Cannot open my neat database, it says invalid or corrupt,
I was editing receipts, suddenly this window appear saying that neat is not responding, I logged off. This morning when I loggen in it says that there is a problem opening the database, database invalid or corrupt and cannot be opened
PABLOCSA
  • 1124 Answers
SOURCE: I was about to open
Goto :
http://www.dlldump.com/download-dll-file...
There you'll find the dll file you need. Just copy and paste it in the correct directory.
(usually it will be
C:\Program Files\Common Files\Microsoft Shared\office11\1033\)
Posted on Nov 13, 2008
honest1abe
  • 72 Answers
SOURCE: How can the product key be wrong??
I would be extremely surprised if this turned out to be a valid copy of XP. Shrink wrap is easy to do. Someone has already used your product key which Microsoft has now registered to a different computer.
And yes, when you submit it the message is that it is invalid which means already in use by another computer.
Microsoft never gives the error message "this product code is already in use". They only say it is invalid.
I've installed XP tons of time and even had a few times where the license belonged to another computer. When that happened, the invalid error message is what I got.
I'll make another guess and say you did not buy XP from a computer store, but instead from an individual. A reputable computer store should be able to help you with your problem if you bought from one.
Honest1abe
Posted on Jan 11, 2009
SOURCE: Access Database opening in read only
check the folder type it may be just set for read only. the administrator has the option on the interface to see if the database is read only for others or if it is editable.
Posted on Jan 22, 2009
Astrophel
  • 116 Answers
SOURCE: when opening sidebar windows installer opens .
It is likely some sidebar gadget you've got installed that wants to use bluetooth.
Take a look at the installed gadgets, and see if that makes sense. To administer gadgets (I am assuming the sidebar is not opening properly), but do try to start it, then:
Start
Control Panel
Windows Sidebar Properties
View list of running Gadgets
Remove any gadgets that may cause the trouble.
Posted on Feb 09, 2009
guru_dev
  • 315 Answers
SOURCE: Problem opening Access Database-upgrade from Access 2003 to 2007
It seems that you have your Database(.mdb) file is created in Office 2003.... thats why you are unable to open it in 2007.... I faced the same problem.... then I came back to 2003 in order to use our database......
Posted on Mar 25, 2009
Recover data from corrupt .mdf and .ldf files.
You can find more information here:
http://www.filerepairforum.com/forum/microsoft/microsoft-aa/sql-server/569-i-have-a-problem-how-do-i-fix-a-corrupted-database-file
Open your SQL Server Management Studio console. This application shortcut is available in the SQL Server directory in the Windows Start button.
· Enter the system administrator user name and password. SQL Server's administrator user name is "sa." This account is required for privileges to restore the database. If your restoring on a host provider server, use the administrator user name and password they supplied for your account.
·Right-click your database name and select "Attach." In the new window that opens, click the "Add" button to open a dialog box.
·Select your MDF file and press the "Ok" button. It may take several minutes to restore the database if it is a large file. Once the process is finished, browse your tables to verify the data. The database is now restored.
If nothing helped try to use:SQL Server Fix Toolbox
http://www.fixsqldatabase.com/
Nov 28, 2014 | Microsoft SQL Server 2000 Standard Edition...
Neat receipt scans a black line through part of the page
That's all I got was a black strip. My solution was to get a new Neat Receipts mobile scanner. It works great and I didn't have to make any software changes. It was worth the price for a new one compared to all the hassles I had with the old one.
Mar 29, 2014 | NEAT Receipts Mobile Scanner
Why would my 'copies' be coming out black pages on Neat Receipts portable scanner; prior to cleaning they were heavily streaked with black lines...now totally/heavy black.
A high percentage of scanners that people use at home are made by Visioneer, although they may be labeled and sold by other companies. Xerox is one example. The Visioneer software drivers are sensitive to changes that routinely occur in MS Windows from software installations, updates, etc. On this Visioneer webpage the company says, in describing the problem, "Your scanner does not appear to be functioning normally; you are getting errors when attempting to scan, your images are not easily readable, or you are unable to access the scanner properties." and "Problems may arise after you have made changes to your Windows environment (e.g. you installed Windows Updates, you installed another scanning application, etc...).".
Instructions as well as some software utilities are available for free download on the same page. Of course this won't help if something has actually broken on your scanner, but they're pretty durable, and chances are you can fix it by closely following the instructions from Visioneer.
