Question about HP Pavilion a1630n Power Supply Replacement
How to install - HP Pavilion a1630n Power Supply Replacement
  • C Walker Jan 11, 2013
    joecoolvette, you're the coolest! Installation was a success, thanks again.
  • HP Master
  • 5,660 Answers
HP Support > Pavilion a1630n Desktop PC > Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?product=3245027&lc=en&cc=us&dlc=en&lang=en&cc=us
Took you this way in case you need additional information, and software; in the future.
No, replacing the Power Supply is not listed.
In the list click on the blue - How To
Now on Adding/Replacing Hardware.
Opening the PC Case
BEFORE working inside your computer, follow Anti-Static Precautions.
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static.
Computer ON a table, computer unplugged from power, computer case open;
TOUCH an unpainted surface of the metal frame, of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
1) Remove ALL cables. If you are not EXACTLY aware of where each cable goes, suggest making a drawing, and notes; as to where each cable goes before removing them.
2) Suggest lay a static free towel on the table you're working on, and lay the computer on it's side; opening of computer case -> Up.
Towel/cloth helps prevent scratching the table, and the computer.
Much easier to work on the computer this way, IMHO.
3) The plastic front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
(Power On switch, Power On LED light, Harddrive activity LED Restart switch; IF used)
The Front Panel header pinout is NOT listed. I THINK I know where the wires go. The Front Panel header pins. I do NOT know the color of the wires, though.
When replacing a Power Supply wires get bumped, and may get accidentally disconnected.
Suggestion is you make a drawing, and notes for the Front Panel header, and color of wires; also.
Also for the headers going along the bottom of the motherboard.
Better to safe, than trying to figure it out later.
4) The Power Supply has a Form Factor. This term was used strictly for motherboards, but has gone also to the Power Supply, and Computer Case.
The Form Factor for your Power Supply is ATX.
The term refers to the size, and shape of the case; and the power cables.
Size is approximately 6 inches Wide, 5.5 inches Long, and 3.5 inches in Height.
(152.39mm Wide x 139.7mm Long x 88.89mm Height)
It is a generic unit made by Bestec, HiPro, or Delta.
Maximum rated Wattage is 300 Watts.
(ACTUAL wattage is more like 60 to 70 percent, of what is stated.
180 to 210 Watts!)
This is JUST a look at an example. Not advertising,
http://www.amazon.com/dp/B001KNO1P6/ref=asc_df_B001KNO1P62343186?smid=AZCEI3EMXUPTH&tag=nextagusmp0359933-20&linkCode=asn&creative=395105&creativeASIN=B001KNO1P6
By the photo you can see the type of power cables, and number used.
If I were recommending a replacement Power Supply, I sure would not recommend the above example.
A) Low quality Electrolytic Capacitors
B) Low quality Rectifier Bridge
C) Low quality MOSFET's
D) Low quality wiring; too small in gauge size
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3255390&CatId=1077
The above example gives a true 350 watts. Has all the power cables you'll need, an extra ones.
Suggest you find a Power Supply comparable to this one, when replacing.
Here's a look at your motherboard,
(Product information > Product specifications > Motherboard Specifications - A8M2N-LA (Nodus M3)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00757531&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3245027
5) There are TWO power cables from the Power Supply, that plug into the motherboard;
A) 24-pin ATX Main power cable;
Looking at the motherboard photo, this power cable's connector, is all the way to the right/middle of the motherboard.
It is the whitish long connector that has two columns of 12 socket holes.
This is a general example of the power cable, and it's respective connector on the motherboard. NOTE* Color of connectors does NOT matter,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
Note the power cable connector's Lock on the side, shown in the middle photo, and photo to the right.
The Lock is hinged. Operates like a see-saw on a playground.
The Top, or part that is closest to the wires; is squeezed in with the fingers, and thumb.
This action brings the hooked end at the bottom, away from the Lock Tab, on the motherboard's female connector.
Now the power cable's CONNECTOR, can gently be wiggled, and pulled up on; with the Lock depressed.
(ONLY use the connector when disconnecting a cable. DO NOT pull on the wires)
The Power Supply I referenced as a recommendation, and all new Power Supply's; have a 20 + 4-pin ATX main power cable.
This type of power cable connector was brought out, so that the Power Supply could be used on motherboard's that required a 20-pin ATX main power cable; or a 24-pin ATX main power cable.
