Kyocera fs-3920DN call service 7410-0028789 - Office Equipment & Supplies
Soulvisitor
  • 1113 Answers
SOURCE: Kyocera Error
Signifies comunication error between mainboard and engine.
Only hope would be check and reinstall printers firmware via flash card in side socket.
Check connections on the boards.
Replace main board.
Error is stated as for F040: the .0183044 is just page count.. no match for just 040 in service manual.
Cheers
Posted on Jan 03, 2008
  • 43 Answers
SOURCE: kyocera fs1920 problem
F030 = main controller PCB System Error (frimware upgrade required)
do you have access to a Compact Flash Card & a Card Reader / Writer?
or is the printer connected via Parallel?
Posted on Dec 16, 2008
leroyal
  • 2120 Answers
SOURCE: Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
Posted on Jan 23, 2009
  • 66 Answers
SOURCE: CALL SERVICE 7410:0002988
the 7410 error may be a drum unit that is not pushed in properly or it could be the following
defective drum EEPROM drum needs to be replaced or
defective engine PCB
the above suggestions assume that it is an original Kyocera drum
hope it helps
Posted on Mar 21, 2009
  • 300 Answers
SOURCE: CALL SERVICE 6000:0115785
Error 6000: is a fuser error 0115785 is your page count. You require a replacement fuser
Posted on Apr 14, 2009
Kyocera FS-3920DN call service 7410:0024247
make sure developer and drum unit are properly installed
Mar 12, 2017 | Kyocera Office Equipment & Supplies
Service error 5100
Straight from the Kyocera service manual.
Main charger high voltage error. Five pages have been printed with the main charger output short-circuited.
Causes: Drum unit installed incorrectly. Engine PWB installed incorrectly. Defective engine PWB.
Solution from service manual:
Verify harness is not pinched in the drum unit.
Verify harness is not pinched in the engine PWB.
Replace the engine PWB.
If you have tried to repair the printer yourself, just go over the reassembly procedure, you might have pinched a wire or one of the connectors might be bent or not in properly.
Regards
Jul 22, 2014 | Kyocera Fs-3920dn Laser Printer
How to reset kyocer 3920 service 7410 01?
Open left door(waste toner bottle)
push drum unit inside.
Jul 02, 2014 | Kyocera Fs-3920dn Laser Printer
How do I reset my fs-3920DN printer back to factory default?
go into service mode and print out the maintenance sheet and look for the ucode for factory reset
Apr 24, 2014 | Kyocera FS Office Equipment & Supplies
Kyocera FS-3920DN call service 2000:0011742
The call service 2000 is about the main motor. Pull the Developer Unit and then the drum unit out of the printer and check if the gears on both units are moving freely. Then turn the printer on without the 2 units and see if the motor is functioning. If your the motor moving then the message displays on printer will be 7410 (because you have the drum unit outside). There is a possibility that the transfer roller is damaged.
Mar 26, 2014 | Kyocera Fs-3920dn Laser Printer
BIG BLACK LINES ON PRINT
could be the fuser, drum, dv unit, mc corona, or lsu glass
Sep 13, 2013 | Kyocera Fs-3920dn Laser Printer
How can i changethe ip adrees from my kyocera fs 2000d
Here's the manual: http://usa.kyoceramita.com/americas/jsp/upload/resource/19873/0/FS2020D-3920DN-4020DNENOG-ADV.pdf
Go to page 65 for Network configurations directions.
Mar 22, 2011 | Kyocera FS-2000D Laser Printer
381 people viewed this question
jasbo
jasbo
