Question about Mitel 5330 IP Phone
L2boot not found
No application loaded, cannot use settings or mailbox key. Can only setup keys from Management console.
Reset CMOS on IBM 2847
  1. cmossave.jpgEnter CMOS setup.
  2. In CMOS setup look for an option to reset the CMOS values to the default setting or an option to load the fail-safe defaults. With many CMOS setup screens there will be a function key to do this; for example, the F5, F6, F9, F11, or F12 key like shown in the picture to the right. Other setups may actually list an option that you can arrow over to using the arrow keys and press Enter.
  3. When found and selected you'll likely be asked if you're sure you wish to load the defaults press Y for yes or arrow to the yes option.
  4. Once the default values have been set make sure to Save and Exit and not just exit.
May 14, 2012 | IBM Computers & Internet
How in the world do you set up voice mail on the e71
Hello Debb,
Please visit the link provide below :
http://www.gen-i.co.nz/Solutions/Mobility/Device_Documents/Nokia%20E71/Setting%20up%20Voicemail%20on%20the%20Nokia%20E71.pdf
Apr 15, 2011 | Nokia E71 Smartphone
I need to reset my acer aspire 5520 to factory settings without recovery discs
There is a recovery console on your HDD (Hard Disk Drive) this is a hidden partition on your HDD. If you power on your laptop and hold the ALT key and keep tapping the F10 key while it posts to the acer logo screen it will goto a black screen with a flashing cursor on the top left then stop tapping F10 and remove your finger from the ALT key, you will then see windows loading files. This will take you to the recovery console and from there you can select restore laptop to factory defaults or restore laptop retaining user data.
Hope this helps
Feb 22, 2011 | Acer Aspire 5500 5570-2609 Laptop
Configure my n72 mailbox
Here is the short tutorial which allows your to configure Gmail Account on N95: (IMP: You must enable POP3 access of Gmail Account. Hint:Look inside Setting and POP forwarding Options on gmail web site)
  1. Open Messaging Application (Figure 1)
  2. Goto Mail box. It asks you No mailbox defined. Define now? Choose Yes (figure 2)
  3. Mailbox setup wizard will start. Press start to continue
  4. Mailbox Type choose POP3, Press Next ( figure 3)
  5. On next screen type your email address xxx@gmail.com (IMP: press the Pencil Key and highlight your email address then press Copy. This will save you typing) ( figure 4)
  6. Press Next
  7. Enter pop.gmail.com as Incoming mail server, Press Next ( figure 5 )
  8. Enter smtp.gmail.com as Outgoing mail server, Press Next (figure 6 )
  9. Access Point, choose Always ask or your preferred one. press next ( figure 7 )
  11. Click Finish
  12. Click Option and then Settings
  13. Choose E-mail
  14. Press on Mailboxes and then on Gmail
  15. Press on Connection settings
  16. Press on Incoming e-mail
  17. Enter Username as xxx@gmail.com (You may Press Pencil and then paste)
  18. In Password type your password
  19. Scroll down to security port and choose SSL/TLS
  20. Press Back Button
  21. Select Outgoing e-mail, Enter your username and password as described above
  22. Scroll down to security port and choose SSL/TLS
  23. Hit Back Button twice
  24. Press on User settings
  25. Enter your Name as you want to display and then go back
  26. Goto Retrieval Settings
  27. Click on E-mail to retrieve and change it to size limit and then enter 100KB or whatever you like in next screen. Press OK
  28. Click on Back
  29. If you have unlimited GPRS connection then goto Automatic retrieval and change it otherwise leave as it is.
  30. Click back button multiple times so that you are back to main screen.
  31. Now when you start Messaging Application you will see Gmail Account goto it and retrieve your email.
  32. You can also send email attach images with it etc. Have fun icon_wink.gif
1_vs.jpg 2_vsdgavs.jpg 3_dvd.jpg 4_dsgs.jpg 5_bfszcv.jpg 6_gdzf.jpg 7_dgsg1.jpg 8_zbhsd.jpg
Jan 05, 2011 | Cell Phones
D2d recovery miss, in my hd, what I do?
If the computer you are recoverying the Operasting System on does not have an internal optical drive an external USB optical drive will be required to use the Recovery Media.
  1. If applicable, ensure the external USB optical drive is properly connected to the computer and powered on.
  2. Power on the computer.
  3. Press the F2 key to enter BIOS Setup during Power-On Self-Test (POST while the Acer logo is being displayed).
  4. Using the keyboard arrow keys, arrow over to Boot.
  5. Refer to on screen instructions to set the first device to CDROM or USB CDROM.
  6. Press the optical drive drive eject button and insert the System CD.
  7. Close the optical drive tray.
  8. Press the F10 key, and then the Enter key to save the changes and restart the computer.
  9. The computer will boot from the Acer Recovery Media, follow the prompts to reinstall the Operating System.
Note: If you do not have a set of Acer Recovery Media they may be purchased at our Acer Recovery Media Order Form.
