Question about Regency 4720 4724 4660c
Regency model 4660c users manual - Regency 4720 4724 4660c
Does anyone have any information on the Pine Ridge 500 wood stove? I'd like to know who the manufacturer is and what the EPA specs are.
PDF]installation and operation manual - Wood Pellet Stoves ...
www.pelletking.com/...stove-manuals/whitfield-advantage-iit-pellet-stove...
Services) and the listing mark is Warnock Hersey. Testing: In accordance ... The assembled pellet stove model Advantage II-T C FS and. Advantage II-T C INS ...
[PDF]INSTRUCTION MANUAL - Ignite Dealer Portal - Regency ...
manuals.regency-fire.com/getattachment/.../R12-R14-R16-Manual.aspx
Tested by Warnock Hersey ... LISTED FACTORY BUILT FIREPLACE ACCESSORY HEARTH STOVE ... it is important that you read this manual throughout.
Nov 01, 2015 | Home
I need a regency woodstove model r6 owners manual
I just sent Regency's a request for the same manual via their site but haven't recieved it yet. You could try the same or email me at rogerthibaudeau@hotmail.com and I'll forward whatever they send me. Here's the link :
http://www.regency-fire.com/Company/Contact-Us.aspx
Have a good one... Roger (Wood\gas stove and fireplace installer)
Oct 13, 2011 | Cars & Trucks
I have an Old Regency Toutch K 100 20 CH S1&S2 S1 is 1-10 CH ?? S2 Ch 11-20 is that correct?? or do you also use CH 1- 10 on S2 ??? What is a Code '' d '' It will not scan all 20 Ch only S2, and not...
The K100 is an oldie from about 1980, when Regency was still manufacturing some radios in the USA and importing some from Japan. Below is a link to the manual for the K500, which had more channels & features than the 100, but was a similar radio. There is currently an eBay listing for the K100 manual (pdf) if you want to spend a few bucks.
http://www.repeater-builder.com/relm-regency-wilson/regency-touch-k500.pdf
Nov 21, 2009 | Radio Shack Radio Communications
How to program an old regency 1060 scanner
I'm not too sure about this particular model, but other Regency variations require you to push the "Manual" button, enter the channel number you want to set (usually 01-09 for single digits) and then enter the frequency you want. On some you may need to enter the frequency first and then the channel number.
Oct 11, 2008 | Uniden BC72XLT Handheld Scanner
Manual
That model was the first prototype of the Uniden Bearcat Electra BC780XLT-PPKL88 otherwise known as the BC780XLT. That manual that you got for the XLT model should work just fine, the only difference is that the XLT has more features than the HLT. The HLT came with its own manual, but it wasn't very accurate either, just try to make due with the manual you've got. If you want a scanner that is easier to use, you should get a Regency Touch K500. The Touch K500 can scan up to the 900MHz range and has VHF/UHF/FM/AM/CB/WX/AIR scanning capabilities. It even comes pre-programmed with international channels. It also has an automatic Weather Alert Notifier Bank already programmed into its internal memory. In short, the K500 is the ultimate scanner. However it will be hard to find because Regency went out of business a while back.
Good Luck!
Jun 25, 2008 | Radio Communications
OLDER ICOM RADIO ICBP5 AND A REGENCY U156B
Hi, The Icom radio models start with IC followed by numbers and then letter(s). The BP5 is the model of the battery pack. Pls post back. I'm not familiar with Regency U156B. However, there is a Regency RU156 which is a 16 channel UHF 25watt mobile radio which could either be crystal controlled or PLL diode matrix. Regency was reported sold to the BK Relm Company, which no longer supports older Regency Radio Equipment. There are a few sites on the Internet where you can get hold of a user's manual (some for a fee) like http://www.bearcat1.com/manuals.htm. Hope this be of some help/idea. Post back how thin gs turned up, the Icom model or should you need additional information. Good luck and kind regards.
Oct 02, 2007 | Radio Communications
Regency 4720 4724   4660c Logo
1,265 people viewed this question
Top Regency Home Security Experts
Lawrence Oravetz
Are you a Regency Home Security Expert? Answer questions, earn points and help others
