Question about Pool & Spa
E-3 Error on Pellet stove summers heat
We get an E3 error sometimes when we run our pellet stove - but not all the time. The manual says its a combustion blower problem, so we cleaned it according to the instructions, but it still does it.
smilemaker
  • 790 Answers
SOURCE: Trailblazer Classic 1600 PS Pellet Stove Schematic
HOPE THIS HELPS U TOO ...
http://www.hearth.com/econtent/index.php/forums/viewthread/11461/
Posted on Dec 30, 2007
SOURCE: St Croix pellet stove: pellets drop
http://www.jaygaulard.com/blog/2009/01/18/how-to-clean-out-a-st-croix-prescott-exl-pellet-stove/
Posted on Feb 24, 2009
protek480
  • 1723 Answers
SOURCE: purchased a used earth stove mp240 pellet stove
The auger motor is fed through a high temp. limit thermostat. It has a manual reset on the back of it that you have to press on firmly to reset it. Open the side panel on the stove and find the wiring. You will see the thermostat on the back side of the combustion chamber. Look very closely and reset it.
good luck!
Posted on Jul 01, 2009
protek480
  • 1723 Answers
SOURCE: AUGER IN PELLET STOVE NOT CONSISTANTLY TURNING
The auger motor is fed through a high temp limit thermostat. It has to be manually reset if it activates but it could be causing your problem with a bad connection or intermittently bad. It deserves a look...
protek480
  • 1723 Answers
SOURCE: auger on pellet stove doesn't turn
The thermostat inside on the back of the combustion chamber has a manual rest that needs to be pushed and reset.
Posted on Jul 08, 2009
Tip
Alternative Heating Pellet Stoves and Pellet Inserts
Pellet stoves usually use wood pellets as their primary heat source. A pellet stove is defined as a stove that burns either compressed wood or biomass pellets to make heat to warm a home or other space.
Pellet stoves come as either free-standing units or fireplace pellet inserts which can be vented into an existing chimney. As an insert, you are able to replace your wood burning stove with this efficient and cost effect stove. Inserts also give the homeowner more of the look of a fireplace than that of a pellet stove. Pellet inserts can also be a great alternative for people who have busy lifestyles and are looking to get the beauty of a fire but prefer a cleaner burning renewable heat source.
Pellet stoves are freestanding structures that can give you the feeling that an old pot bellied stove did, tucked into a corner of a living room, den, or kitchen. Either the pellet inserts or freestanding stoves are a great alternative heating solution for keeping a house warm during the winter.
Many stove manufacturers recommend the using a corn and pellet mixture, but some are UL listed for many fuels other than pellets. These can include wheat, corn, sunflower seeds, and cherry pits.
Pellet stoves are a bit more efficient, burn cleaner, and are easier to use than conventional wood burning stoves. Pellet stoves often look very similar to wood stoves or fireplace inserts, however the similarities end there.
If you are considering burning alternative fuels then you will want to look into a pellet stove as a great way to heat your home. Pellet stoves and pellet insets have many great advantages over regular wood stoves that make them a practical heat for busy lifestyles.
on Dec 07, 2009 | Heating & Cooling
What is a 5 u code on a pellet stove
New Stove Auger not moving shows S U in display ' Hearth.com ...
www.hearth.com > ... > The Pellet Mill - Pellet and Multifuel Stoves
Nov 25, 2010 - 25 posts - ‎6 authors The letters "S U" mean the stove is in "Start Up mode. ... At this point load the stove w/pellets and hit the start button again. ... Shows SU again and settings are at 5 and 5. still no auger movement, not even the slightest bit. ... The E-0 code is the no error errorcode and stove will enter normal operation which ...
Oct 03, 2015 | Pool & Spa
What are the pros and cons of operating the Quadrafire Mt Vernon AE pellet stove in manual mode?
They probably cannot suggest running it on 'manual' due to liability reasons....leaving home for an extended time and forgetting its on manual...comes to mind.
What may be suggested is to make sure ANY and ALL safety controls still function to shut off fuel (pellet) flow in the manual mode as an extended overtemp condition is the first thing that comes to mind when you think of damage to a heating system or to the structure within which it is installed.
I think its a judgement call on your part once you determine you pretty well KNOW the full and complete operation of the device. The key to that statement is KNOWING WITHOUT A DOUBT the FULL operation of the system.
I also would NEVER recommend to a customer to operate it in the manual position.
Mar 25, 2015 | Heating & Cooling
My stove keeps going out on E2 and shuts down why
The E-2 Error code indicates an automatic shutdown because the stove does not detect a fire. Check out Englander's troubleshooting guide to some of the causes.
http://www.heatredefined.com/faq/troubleshooting-guide/pellet-stove/evolution-pellet-stove/evolution-pellet-troubleshooting-guide/e-codes/e-2-failure-to-start
Feb 27, 2015 | Englander Direct Vent: 2,000 sq.ft. Pellet...
WHAT DOES ER2 CODE MEAN ON PELLET STOVE
Which pellet stove do you have? A lot of pellet stoves have a part inside called a Draft Flow Switch the size of your palm and hook to the Draft Flow Switch is a Draft silicone hose and this will get clogged with debris you will need to look at your diagram to see if you have that on your stove. If you do you will need to "gingerly take off the hose and blow through it. and re connected to the draft flow Switch. After sometime the hoses become brittle. Another thing to look at is the exhaust at the back of the stove cleaned out and you are getting your pellet stove cleaned out by a chimney sweep.
Mar 03, 2014 | Us Stove Company Pellet Heater with...
Traeger pellet stove minuteman MPW070 user manual
does the auger in my mpd070 pellet stove have a carrier on both ends
Feb 08, 2014 | Kitchen Ranges
Trying to hook up a RTH2310B thermostat to a wood pellet stove with only two wires.. How do I know where to connect them too?
Hey Brad432, this is what i did with the same RTH2310B thermostat and my harmon stove. You must have the heat sensor that plugs in the back of the stove to start with. Take your new wire from the stove to your thermostat, red to rh, white to one side of your sensor then other side of sensor to W on your thermostat. On your stove side set your room temp as high as it will go and let your programmable thermostat set the room temp. Works good for mine. Good Luck
Nov 01, 2010 | Honeywell Focus 6300B 5-2 Days...
Pool & Spa Logo
1,265 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
