Took inside pannel off all parts look good and seem to move propely
Door handle broke depends on what door handle it is.if door cant be open on out side out side door handle broke.if cant open door on inside inside door handle broke.door handle clip that connects to latch rod broken.when you try open door handle not engage to latch rod.door not going open.have to replace door handle with new clip holds latch rod in place.
SOURCE: Door want open from inside door parts list
replace inside door handle common problem good luck,
SOURCE: 1991 Chevy Astro Back doors will not open
You can remove door trim panels from inside the car, panel will come off even the door is closed.
Than put you hand inside door and pull levers to open door.
SOURCE: have a 2004 avalanche locking problem
There is a button on the drivers side control panel on the door, where the power window controls are at.. This button is square and it controls the door locks in the back so, young kids can't accidentally open the door. Pressing this button should solve your problem. Good Luck
SOURCE: drivers door won't open from the inside
Check the child lock is not engaged. If not you will need to remove the door trim to see what is going on
SOURCE: door won't open from inside '98 silverado
your door rod to your latch must have popped off your inside door latch. take your door pannel off and the door rood will be unhooked
Testimonial: "That was exactly what happened. It was not easy getting the panel off and back on, and I didn't see what caused the rod to pop off, but if it happens again I will at least no what the problem is. "
