into freezer or fresh food compartment. Every refrigerator is a little different so click here=> REPAIR OF LEAKING REFRIGERATORS and scroll down to near bottom of page. Read and watch the You Tube movie clip and other material and if you have more questions ask. You may need to remove the rear panel in back of the freezer compartment or if your brand has dual evaporators you may need to go into the rear of the fresh food compartment. Not every Samsung has dual evaporators. here is your Service Manual=> RS265LA It does appear that you have two evaporators on your model. Look this may take a wet and dry vacuum and Clorox with warm water and once the drain is cleared you will not need to do this often. On page 17 is a view of the two evaporators. Watch the movie at the link above and it will be so much easier. Contact me if you run into problems. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Posted on Mar 14, 2010
Water in bottom vegetable drawer and bottom of refrigerator ge profile side by side
This model has two evaporators, so Do you have an ice ball in behind the crisper (should be on the left)? Is there brown looking water going down the back and collecting under the crispers? I need two things, a complete model number (there is 8 different model with this number you gave) also where is the ice and water located? Thanks
Jul 25, 2014 | GE Profile PSW26P Stainless Steel Side by...
Water in left bottom crisper drawer
You need to get a replacement gasket for the make and model of the refrigerator, http://www.fixya.com/support/12355008-water_in_bottom_left_crisper_drawer
Jun 11, 2017 | Whirlpool Refrigerators
Water in bottom left crisper drawer and under drawer
I'm sorry to say that it sound as though your door gasket may no longer be sealing correctly.
For me, it's simply a task of getting a replacement gasket for that make and model.
To remove the old one you would, simply, peel the inside of the gasket toward the outside of the edge of the door revealing the mounting screws. Remove these screws all the way around and replace with the new one in the same fashion...
The reason that I recommend this is that humid air outside of the refrigerator can seep past a worn gasket and condense on the inside surfaces making its way to the bottom and into those drawers.
Feb 16, 2014 | Whirlpool Refrigerators
Water in crisper drawer of Whirlpool model number ET18TK
the water in the bottom of the fridge will be from condensate running down the back wall and not collecting in the drain ridge to flow outside to the dish on top of the compressor. It comes from overloading the fridge by opening the door too often and excess food trying to cool down. check and unplug any blockages in the drain and pull any containers away from the back wall as water will flow off the wall onto them and miss the drain all together. The drain ridge will be under 1/2 way down the back
Dec 25, 2013 | Cars & Trucks
Why is water leaking from the inside bottom of refrigerator?
Hay Lola , your drain hose is clogged open the back panel and blowdry all the ice until the water drains good luck APPLIANCES R EN
Mar 14, 2013 | Magic Chef Refrigerators
67001503 Pan, lg crisper drawer Where can i purchase this please? model XRSS204BW
Hi. You can purchase your large crisper drawer at this site. Click Here to access the purchase page.
Jun 28, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Water build up under crisper dwawer
I would check the defrost drain cup located in the frig section on the back wall. Take a large syrenge filled with hot water. Insert it into the drain cup and try and seal it into the drain hole at the rear of the cup. Farce as much hot water into the cup to clear any debris cought in the drain cup and hose assembly.
TIP: insert a short rubber hose into the end of the syrenge to make it more flexable to get into the drain cup.
Dec 30, 2009 | Refrigerators
Water is forming on the floor. Appears the water is pooling under the crisper drawer, then seeps through the seal. GE TBX 18CI. Any ideas?
You should not have any water at all forming inside the frig compartment unless you have a water dispenser on the frig. The water resevoir is located in the frig compartment at the bottom behind crisper. There may be a small leak or loose water connection on it. Hope this helps.
Jul 24, 2009 | Refrigerators
Refrigerators Logo
54 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
