Question about Powerline Asoka Pluglink 9550 85mbps Wireless Adapter Lcd Tivo Led Projector
Asoka pluglink
No wireless signal
After installing my lexmark 7675 my laptop cannot access the wireless network
Wireless communication issues could be due to wireless signal quality, signal interference, firewall, etc. Make sure your printer is positioned where it receives excellent wireless signal strength (avoid physical obstructions whenever possible) and away from appliances which emit wireless signals (e.g. microwave ovens, cordless telephones, baby monitors, and other wireless electronics) that may cause interference. Make sure to allow full access to all Lexmark software and printer communication processes in the program rules/permissions for your firewall.
You may also refer to these articles from the Lexmark website to identify and rectify this problem:
- Wireless & Network Communication Issues with 2008 Lexmark Inkjet Products
- How to identify a Wireless Communication Problem and Resolution Tips
I hope this helps.
Jan 28, 2012 | Lexmark X7675 AllInOne InkJet Printer
Can i use a wireless router with a wireless modem?
Yes you can definitely use a wireless router to work with your existing wireless modem , so you have an option to connect to the signal of the wireless modem of the wireless router. You can also choose if you like to disable the wireless signal of the mode and just use the signal of the router.
Apr 24, 2011 | Arris SURFboard SBG900 Wireless Router...
How can I boost the signal on my rocketfish bluetooth adapter?
There is no BOOSTER to do it,but you can do it for a router.Depends on your route rmodel there is several router signal boosters online.
Shopping results for wireless router signal boosters z 3 pack Wi-Fi Wireless Antenna / Router Signal Booster
nav_logo29.png 4 reviews - $10.02 - Amazon.com 2 pack Wi-Fi Wireless Antenna / Router Signal Booster
$7.99 - Buy.com 2 Pack Wi-Fi Wireless Antenna / Router Signal Booster
$8 - 2 stores
Dec 23, 2010 | Rocketfish Bluetooth USB Adapter...
I have about 300 meters distance and I would like to connect my internet connection to the end. I'm using smart bro connection, is it possible using router to spread signal of internet on wireless with...
Wireless-g router can only extend it's wireless signal up to 50 to 75 feet. You can use a wireless signal extender to be able to extend the signal further. And yes, you may have password on the wireless network.
Jun 07, 2010 | Linksys Wireless-G WRT54G Router
Low broadcast signal
Turn off or move any other gadgets that may emit a wireless signal. Other wireless signals may prevent the router signal from being as strong as it should be
Nov 27, 2009 | Belkin (F5D7633UK4A) Wireless Router
When I go into other rooms I can't connect to router
How is the signal strength? Check and make sure the antennas are not loose. Is your house the old style concrete? Sometimes thick block or concrete walls are tough for the wireless signal to get through. They do make larger antennas or signal boosters for wireless routers. You may need to install one of these to boost signal strength. Also is it wireless B,G,or N? Wireless B has a very weak signal while wireless N has a very strong signal. Sometimes the router settings can be changed to adjust the signal strength and may be set too low also.
Sep 05, 2009 | Linksys Wireless-G WRT54G Router
Iam about 30 meters from where i get my signal
To improve signal performance, change the wireless channel on the wireless router.
Aug 07, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Inspiron 6000 has trouble picking up wireless signal
Some wireless cards are better than others at picking up weaker signals.
The problem with any wireless transmissions is that radio signals cannot pass through metallic surfaces.
You should position your wireless router away from metallic surfaces/walls and position your laptop so it can receive the radio signals without it passing through any metallic walls. If possible place the wireless router higher than at desk level.
Dec 26, 2008 | Dell Inspiron 6000 Notebook
WEBCAN INSTALLATION
i have a microsoft lifecam vx-3000 web cam and i lost the cd installer
Sep 18, 2008 | Microsoft LifeCam VX-3000 Web Camera
My neighbor's signal
If your neighbors know that your using their router, you might ask them to reset it. If they moved it, this could cause the weakening of the signal, walls drastically decrease a wireless signal. You might also refresh your wireless card by uninstalling the wireless drivers and reinstalling them.
Aug 05, 2008 | HP Compaq nc6000 Notebook
Powerline Asoka Pluglink 9550 85mbps Wireless Adapter Lcd Tivo Led Projector Logo
Top Powerline Computers & Internet Experts
David Payne
David Payne
Are you a Powerline Computer and Internet Expert? Answer questions, earn points and help others
