Question about SLY electronics SL014G MP3 Player
SL014G MP3 player. How do I turn on Shuffle/Random.
I have the manual, but the only options I see in the 'music' part are: When paused or stopped: *Local Folder (where my music is) *Delete File *Delete All *Exit When music is playing: *Equalizer >Natural >Pop >Rock >Classic >Jazz >Soft >DBB *Repeat >Normal >Repeat one >Repeat all *Replay >Set A-Set B *Exit Does the Random not work with the SL014G, or do I have to update it or something? All I have is version: LD3188-STD-1.1. If I do have to update the version to get the option to Shuffle/Randomize my music, how do I do that?
How do I shuffle songs on my Bush MPK8099BUK MP3 player?
If you set the play mode to shuffle. It should shuffle whatever you are playing, be it All Music, An album or a playlist.
you can set the player to shuffle by pressing the "M" button. from the menu choose "Repeat" mode press "Previous/Next" to scroll through the options until you get to "shuffle". [Press "Play/Pause" to confirm and press M to return to sub menu.
Aug 04, 2011 | Audio Players & Recorders
Is there a way to put the device on shuffle mode?
  • There is a random setting rather than a shuffle mode. Same thing just a different name.
  • While in the play mode menu press "PREV/NEXT" to select the desired repeat mode ie.
  • Normal, Repeat One, Repeat All, Random, Random All, Preview.
  • You want to choose "Random" or Random All" depending on
  • Random - All music is played randomly until all songs have been heard.
  • Random All - All music will play randomly until you turn the MP3 player off.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 13, 2011 | Curtis MPS2015 MP3 Player
What is the difference between shuffle all and smart shuffle all?
Smart shuffle let's user listen to favorite songs first and shuffle all means random mode playing function.
Thanks,
gylacz
Apr 07, 2011 | Philips GOGEAR SA6045 MP3 Player
How do I turn the shuffle off?? I go to settings, choose music options, choose shuffle and highlight "on" and nothing I hit makes it change to "off". Help!!
For the Sansa Fuze, the selection Shuffle Mode is correct, just like you told:
In Main Menu > Music > Submenu > Music Options > Shuffle Mode:
1. Select Shuffle.
2. Use thumbwheel to choose Shuffle on or Shuffle off.
(to play songs in random order, set Shuffle to ON).
3. Press Select to change the Shuffle mode.
See page 9 (=page 6) of the manual in pdf format for the Sansa Fuze:
http://mp3support.sandisk.com/sansa/UserManual/FUZE/fuze_userguide_en.pdf
Thumbwheel: 5
Select button: 9
Jan 07, 2010 | SanDisk Sansa Fuse MP3 Player
Why does sony E436F MP3 player change the order of the songs
Your music has likely been put on shuffle. Look on the screen while songs are playing. You will see two crossed arrows or the word shuffle or random. Check playback options and see if random or shuffle option has been turned on. Sometimes the program you use to put songs on the MP3 player will activate this option if the program's playlist is on shuffle.
Dec 16, 2009 | Sony NWZ-E436F MP3 Player
Music won't play in order it is listed
it is probably in suffle mode, try and go into the options menu in the actual Mp3 player and you will have to look for suffle or something uncheck it or turn it off or whatever the option is on the screen. but it is possible to find the manual online just look for it
Apr 23, 2009 | Innovage Shift3 MP3 Player
GPX ML648B wont shuffle -- not an option?
There is a RANDOM option. But I've found that it is restricted by folder. It's best used when you've moved all your music into one folder.
To turn this option on,
1. play a song
2. press the button on the side
3. select PLAY MODE
4. Choose RANDOM
Mar 31, 2009 | GPX ML648B MP3 Player
Sylvania SMP2002 Shuffle?
how do i play the songs on my songs on my sylvania smp2002 mp3 player because it wont play
Mar 09, 2009 | Audio Players & Recorders
Bronon W64 MP3/MP4 - Random music
When you start it up it should be at the "Home" menu. If you press the "M" button once it will take you to another menu that gives you a fair amount of options. The first selection should be "Shuffle". Just press the play button and it should turn the "Shuffle" on. Hope this helps :)
Nov 12, 2008 | RCA OPAL M4001 MP3 Player
SLY electronics SL014G MP3 Player Logo
Top SLY electronics Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a SLY electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