Either use the extra 4-pin power cable to make a 24-pin model; or don't, to have a 20-pin model. YOU will use the 20-pin AND the 4-pin power cable - together.
General example of said cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20plus4
NOTE the color code of the wires, in the additional 4-pin power cable.
Two Yellow (12 Volt), One Red (5 Volt), and One Black. (Ground)
B) The second power cable going to the motherboard, also has this type of Lock;
The 4-pin ATX +12 Volt Power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
NOTE the color code of the wires.
Two Yellow (12 Volt), two Black. (Ground)
You cannot mix the two power cables up, because the connectors are different, but wanted you to be aware of their likeness.
[4-pin ATX +12 Volt power cable, and 4-pin power cable for 24-pin ATX Main power cable)
Looking at the Top/Left in the motherboard photo, the square whitish 4-socket hole connector; is for the 4-pin ATX +12 Volt power cable.
6) Looking at -
HP Pavilion Media Center a1630n Desktop PC Product Specifications; tells me there is a SATA harddrive used, and a SATA optical drive,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00753784&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3245027
Harddrive - 250GB SATA / 7200 rpm
16X DVD (+/-) R-RW RAM (+/-)R DL Lightscribe drive, is the optical drive.
Lightscribe was developed to be used on SATA optical drives. (CD/DVD drive)
Therefore I conclude it is a SATA optical drive.
The SATA harddrive, and the SATA optical drive; use this type of power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
Between it, and the SATA data cable, the SATA power cable's connector is longer. It has 15 contact pins.
A SATA data cable has 7-pins.
More in an added Comment.
Regards,
joecoolvette
Posted on Jan 09, 2013
  • 1 more comment
  • C Walker Jan 09, 2013
    A lot of helpful information; will give a try. Thanks!
  • joecoolvette
    joecoolvette Jan 09, 2013
    This is an example of a SATA data cable, and it's respective connector on the motherboard,http://en.wikipedia.org/wiki/File:SATA_p... NOTE that the SATA data cable connectors on your motherboard, look different. Those are the Yellow, Blue, Black, and White connectors, at the bottom/right corner of the motherboard; and right next to the CMOS battery. Looking at the SATA data cable's opening, note that it has an L-shape. Matches the L-shaped SATA connector on the motherboard, and on the Harddrive, and Optical Drive/s. Both the SATA power cable, and SATA data cable, have this L-shaped opening. There may also be a lock on the connector to harddrive, or optical drive. Sometimes it's a bulb type of affair, you press down on, other times it may be a flat spot on the connector. Depress/unlock to install cable, or disconnect. On the motherboard specification page, go down to the heading - Motherboard layout, and click on the + sign to the left of it. Looking down at the Bottom/Right corner, you can see the four SATA connectors are numbered. Matching them back to the photo; SATA1 is Black. SATA2 is White, SATA3 is Blue, and SATA4 is Yellow. SATA1 is where the Harddrive is supposed to plug into. SATA2 is for the Optical Drive, or primary optical drive if two are used. SATA3 would be for the secondary optical drive. (Or Master optical drive/Slave optical drive) HOWEVER, Walkerwwf, the beauty of SATA is that, you can plug ANY device into ANY SATA connector on the motherboard, and BIOS will find it. Plug harddrive into SATA3? No problem. Plug optical drive into SATA4? No problem. The Power Supply is held in with four Philips head screws, on the back of the computer's case. http://www.fonerbooks.com/r_power.htm http://www.youtube.com/watch?v=UzolRkN7E... There is usually a locking mechanism on the inside of the computer case, for the Power Supply too. It may be a small bracket with a Philips head screw in it, or two screws; or may be a sliding type of lock, that is slid over to one side; or a metal tab is depressed, to allow the Power Supply to slide FORWARD, towards the front of the computer case. (I have also seen plastic sliding locks) OR, there may be no additional, inside the computer case, lock. For additional questions please post in a Comment. Regards, joecoolvette
  • joecoolvette
    You're welcome, and thank you for the rating!
  • HP Master
  • 2,878 Answers
The power supply needs to physically fit in chassis. Then you have 1 large 20 or 24 pin adapter for the mainboard. You have a 8 or 4 pin CPU. That is where the extra pins still add up to 28.
The rest are just adapters for hard drives, disc drives, including spares for additional expansion.
