Question about Toshiba E Studio 230 280 Copier
Toshiba 280 copier c440
Code C440
    Habit-Forming:
  • 41 Answers
Press
0 + 8 --> power on
400 --> start --> 0 --> interrupt
Posted on Feb 18, 2013
  • Toshiba Expert
  • 414 Answers
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine.
When this code not cleat 08-400 then check these all thengs..
1.Check the thermistors
(1) Check if the connectors are disconnected.
(2) Check if the main and edge thermistors are in contact with the surface of the fuser roller properly?
(3) Check if the harnesses of the main and edge thermistors are open circuited.
2. Check the IH board and IH coil
(1) Check if the IH coil is broken.
(2) Check if the connector of the IH coil is disconnected.
(3) Check if the thermostat is blown.
(4) Check if the connectors on the IH board are disconnected (AC input connector and LGC I/F connector
CN455/456).
(5) Check if the IH board or the switching power supply unit are abnormal.
• Replace the IH control board.
3. Check the LGC board
(1) Check if the connectors CN316 are disconnected.
(2) Check if the conductor pattern on the LGC board is short circuited or open circuited.
(3) Replace the LGC board.
Thanks
Best Regards
Posted on Jan 11, 2013
  • 990 Answers
SOURCE: error code c440
Hello sir; C440in this machine,it means fuser unit problem, but it can be reset the procedure as follow;
1, hold down "0" and "8" keys while turn on the power.
2, enter 400 press start.
3, enter 0 press set or enter.
Posted on Jan 07, 2009
  • 3 Answers
SOURCE: toshiba e-studio 232 says c440 code
This problem is caused by the thermister in the fuser section. To reset shut macine off, then turn it on while holding down the 0 and the 8 key down for more than ten seconds then release. This is service program mode, now press 4 then 0 then 0 and then the start key, you will see a nuber in the screen, press 0 then start key this should reset that code if not the thermisters need to be replaced
Posted on Apr 11, 2010
mce_sys
  • 41 Answers
SOURCE: toshiba estudio 4511 error code C440
Press 0-8 then enter 400 and make it 0 then press print switch, if doesen't work u have to change thermostar, then if not working change heater, if not then IH board, and the last solution is to change the system board.
Posted on Jul 24, 2010
  • 30 Answers
SOURCE: I got a C440 error code sub code "7" with Toshiba
Hi how are you this is jack ...(jack_pak@hotmail.com)..
Dear follow the procedure
[C440] Fuser abnormality after abnormality judment.
CN455/456).
please vote me.
Thanks
Best Regards,
Posted on Aug 14, 2010
djuksoni
  • 103 Answers
SOURCE: Error code c440. call for
Fuser unit error code, need to replace fuser unit
BR
Posted on Feb 12, 2011
C440 toshiba 306 se
Change the current status counter value (08-2002) "4" to "0" for
Jun 16, 2016 | Toshiba Office Equipment & Supplies
Error code C440
Toshiba eStudio 355/455 Full Service Manual - Tradebit.com
https://www.tradebit.com/.../155135538-toshiba-estudio-355-455-full-se...
Download Toshiba eStudio 355/455 Full Service Manual ... Configuring DepartmentCodes Configuring ... TSB-1013: C440 Error - Countermeasure .... DIG-ACC-145: MJ-1025 Bracket Change to Enable Installation on e-STUDIO205L/255/305
Aug 08, 2015 | Toshiba E-Studio 305 Digital Copier
What is error c440 of toshiba photocopier
Toshiba e-studio Error code c440 is just problem with Fuser Unit after warm up time . 200L/ 202L/ 230/ 232/ 280/ 282/ 283/ 233
PROBLEM:
Fuser unit problem,
SOLUTION:
Try to reset it:
1. Hold down "0" and "8" keys while turn on the power.
2. Enter 400 press Start.
3. Enter 0 press Set or Enter.
Hope this helps
you can find more info at this link
Apr 28, 2014 | Toshiba E-studio 352 Digital...
C440 error
chik tha power suppl bord
Nov 15, 2013 | Toshiba E-Studio 456 Copier
How to reset c440 code
reset ligue o equipamnto 08 precionado digite 400 start reposicione para 0 enter desligue o equipamento ok. caso retorne codigo substitua o thermistor
Jan 09, 2013 | Toshiba E Studio 230 280 Copier
TOSHIBA E-STUDIO 452 showing error code C440 problem solutions
How con i INCREASE , color of copy in toshiba 452
please sent to my add the GUIDE code toshiba 452
oolmii@yahoo.com
Aug 12, 2012 | Toshiba Estudio 200L Copier
TOSHIBA E STUDIO 280 CALL FOR SERVICE
First of all check what is sub code with this .if it is not showing code press clear & 8 key at same time .code will bi shown .if no code just reset pm cycle count.MIAN AKHLAQ
Dec 31, 2008 | Toshiba e-Studio 350 Copier
Toshiba E Studio 230 280 Copier Logo
174 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