Drivers for Acer products may be found on the Acer Product Support. Search for the product and download the drivers.
Alternatively, the factory installed drivers and applications can be re-installed by using Acer eRecovery by following these steps:
  1. Click Start, and then All Programs
  2. Click Acer, and then Acer eRecovery Management
  3. You may be prompted to enter or create a password. This password will be required to use eRecovery in the future.
  4. In the next window on the left toolbar, select Restore.
  5. Choose Reinstall Drivers or Applications
  6. Choose Contents
  7. Choose the driver or application you wish to install
  8. On the right, click the Install link and follow the prompts.
  9. The computer may restart when installation is complete. If it does not restart, manually shutdown and restart the computer.
Note: For older Acer products, the Acer eRecovery Management program may not be available.
Dec 12, 2010 | Acer Aspire 5610-4648 Notebook
Reset the BIOS on a Compaq server 740 jumpers settings
Don,t do that insatead:
Entering the BIOS Setup menu Entering the BIOS Setup menu requires pressing a specific key at a specific time. If you fail to enter the Setup menu on your first try, repeat the following steps until you are successful:
  1. Close all applications that are currently running and restart the computer by clicking Start , Shut Down , Restart the Computer , and then OK .
  2. When the red Compaq logo or blue HP logo screen appears, press the F10 key on the keyboard to enter the Setup menu.
NOTE: An alternate to the above steps, especially if the logo screen disappears too quickly to enter BIOS, is to shut down (turn off) the computer. Wait 30 seconds, turn the power on and press F10 or F1 at the logo screen. Reloading the default settings Complete the following steps to reload the factory installed BIOS Setup settings:
  1. In the BIOS Setup utility, select the Exit tab.
  2. Select Load Setup Defaults .
  3. Select Save Changes and Exit (pressing F5 and the Enter key will also load the Setup Defaults).
  4. Press Esc and then Enter to exit Setup.
Nov 13, 2010 | Computers & Internet
I cant get a wpa key.it always tells me wpa key has timed out or is not correct
Thank you for using Fixya!
The WPA key can be found your router's setup page or configuration page (under wireless settings).
If you do not know how to access your router's setup page I would suggest contact your router's manufacturer to assist you on getting the WPA key. If you are connecting to other peoples wireless network then I'm afraid that is not possible unless you can ask them to provide you the key.
You can also go to www.portforward.com, to know on how to access router's setup page for different brand and model.
Hope this helps.
Thank you,
stif_nec
May 22, 2010 | Sony PlayStation Portable (PSP) Console
How doi find my wep key?
Your WEP key is the key for your wireless (wifi) router. You will need to check the settings of your specific router in order to access the WEP key settings. Your computers on the wireless network have the WEP key too, but it is like a password and cannot be read from the computers, it is only found on the router setup/settings.
May 07, 2010 | Sony Playstation 3 (PS3) Console
How do i set up a scan box on my konica, i have my i.p address already konica minolta bizhub c252
How to setup scan to hard drive on a c250 with standard controller:
1. Enter the ip address in your web browser.
2. Click on the file tab and then the create box under the mailboxes.
3. Input a mailbox number and password that you select in the proper fields.
4. Click on create and after the browser returns to the previous screen you can create another mailbox or log out.
5. After all mailboxes have been created you click on the scan tab to set up a one-touch key.
6. Select the index number you wish to set the one touch key under and then click on an open box. (box with --- In it).
7. On the destination screen that opens select scan to hdd and click on the next box.
8. Name the mailbox with the name you want on the machine display in the destination name field.
9. Select the mailbox name or number for the location using the drop down menu.
10. Click on create to finish creating the mailbox and making it available as a one touch key.
Nov 02, 2009 | Konica Minolta bizhub C250 All-In-One...
MWI for voice menu definition with muliple mailboxes
why define them as EM,if you set them as regular mailbox's and use the scr dn key 0 as the mailbox with the other numbers as secondary numbers in the mailbox profile.sorry for delay i am only new...i hope this helps in some way
Jul 22, 2008 | Nortel MERIDIAN M2250 ATTENDANT CONSOLE...
Mitel 5330 IP Phone Logo
126 people viewed this question
Top Mitel Computers & Internet Experts
Martin Murray
Kelley Hopper
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