This answer should apply to several of the questions in this section.
Jun 22, 2013 | NEAT Receipts Mobile Scanner
Setup has detected that the file 'C:\DOCUME~1\Jennifer\LOCALS~1\Temp\VSD335.tmp\SQL Server Compact Edition\SSCERuntime-ENU.msi' has changed since it was initially published.
Hi Remove you Temp file and installation again, now you did not get this error.
How to Remove Temp file
1) Go to Run and Type %temp% and press enter
2) Temp window will open select all and press the delete
Thanks
May 24, 2012 | NEAT Receipts Mobile Scanner
Problems installing Neat Receipts
You need to install Microsoft SQL Server Compact 3.5 Service Pack 2 from MS web site:
http://www.microsoft.com/en-us/download/details.aspx?id=5783
Steps:
1. Download installation package from above link and save them to the desktop or other folder
2. Start that .exe and unpack to some folder on your PC (or that same folder)3. Open that folder and run BOTH installations for Windoxs x64 PC - first start:
SSCERuntime_x86-ENU.msi and then
SSCERuntime_x64-ENU.msi
4. This would install necessary SW and then you could re-insert Neat CD to start the installation which would proceed now.
Mar 06, 2012 | NEAT Receipts Mobile Scanner
HOW TO SOLVE VFP FILE CURRUPT WHEN POWER FAILURE
At times, you may view that your MS Visual FoxPro 9.0 database is behaving abnormally. Some of the abnormal symptoms could be an error message while opening any database table, invalid characters in place of pre-defined values, and and more. The main reason for abnormal behavior of the database is its corruption due some logical crash. Few common reasons for corruption of MS Visual FoxPro 9.0 database are abnormal termination, faulty network devices, simultaneous modifications, conflicting third-party software, and incompatible service packs.
To overcome such database corruption scenarios, the user can use an up-to-date backup and perform restoration. However, restoration fails in cases where the user either forgets to create a database or the database backup itself gets damaged. In such cases, the database users can use a third-party DBF File Repair application to repair his/her corrupted database.
To illustrate the above case, consider a real-time scenario wherein you execute a query to modify your MS Visual FoxPro 9.0 database. While the query was performing the modification, the system shutdown due to power failure. However, the next time you tried to mount the database, you encountered an error message that did not allow you to access the database records. Moreover, the same error message appears every time you try to access the database.
Cause:
The root cause for the error message is MS Visual FoxPro 9.0 database corruption due to improper system shutdown.
Resolution:
The database corruption error message can be surmounted by following the below steps:
Use a complete database backup and perform restoration. However, in case of database backup unavailability, you will need to search for a commercial DBF File Repair utility.
A third-party DBF Repair application uses effective repair techniques to repair logically damaged MS Visual FoxPro 9.0 database and restore it at a new and safe location. The original database during the repair process remains intact. The tool is easy-to-understand and allows even a non-technical person to perform repair.
DBF Recovery Software is a comprehensive solution to repair databases created in MS Visual FoxPro 9.0, MS Visual FoxPro 8.0, and MS Visual FoxPro 7.0. The tool also repairs databases built in dBase III, dBase IV, and dBase V. Supported by Windows 7, Vista, 2003, XP, and 2000, the DBF Repair tool creates a new repaired file that can be attached to existing database.
Tanvi Sharma is a self employed Internet entrepreneur and product reviewer. This DBF Repair utility is extremely useful when the dBase and Foxpro database gets corrupted due to internal program errors, hardware malfunctioning, accidental deletion of data and more. This DBF Repair software repairs all types of database components including table name, column name, column data type, indexes and primary keys.
May 31, 2010 | Microsoft Visual FoxPro Professional...
Jan 22, 2009 | Microsoft Office Access 2003 (077-02871)...
Error in registry
The easy way is to make windows repair itself, this can be done by starting your pc from the windows cd, then when the blue screen appears with 3 options,
..install windows,...repaire,...quite ..F3,
press enter for installation, then F8 to accept, then windows setup will search for installed OS and then asked you to press R to repair it, from this point you can press R and wait while installer delete windows system files the reinstall them without loosing your installed programs.
Dec 10, 2008 | Computers & Internet
Computers & Internet Logo
1,015 people viewed this question
David Payne
David Payne
