Question about Microsoft Excel Computers & Internet
Excel Conditional Formatting: how do I make one cell highlight based on whether or not another cell is blank?
I have work order numbers in one column. I want the cells they are in to be highlighted bright yellow until they are completed. I will enter the completion date in another cell in the same row. Once I enter that date, I would like the highlighting in the WO cell to go away. Thanks!
    Problem Solver:
  • 6 Answers
Option: formula is
formula: =(datecell="")
select formatting of choice
Highlight the order cells, go to >format>conditional formatting, choose "formula is" instead of "cell is". When you refer to the datecell, use the first date cell in the column only, and do not use $ signs.
Posted on Feb 15, 2013
  • 5 Answers
SOURCE: Conditional Formating
Use conditional formatting for the coloumn of student use Option " Formula Is" - In this write cell address of Marks e.g.c5 Then write =$c5>80 then click format and format the pattern
Posted on Oct 04, 2007
softplanway
  • 53 Answers
SOURCE: Excel Coordinates don't show up in Formula Bar
Heyo. I have had this problem before too. This procedure prevents the cells that contain the formula from being edited.
  1. Select the range of cells whose formulas you want to hide. You can also select the entire sheet.
  2. On the Format menu, click Cells, and then click the Protection tab.
  3. Select the Hidden check box.
  4. Click OK.
  5. On the Tools menu, point to Protection, and then click Protect Sheet.
  6. Make sure the Protect worksheet and contents of locked cells check box is selected.
Good Luck!
Wayne
Posted on Dec 28, 2007
  • 163 Answers
SOURCE: MS Word 2003Windows everything gets selected; all is highlighted
hi,
guess your using oldversion of outook or ms office. try to update to latest one.
or try repairing the software using your office CD. Please follow the steps it will help you to slove the issue.
  1. On the Help menu, click Detect and Repair. To restore the program shortcuts to the Windows Start menu, make sure the Restore my shortcuts while repairing check box is selected.
  2. Click Start.
Make sure that you close all programs running.
Posted on Dec 30, 2008
Squirm57
  • 152 Answers
SOURCE: Status bar (that shows sum of highlighted cells) has vanished
The status bar is located at the bottom of the Excel window. It is to the left of the View buttons. If you right click, a customixe status bar menu appears and you can select what you want to show. If is does not come up, you should run Microsoft Office Diagnostics located under the Office tools menu.
Posted on Mar 22, 2009
Squirm57
  • 152 Answers
SOURCE: Excel 2007: Conditional formatting
did you put the sheet name in your reference? ex =Sheet2!A1 or you can name the cell ranges on the other sheets and use the cell names in your conditional formatting formla.
Posted on May 10, 2009
IS THERE A FORMULA IN EXCEL THAT WILL HIGHLIGHT CELLS THAT MATCH A NUMERICAL INVENTORY LIST?
One way would be to create a colunn C and use the formula: =COUNTIF(B$2:B$200,A2) in cell C2. Then copy the formula down to C200. (assuming you have 200 entries in B...). This will put a "1" next to every number in Column A that has a match in column B. Then you could put a conditional formula in column A that will highlight the cell if the value in column C is equal to 1. Alternatively you could also simply filter for 1's in column C and then manually highlight the cells that show up in A!
Sep 16, 2014 | Microsoft Excel for PC
May 08, 2009 | Microsoft Excel for PC
Conditional formating to highlight problems.
in Excel 2007 and if you have a cell (say C2) with the value of elapsed time (for example set = A2 which contains start time plus B2 which contains end time - or current time) - click in the cell (C2) then on the Home tab click on Styles >> Conditional formatting choose Highlight Cells Rules>>Greater Than... set your value in the dialog to your respective value and choose your highlight. This is a start - you can then add new rules.
to then apply this same conditional formatting to every cell in that column Ctrl-C to copy the cell you just formatted - then click on the column header to highlght the entire column - Right-click and choose Paste Special - then choose Formatting for what to paste.
It's slightly different in Excel 2003 so let us know what version you are using.
Cheers.
Feb 27, 2009 | Microsoft Office Standard for PC
I have a year planner in excel in which first row consist of month jan,feb.... and in the second row days are there like 1, 2,3..... and on the very first column name of employees is there so my task is to...
There is always multiple solutions, but here is one...
Add a row (that can be hidden later if you want) where you have the full date (01/01/09). For this example it will be row "C." Then use Conditional Formatting with the function:
=weekday(C$2,2)>5.
See if this helps.
Jan 03, 2009 | Microsoft Excel for PC
Highlight weekend in the year planner
The easiest way of doing this is by inserting another row with Days
Can be MTWT etc, and you can set conditional formatting for any cell beginning with "S" into a colour/ variation of your choice.
To highligh weekend in the year planner
Need Formula
TEXT CASE
Convert to UPPER, Proper or lower
Auto Convert to UPPER, Proper or lower
Stop VBA Being Case Sensitive
SELECT CASE VBA
Select Case Statement. Great alternative to Else If Statements
CONVERSION
VBA: CBool(),CByt(),CCur(),CDate(),CDbl()Double,CDec(),CInt(),CLng(),CSng(),CStr(),CVar().
Example
dDate=cDate("25-Jan-07")
Convert Numbers to Words
Convert Numbers to Dollar Amount in Words
Spreadsheet Converter. Versions: HTML/JavaScript,Excel ASP.Net and Excel Java/JSP. $
SQL Database Migration $
Converters. Database Converters, Spreadsheet Converters, Text Converters, E-mail Conversion, Document Conversion, PDF Conversion and more! $
CSV Converter $
IMPORTING
Import SQL Into Excel-SQL Tester $
Import Excel Into Access $
CONDITIONAL FORMATTING
More Than 3 Conditional Formats
Conditional Format Fonts for greater than 3
CUSTOM FORMATS
Custom Formats
Excel see a cells format as having four Sections. These are, from left to right: Positives;Negatives;Zeros;Text.
To hide zeros cell-by-cell use a Custom Number Format like 0.00;-0.00; where 0.00 is desired format for non zeros. Note the use of -0.00 for negatives.
To hide zeros on the Workbook level go to Tools>Options>View - Zero Values.
Dec 15, 2008 | Microsoft Windows XP Home Edition
http://chandoo.org/wp/2008/03/13/want-to-be-an-excel-conditional-formatting-rock-star-read-this/
Go down to the section about highlighting where there's an error. That's the basics of what you want to do. Now you need the code:
This will set a value of "True" if the string is -not- found inside. So if you want to flag it for finding the word NOT, you want the conditional formatting to kick in if the value of this is FALSE.
=iserr(find("NOT",A1))
Dec 06, 2008 | Computers & Internet
If statement that will change cell color in excel
conditional formatting is alright.
you just have to remove the $ signs in the cell reference when you set a condition.
then, copy-paste
Nov 20, 2008 | Microsoft Excel for PC
Oct 03, 2007 | Microsoft Office Standard for PC
Computers & Internet Logo
49 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
