My dog chewed off the panel which exposed the tube. It was pulled out and is leaking water but it doesn't look like it is damaged and might just need to be put back somehow. Does any one know how I mi
Check tube has hole or split and replace tube or seal the hole
Posted on Jan 09, 2013
2 Suggested Answers
  • 472 Answers
SOURCE: Our dog chewed off the front drain door and part
i am a lg servicer and have been for several years ... you can call lg @ 1-800-847-7597 AND GO THROUGH PROMPTS SOMEONE WILL ANSWER and make sure you have your model number on hand... be warned some of the people taken the orders are not the brightest so if you can find a pars schematic and identify the correct names of the parts you are looking for would be the best.
www.repairclinic.com offers a place to type in your model number and i believe will come up with a parts diagram of unit locate what you need and either order from them or call lg directly. good luck to you
Posted on Jan 08, 2011
My refrigerator leaks water out the bottom when I use the water dispenser in the door.
water line has a hole. probably from a mouse chewing on the plastic tube. Another possiblity the plastic tube was pulled on and pulled out of the compression nut / connector.
Feb 07, 2014 | Frigidaire PLHS267ZA Side by Side...
My GE Profile refrigerator leaks water from the freezer. I find a puddle under it 2x/week.
Defrost drain tube clogged, drain pan cracked, water tubing near compressor gets brittle and leaks, critters chew on water tubing also.
Oct 29, 2013 | GE Profile 26.6 cu. ft. Side-by-Side...
Dog chewed off seat belt in front and replaced with junk yard now thejunk yard replacement will no retrack out
Unfortunately the junk yard takes parts from wrecked vehicles. The other problem is sometimes these vehicles are exposed to the weather soyou may have rust etc. in the track. Spray WD-40 inside and tap lightly while trying to pull belt out.
Mar 28, 2011 | 2004 Ford F150
The top screen of our DS is frozen white and blotcy.
Well that can mean only one thing and that is that the screen is damaged either from being dropped or water damage or from being thrown or chewed on which dogs are famous for chewing on things. So what you need to do is either get the screen replaced through the manufacturer or you can go the cheaper route and buy a new DS.
Mar 04, 2010 | Nintendo DS Console
My jacuzzi bathtub plastics pipes underneath are leaking due to being chewed by rats. So if i fill up the tub to the jacuzzi line holes, water leakes through the chewed pipes on to the wood floor...
no there is no solutions for plugging off the jets so the water doesn't go in them. you will have to pull the tub and repair the lines. no access panel just means you have to dig in!
Feb 23, 2010 | Whirlpool 5"x36" White Bathroom Drop-in ...
MY AIR CONDITONER HAS JUST STARTED LEAKING WATER,SPLIT SYSTEM DOGS HAVE CHEWED FOAM AWAY FROM COOPER PIPES ON THE OUTSIDE UNIT
if the water is coming from the cooling coil on the furnace or blower package, that means the drain line is plugged. put a wet vacuum on the end of the drain line for a few seconds, that should **** out any residual sediment collected in the drain trap or drain line. if your concerned about the water collecting on the line that is missing the insulation, that is only sweat from the humid air contacting the cold pipe (suction line)and doesn't pose any problem as long as the exposed line is outside. it would be a good idea to reinsulate the line to prevent the sweat and the refrigerant temp from getting too warm . the low gas temp in the suction line is what keeps the compressor motor windings cool and prevents it from overheating and burning up. Don't let the dogs **** on the condenser (outdoor unit) the urine will corrode the fins and you'll start loosing capacity due to higher discharge pressures.
Feb 12, 2010 | Fujitsu Heating & Cooling
Kenmore 665.16039403 leaks water when filling
It is coming from the fill tube. You can pull the unit out or use a mirror to look up underneath. It might have come off or got a hole chewed in it.
Eric
Sep 25, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Chevy impala 2005, dog chewed off rear licence plate. Pulled out wires, do I have to take full bumper off to check damage. Blinker and lights seem to be working
See if you can pull the wires out just a little and see if there is any bare wire showing. If you can pull any wire out then more than likely the dog couldnt eather.
Jul 14, 2009 | 2005 Chevrolet Impala
Tubing leaking in refrigerator door
if your talking about the water line fron the bottom ofthe door to the dispensor head, it pulls out and is replaceable, might be a little tricke to feed through the door but ther is a channel in which it will push back through
Nov 15, 2008 | Frigidaire FRS26R4A Side by Side...
Replacing tubing for water
1. get the same size tubing and parts
2.check the fitting, take apart both side and put the new tubing again
Jul 10, 2008 | KitchenAid Superba Architect KSCS25INSS...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
