This has happened on several occasions:
If the power goes out-always does it.
If i restart my computer before i turn the monitor off.
My monitor will not come back on, the green light will flash.
In the past i have been able to get it to come on by unpluging the monitor and rebooting the computer. But this is not working anymore.
Monitor is out of warranty.
Thanks for your help
SOURCE: Monitor flashes image for split second then goes blank but green LED flashes as well
while the monitor is still powered on, but with the LED flashing, unplug the monitor from the PC. press the power button, and the monitor should go off, now plug the pc back into the monitor. Turn the monitor back on and it should work.
Occasionally this will not work for me, but if I repeat it it normally works
Hope this helps - my problem is intermitant so it may be different to what u guys have
SOURCE: I have a viewsonic optiquest monitor Q20WB and buttons not workin
Sounds like that monitor has reached the end of the road. I would recommend purchasing another monitor, other than view sonic. Purchase a Dell..they are great!
SOURCE: Viewsonic VA912b. Monitor will only turn on for a
Bad caps in the power supply, common problems. See examples here: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20V912B/
SOURCE: Optiquest q20wb LCD has black screen & green power light flashing
Hi Rickyknows2,
If you are not hearing any beep I assume you are having problem with your video so, please ...
- open your PC and check whether your video card is well placed (sometimes it looks fine but you never know) remove it and put it back.
- If you used to remove often the cable from the PC, it might be that the pins from the monitor cable are even broke... please check.
- try to find another video card and replace it just to make sure its the video ...
- last... reset the bios (but I doubt that this is your problem)
chsers ..
SOURCE: Viewsonic Optiquest Q20wb green blink light
It's an issue with the power supply, most likely the Capacitors (one or more) may be shot. Open it up if it is out of warrenty, look at the capacitors (they look like cans), if they are bulging at the top or even sides they are bad. This is a common problem with this monitor. Crappy Caps used in manufacturing. Replace all the caps with same rated caps and you should be good. Do your research on how to desolder the old ones off and proper installation of the new ones.
The problem is the monitor. I have the same problem when rebooting. You need to turn your monitor off during reboot. After your computer is completely rebooted, you can turn your monitor back on and the green light will stop flashing. There is a flaw in the MONITOR!!! When new this did not happen!
With mine the green light just flashes constantly when I turn it on. The only way to turn it off is to unplug the power entirely. I have no idea why. It worked fine and then I rebooted and now I can't even get it to shut off.