Breakdown:
1 Motherboard
1 CPU
Spares
Need timing belt digram for a 2000 kia sportage
  1. Install lower timing belt cover.
  2. Install upper timing belt cover.
  3. Install power steering drive belt and adjust belt tension.
  4. Install fan pulley.
  5. Install generator drive belt and adjust belt tension.
  6. Install A/C drive belt and adjust belt tension.
  7. Install splash guard.
  8. Install fan and fan shroud.
  9. Install 4 fan bolts. Tighten to 24 ft lb (33 Nm).
  10. Install fan shroud mounting bolts.
  11. Install fresh air duct.
  12. Connect hose to resonance chamber.
  13. Connect battery negative cable.
Apr 17, 2013 | 2000 Daewoo Nubira
How do u set timing on it? 1.8 engine
Installation
Install crankshaft sprocket on crankshaft.
Make sure mating marks on crankshaft sprocket face front of engine.
Position crankshaft so that No. 1 piston is at TDC and crankshaft key is at 12 o'clock.
Install slack side timing chain guide and timing chain tension guide.
Install timing chain on crankshaft sprocket.
Set timing chain by aligning its mating mark with that on the crankshaft sprocket.
Make sure sprocket's mating mark faces engine front.
Install camshaft sprockets.
Set timing chain by aligning mating marks with those of camshaft sprockets.
Install camshaft sprocket bolts to correct torque.
Apply new engine oil to bolt threads and seat surface.
Install chain tensioner.
Before installing chain tensioner, insert a suitable pin into pin hole of chain tensioner.
After installing chain tensioner, remove the pin.
Install timing chain guide.
Install O-rings to cylinder block.
Before installing front cover, remove all traces of RTV silicone sealant from mating surface using a scraper.
Also remove traces of RTV silicone sealant from mating surface of cylinder block.
Apply a continuous bead of Genuine RTV Silicone Sealant or equivalent to mating surface of front cover. Refer to RECOMMENDED CHEMICAL PRODUCTS AND SEALANTS .
Check alignment of mating marks on chain and crankshaft sprocket.
Align oil drive spacer with oil pump.
Place timing chain to the side of chain guide. This prevents the chain from making contact with water seal area of front cover.
Install front cover.
Make sure two O-rings are present.
Be careful not to damage oil seal when installing front cover.
Install cylinder head bolts at engine front side as shown in Fig. 55.
Tightening procedure:
Tighten bolts (1 - 4): 6.3-8.3 N.m (0.64-0.85 kg.m, 55.8-73.5 in.lb).
Install oil pump drive spacer.
Install water pump and water pump pulley. Refer to REMOVAL AND INSTALLATION .
Install idler pulley and bracket.
Install RH engine mounting bracket
Install RH engine mounting.
Install oil pan. Refer to INSTALLATION.
Install crankshaft pulley.
Remove ring gear stopper.
Install starter motor.
Install cylinder head front cover.
Apply RTV silicone sealant to cylinder head front cover.
Use Genuine RTV Silicone Sealant or equivalent. Refer to RECOMMENDED CHEMICAL PRODUCTS AND SEALANTS .
Install Camshaft Position Sensor (PHASE).
Before installing rocker cover, apply a bead of Genuine RTV Silicone Sealant or equivalent, to mating surface of cylinder head as shown in .
Install rocker cover gasket into rocker cover.
Install rocker cover and tighten in numerical order as shown in
Install spark plugs.
Install ignition coils.
Install front exhaust tube.
Install front/right-side splash undercover.
Install front RH wheel.
Install drive belts.
Adjusting drive belt deflection..
Nov 29, 2010 | 2002 Nissan Sentra
I want to install printer hp deskjet d2460
How to install Printer
Follow these steps to install the downloaded software.
  1. When the download is complete and you are ready to install the files, click Open Folder , and then click the downloaded file. The file name ends in .exe . NOTE: If you closed the Download Complete screen, browse to the folder where you saved the .exe file, and then click it.
  2. You can accept the default place to save the files. Click Next , and then wait while the installer extracts the files to prepare for installation.
  3. When the Install Wizard starts, follow the on-screen instructions to install the software. NOTE: If you have previously installed the software and are changing the connection type from USB to Ethernet, click Add a device when the Uninstall the software or Add a device window opens. For a Full Feature installation, you choose what type of installation you want. The following information might help you decide which installation type to use. Typical (Recommended) Minimum For full use of all your product features : HP includes valuable software to help you get the most out of your product.
