Question about KitchenAid Kitchen Aid KFPW760WH - 12 Cup Ultra Wide Mouth Food Processor, White
Kitchen aid food processor blade , one of the blades came out of the socket.
It fits back in the socket but can I glue it and what kind of glue should I use if so?
  • karen Jan 09, 2013
    This is a food processor not the blender. the part ishttp://www.partselect.com/PS357062-Whirl... and only one of the blades came out of the hole or socket as I am calling it. The piece is not broken it just fell out
    Sergeant:
  • 475 Answers
No you can't glue it you need th replace it call the store or the manufactor and see what they say, thats there fault for that falling out call them.
Posted on Jan 11, 2013
  • karen Jan 11, 2013
    I'll call, thanks
3 Suggested Answers
SOURCE: The coupler on my kitchen aid has broken
Try http://www.kaparts.co.uk/ they are usually in stock and sent first class.
Posted on Jan 26, 2010
SOURCE: my blender is leakin from the blade and
I have the same blender and it's had a slow leak all the way up until today... when all of the fluid ran out of the bottom of the pitcher and all the lights on my blender started flashing. I've tried tightening the blade, but it doesn't seem to tighten... I think I'm going to have to call KitchenAid
Posted on Mar 30, 2010
CUISINART RECALL PART DFP 14
Cuisinart Food Processors Recalled by Conair Due to Laceration ...
https://www.cpsc.gov/Recalls/2017/Cuisinart-Food-Processors-Recalled-by-Conair
  1. Cached
13 hours ago - This recall involves the riveted blades in Cuisinart food processors with model numbers that begin with the following: CFP-9, CFP-11, DFP-7, ...
Cuisinart Recalls 8.3 Million Food Processor Blades Dating Back To ...
https://consumerist.com/.../cuisinart-recalls-8-3-million-food-processor-blades-dating-...
  1. Cached
7 hours ago - Yet Cuisinart has recalled 8.3 million food processors in the United States and Canada that pose a ... Affected models: CFP-9, CFP-11, DFP-7, DFP-11, DFP-14, DLC-5, DLC-7, DLC-8, DLC-10, ... Part of Consumer Reports.
DFP-14 - Food Processors - Parts & Accessories - Cuisinart.com
https://www.cuisinart.com/parts/food_processors/dfp-14/
  1. Cached
DFP-14. White And Stainless.Png Color Swatch Matte Black Metals.Png Color Swatch Brushed Stainless.Png Color Swatch White.Png Color Swatch Red.
Dec 14, 2016 | Cuisinart Blenders
Where do I register for replacement blades for recalled blender blades?
Dec 14, 2016 | Blenders
Why does water leak out when filled passed the top of blade
About 11,000 results (0.81 seconds) Search Results
    [PDF]Instruction Booklet Premier™ 11-Cup Series - Cuisinart
    https://www.cuisinart.com/share/pdf/manuals/dlc-2011.pdf
    Cuisinart11 cups (total processed weight varies by food) ... PowerPrep® metal dough blade, metal ... bowl at the top with ... filled out. WHEN. REMOVING BLADE: CAREFULLY REMOVE. THE METAL BLADE BY .... (If machine does not ... not put base in water or... These features, plus the .... have passed into the ... food from leaking.
    [PDF]Download Manual - Cuisinart
    https://www.cuisinart.com/share/pdf/manuals/dlc-10s.pdf
    Cuisinartmatching outline O on top of .... base in water or other liquid. General ... does not fit fully in the outlet, ... as you would sharp knives, out of ... 11. KNEADING YEAST DOUGH WITH DOUGH BLADE. 12. KNEADING BREAD DOUGH ... loodfrom leaking...... uid onto dough as it passes under ..... Fill the feed tube wilh the pieces,.
    [PDF]Food Processor - Cuisinart
    https://www.cuisinart.com/share/pdf/manuals/dlc-xp.pdf
    Cuisinart
Feb 08, 2016 | Cuisinart Prep 11 Plus Dlc2011chb Food...
Any ideas how I remove both the mixing bowl & blade that won't release from my hardly used (maybe 10x's) Kitchen Aid Food Processor?
It sounds like the blade has become jammed on the motor shaft sleeve. You will be up for a new blade and motor shaft sleeve to sort that out. They are not expensive and it is the only proper fix for them. If you replace nothing it will happen again pretty much straight away and if you only do one the other damaged part will wreck the new part. To solve the not turning on problem which is a separate issue it will very likely involve replacement of either the bowl or the lid. One is as likely as the other, I have both parts in stock so I try one or the other to decide which one is the problem. Getting the blade off is a real chore, I have a small chain (with welded links so very strong) I put a couple of turns around the big blade shaft and fix it there with a shackle. It's about 2.5 meters long so I attach the other end to the leg of my bench and accelerate the motor unit away from the bench. The chain comes tight and shocks the blade off. I then drill a hole through the motor shaft about 8 mm from the top, attach the chain to that with a shackle and shock it off just like the blade. New parts now and job done.
Nov 20, 2015 | KitchenAid Kitchen Aid KFPW760WH - 12 Cup...
The blade won't 'lock' on my kitchenmaid food processor. It is new.
The blade off the shaft or on it will not prevent the processor from starting. The safety interlocks are on the bowl, lid and pusher so look there for the problem.
Feb 20, 2015 | KitchenAid Kitchen Aid KFP715OB - Food...
Food processor won't turn off
Probably going to require a new 3 button switch panel, they are not hard to fit.
Feb 17, 2013 | KitchenAid Kitchen Aid KFPW760WH - 12 Cup...
I have a kitchen aid blender with a polycarbonate jar. The jar leaks at the blade. I noticed it has a plastic nut on the bottom with left hand threads. However the nut will not fit over the drive gear...
Older KitchenAid blenders had a jar that was made so the blade assembly could be removed for cleaning. On the newer models the blender jar and the blade assembly are all one unit so you have to purchase a new jar to get the blade assembly. All of this is dependent on which model of blender you have.
We would be happy to help you. Please a give us a call at 1-800-339-9297 we would be happy to help! One of our repair technicians can talk you through the repair over the phone free of charge. On the bottom of your blender is the model and serial numbers; have these handy when you call so we can help you order the correct part.
We have several blender jars on our Web site http://www.mendingshed.com/kitaidblen.html for KitchenAid blenders. If we don't have the blender jar that fits your model in-stock we can order it and ship it to you. Please contact us with any further questions. You can also email your model number or questions to customerservice@mendingshed.com
Sincerely,
Mendingshed.com Staff
Aug 28, 2011 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
KitchenAid Kitchen Aid KFPW760WH - 12 Cup Ultra Wide Mouth Food Processor, White Logo
246 people viewed this question
Top KitchenAid Blenders Experts
Appliance engineer
eyecam
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
