Question about Maytag Legacy Series Top Load Washer
How do I remove the cabinet from a maytag legacy series washewr?
I need to get to the motor coupling on a Maytag Legacy series washer, but for the life of me I can't get the cabinet off. All the instructions I have tell me to remove the front panel, but it's all one piece.
  • 63 Answers
SOURCE: Maytag legacy series washer top load-squeaky during wash and rinse
very possible if squeaks in agitation top springs that hold tub needs greased under spring & plastic shield under spring. had same problem on big front loaders whirlpool
Posted on Nov 14, 2008
SOURCE: Maytag Legacy washer MAV408DAWW loud noise, dumped all water
Tub bearings and seal have failed. My SAV405DAWW just started with the loud grinding and I am now in the process of finding out if I can fix it myself. Kurt
Posted on Jan 13, 2009
jyackle5
  • 8197 Answers
SOURCE: My Maytag Legacy Series washer
You also might want to check the lid switch.
Posted on Mar 15, 2009
co7196
  • 3433 Answers
SOURCE: Maytag Legacy Series Washer. Lint settles on
Lint is in majority flushed out in drain cycle. make aire the tissue and match books aren't in any pockets. the lint is then deied and separated in the drier , Well so I was told . good luck
Posted on Jun 15, 2009
richroth
  • 9472 Answers
SOURCE: how do i change the belt on a maytag legacy series washer
See if this video helps you.
Posted on Nov 29, 2012
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Maytag Legacy Series Electric Dryer
May need a new timer, I had to replace mine, easy job if you watch the video online.
Jul 08, 2013 | Maytag Legacy Series Top Load Washer
I have a maytag legacy series, toploading washer. It does fine, until it spins...a very loud screaching sound. Could this be a belt?
most likely your problem is in the pump either the pump itself is bad or there is something jammed in it, remove and inspect pump replace with new one if necessary.
Jul 08, 2009 | Maytag Legacy Top Load Washer
Jun 07, 2009 | Maytag Legacy Series Top Load Washer
Washer does not work after water fills up (Legacy series)
The motor has had it and it is effecting the whole washer or it may be the computer but most likley the motor.
Turn it off and unplug it. take it to the nearest repair man
If you have any questions please dont hesitate to ask
Dec 04, 2008 | Maytag Legacy Series Top Load Washer
Water leak
If the main seal is leaking there will typically be a splash line around the inside of your washer cabinet. There is a special wrench available for removing the large nut that holds the inner basket in. This nut is aluminum and can be removed with a chissel if it is stuck. remove the inner basket and you will see cone shaped "NUT" that is covered in cork. There is a torx screw on the side of the cone shaped piece. once the screw is removed then the cone shaped nut can be removed using the special wrench and brute force.
Mar 10, 2007 | Maytag Legacy Series Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