    HP designed this installation type to work for most users. A custom type of installation might be available for your product. This installation allows you to install the minimum software required or the preferred software. Use this type of installation only if you have one of the following reasons:
    • The computer is low on hard disk space.
    • You attempted a recommended type of installation and received errors. (If errors occur during the recommended installation, fix them before trying a custom installation.)
Apr 10, 2010 | HP Deskjet 2460 Printer
F380 All-In-One won't print
first of all you need to install the software..these are the steps to install the software please follow the steps below
Two installation options are available when installing the software and drivers from the product CD. The recommended install installs everything your device requires to work, including a suite of software recommended for your installation. The custom install allows you to choose what software to install. The recommended install is designed to work for most users. Use the custom install only if you have one of the following reasons:
  • Low hard disk space on the computer.
  • You do not want the additional software.
  • Errors occur during the recommended installation. NOTE: If errors occur during the recommended install, fix them before doing a custom install.
Recommended install Complete the following instructions to install the software: CAUTION: Do not connect the USB cable until prompted to do so during software installation. HP recommends using a USB cable that is less than 10 feet (3 meters) long. NOTE: Choose unblock or accept on all firewall messages or the install will fail.
  1. Insert the software CD into the CD-ROM drive of the computer. The software installer starts automatically. NOTE: The User Account Control screen might display. Click Continue .
  2. Click Install on the Thank you for purchasing from HP! screen.
  3. Click Next on the Welcome to the Install Wizard... screen.
  4. Click Next on the Do Not Block HP Install Wizard Processes screen.
  5. Select Yes or No on the Automatically Check For Updates screen and then click Next .
    • Choose the Yes (recommended) option to check for updates through an Internet connection.
    • Choose the No option if you do not want to check for updates.
  6. Select Recommended on the Installation Options screen, and then click Next .
  7. Follow the instructions on the screen that displays to finish installing the software.
Custom install CAUTION: Do not connect the USB cable until prompted to do so during software installation. HP recommends using a USB cable that is less than 10 feet (3 meters) long. NOTE: Select unblock or accept on all firewall messages or the install will fail.
  6. Select Custom on the Installation Options screen, and then click Next .
  7. Select which software to install by selecting or clicking to clear the check box next to each item on the Custom Installation screen. Click an item to see its description and the required disk space. NOTE: You must install the drivers and the HP Imaging Device Functions for the buttons on the front panel to be functional.
  8. Follow the instructions on the screen that displays to finish installing the software.
  9. once the software installation is complete try to print that should work
Mar 09, 2009 | HP DeskJet F380 All-In-One Printer
Installation?
Hai,
first instal program software from the site provided by dell install in d/drive and strat your program if any case error pops up retry by software from intel
Dec 25, 2008 | Dell Inspiron 6000 Notebook
T3 sync with PC- Windows XP
Need to reload software in pc. Dropping stuff. If you found this helpful, please post as so. If you need to knwo how, live chat
Sep 14, 2008 | Palm Tungsten T3 Handheld
I Have a Hp Deskjet F380 ALL-In-ONE Printer-Scanner-Copier,I Need Know How to install a print driver for my Hp Deskjet F380 Printer.Thank You, I Need Help????
How do I download and install the software? To download the software, do the following:
  1. Click here to go to the Software and Drivers page for your product.
  2. Click your operating system.
  3. In the Driver section, click the appropriate software driver.
  4. Follow the instructions on the page that appears to download and install the software.
How do I install from the CD? Two installation options are available when installing the software and drivers from the product CD. The recommended install installs everything your device requires to work, including a suite of software recommended for your installation. The custom install allows you to choose what software to install. The recommended install is designed to work for most users. Use the custom install only if you have one of the following reasons:
Aug 19, 2008 | HP Office Equipment & Supplies
Install A4 tech PK635 M web cam without cd installer
help me solve my problem give me installer
May 19, 2008 | A4tech PK5
how to install a A4 tech PK 635 M web cam without using cd installer?
how to install a A4 tech PK 635 M web cam without using cd installer?coz ive lost it.
installer
May 03, 2008 | A4tech PK5
HP Pavilion a1630n Power Supply Replacement Logo
141 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
