Question about Lands Phones
My panasonic kx-tg5521e loud speaker on handset is not working. how do i make this function work. My other handset speaker function works fine. Have any settings been adjusted accidentally?
I have 2 handsets with this system, both of which have the loud speaker function. However this loud speaker function and even the key tones on one of the handsets doesn't work at all. I can use the handset in normal phone to ear mode, but the speaker mode doesn't work. Do I have a faulty handset or has the function settings of the phone been changed somehow? Is so, how do I fix this. Thank you
SOURCE: I have a Panasonic KX-TG6051CM
I had the same problem, and it seems that the battery charging circuit in the handset had locked up, constantly charging the battery until it overheated. I was able to reset the circuit in my handset by completely draining the battery. Here is the procedure:
1. Remove the handset from the charging cradle, and leave it on for a few days until the battery runs out, and the handset finally turns off. At his point, the battery will be very low, BUT NOT COMPLETELY DRAINED.
2. Next, you must manually drain the charge remaining in the battery by shorting out the two contacts on it. Shorting won't damage the battery, since it is holding very little charge at this point. An easy way to physically do this is to remove the battery, and place a piece of thin wire across the the two contacts of the HANDSET. I am referring to the contacts inside the handset that connect to the battery, NOT the contacts on the bottom outside that connect the handset to the charging cradle. Next, put the battery back in, sandwiching the wire between the battery's contacts and those inside the handset. This will hold the wire in place. DO NOT PUT THE HANDSET BACK INTO THE CHARGER, WITH THE BATTERY SHORTED OUT.
3. Wait about 30 minutes for the battery to completely die. Remove the jumper wire, and but the handset back into the charger.
4. If the battery was fully discharged , you will get a message on the handset telling you that you should let it will charge for 7 hours. If you do not get this message, then either the battery was not fully discharged, or your problem is different from mine. Try the procedure again in Step 3 for another 30 minutes to discharge the battery some more.
5. If you get the "Wait for 7 hours to charge" message on the handset, then leave it in the charging cradle for the 7 hours requested. After that, it should work fine.
Let me know how you make out.
Posted on Aug 11, 2008
SOURCE: BT Studio 1000 4 handsets
hi problem with bt studio 1000 phone changed battery and phone still not working just a hi pitch sound when you press it .
please can you help me.
Posted on Oct 27, 2008
SOURCE: adding handset to Panasonic KX-TGA542M phone. ? how to ?
I ordered a new kx-tg560m handset for my kx-tg5632 base unit, but the enclosed instructions for registering it with the base unit were wrong. Fortunately, I found the old quick setup guide in my files.
If you do not have the same base unit and handset, go to the URL:
http://www.panaxonic.com/RegisterYourHandset.
1. On the handset, press [MENU], then press [0][0]. The handset displays "Refer to manual to prepare base. Then press OK->"
2. On the base unit, press [SELECT] until the desired extension number [H1, H2, H3, or H4] is displayed on the base unit, then press and hold [CALL] until the CHARGE indicator flashes.
3. On the handset, press the [OK] softkey.
When the handset is off and sitting in the charger, the handset's extension is displayed in the upper right corner.
Posted on Nov 22, 2008
funkyjacob
  • 76 Answers
SOURCE: No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
Posted on Dec 02, 2008
SOURCE: Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Posted on Sep 10, 2009
Testimonial: "This responder did nothing but repeat my initial post and yet gets credit for a solution?"
KX-TGA660 handsets - 3 of 5 wouldn't ring (no sound)
sounds like who ever installed your service was an amateur, all points should be gone over by a senior tech, piece by piece!!
Nov 14, 2013 | Panasonic Lands Phones
Speaker not working on panasonic kx-tga410
*** This phone is a POS ***
I've had three of four handsets stop giving audible feedback when a button is pushed, and 2 of 4 speakerphone stopped working.
Apr 03, 2012 | Lands Phones
I have a panasonic kx-tga271 handset. The speaker phone, the ringer and keypad noise do not work. Is it fixanle?
It could be the speaker. I have a handset with the same issue. The internal speaker which produces these sounds broke. If you can find a small speaker that fits inside, its an easy fix - - just take out the screw inside the battery compartment and carefully undo the plastic assembly. The speaker is held in place with a plastic anchor that twists off. There are two dots of solder which attach the wires that will have to be melted and resoldered on the replacement. Anyone thats handy can fix this. Look for a used handset for parts. You might also consider breaking apart a cheap set of headphones for the speaker. It won't be as loud, but at least the sound will be restored to some degree.
Oct 21, 2010 | Panasonic KX-TGA271 Cordless Expansion...
Need hnew handset for Panasonic KX-TG2357
www.amazon.com/Panasonic-KX-TG2357-Technology-Speakerphone-Answering/dp/B000JF23IS - 240k
Available from these sellers
Jan 10, 2009 | Panasonic KX-TG2357 Cordless Phone
Panasonic KX-TG6700
Did you try disonnecting the unit from the power for a few hours?
Apr 13, 2008 | Panasonic KX-TG6500 Cordless Phone
Panasonic KX-TGA400B De-register handset
You do not need to power up the handset to delete the old intercom number, you do this on your base station. At your base push Function, then scroll up to Registration, push Enter, scroll to de-registration, push enter, scroll to the right and highlight that intercom number that you wish to delete, push Enter then Clear. If your not sure which intercom number it was, take a piece of paper and a pen and look at each functional handset you have, and notate the intercom number which is in the upper right hand corner. You can send your dead handset in for repair to have a backup, so don't toss it.
Mar 17, 2008 | Panasonic KX TGA400B Cordless Expansion...
Panasonic kx-fpc141
Try Ths on the handset Be sure the TALK indicator is off.Press LOUD/RINGER button on the handset, the curreent ringerwill sound. To change the Volume press the LOUD/RINGERagain within 5 secs , and the new ringer will sound, you must press LOUD/RINGER within 5 secs or the volume will not change.
May 08, 2007 | Panasonic KX-FPC141 Plain Paper Thermal...
Lands Phones Logo
97 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
